Arris Touchstone 450a (CM450) Modem Logo
A
Anonymous Posted on Feb 28, 2013
Resetting router and modem - Arris Touchstone 450a (CM450) Modem
1helpful
4answers
The connection in the router is there but we cannot use it. what we are going to do
Perform a full reset of the router. With the power plugged in, press the reset button for 30 seconds; keep the reset button pressed and pull the power plug out for 30 seconds; keep the reset button pressed and plug the power back in. The unit will reset to the factory settings.
User the software and instructions that came with your router, or download them from the Linksys website, and log onto the router and use the setup program to finish the setup.
Ho do I sync my wireless router to my new modem
Turn the new modem off.
Turn the wireless router off.
Turn the modem on.
Wait 60 seconds for the modem to reset itself.
Connect an Ethernet cable from the modem to the 'WAN' port on the router.
Turn the router on.
Wait 60 seconds for the router to reset itself.
Done.
Reset modem to default
modems don't have any settings unless you are referring to a modem/router combo. Routers or modem/router combos, commercial/home grade routers can be reset by locating the reset button, or pin sided hole on the back of the router typically labeled "reset" press and hold for 10+ seconds and this will restore the device to factory settings including passwords.
1helpful
When I first started using this modem, it worked great and easily worked well with my Belkin router. One day when I came home, the modem was only flashing the "power" light was flashing and I had...
Flashing power light on Router is sign of hardware failure As mentioned, you have already reset the router
You can try to hard reset the router one more time
Follow this procedure
1. Press the reset button with some paper clip 2. Wait for 10 Secs 3. Turn of Power to the router (While Reset button is still pressed) 4. Wait for 10 secs 5. Power on router 6. Wait for 10 secs and then release the Reset button
While doing this make sure reset button is pressed continuously start from Step 1 - 6
Check if Power light still blinks
If No - you can setup router like before and it will work If yes - Buy a new router or get it replaced if under warranty
Access to internet through the modem works fine. As soon as I hook up the router, no access. I have booted up the modem, the router, and the PC with no luck. I have pressed in the reset button on the...
you can not acces the internet if you reset the modem and the router. once you reset the router it set back to original factory setting. theres a certain configuration for the modem the router especially for the ip address. you have to get in touch w/ your internet service provider for the modem and router configuration.
The Router is showing modem prob : when router out of loop works
Your router needs to be configured correctly
Turn everything off, modem, router and computer.
Turn on the modem first and wait for a solid data/connect light.
Turn on the router, give it two minutes.
Still if problem presists you need to reset the router ..
How to reset::
Push and release the “Reset” button.
The lights on the Router will momentarily flash.
The “Power/Ready” light will begin to blink. When the “Power/Ready” light becomes solid again, the reset is complete
I have a primus modem hocked to router computers don't connect if i connect modem direct it works what do i do
attach the router to the modem, computers to the router. then turn off the computers and press the reset button on router first. when it comes up press the reset button on modem. most cable/dsl modems can only use one device. if the router is all that in on when it is reset it will use it's ip address. the router will pass this along to the computers.
Belkin F5D8638au4A modem-router. router operation
Try first to reset and reconfigure the router , to reset it press and hold the reset button of the router for 10 seconds while power is ON and then after that reconfigure the router........
MY INTERNET WAS DONE AND CALLED COMCAST TO RESTART AND THEY TOLD ME IT WAS MY ROUTER THAT NEEDED TO BE RESET, THEY TRIED TO RESET, AND THERE IS A CONNECTION THERE BUT NOT WITH THE ROUTER HOW CAN I FIX THIS
Hi
Connect the modem and the router. Make sure the cable from the modem goes to the internet port in the router.
Reset the modem.Resetting the modem can be done by using a paper clip and insert it to the reset hole found on the back of the modem. Restart your router and systems.
Check if this resolves your issue. Post your results.
Thank you
rakesh
Dell Laptop Expert
4helpful
No internet when using router
Your modem has already registered itself with the MAC address of your computer, so it doesn't recognize the MAC of your router. In cases like this you have two options:
  1. Configure your router to clone the MAC of your computer
  2. Connect the router to your modem and do a soft reset so the modem registers itself with the MAC of your router.
Clone MAC - Go to your routers Admin web interface and on the main page you should see the "Router MAC Address" section at the bottom. Select "Use Computer MAC Address" and click "Apply" and your router should reboot and you'll be back in business.
Soft Reset
- Plug the modem into the router via the ethernet cable then do a soft reset.
To do a soft reset, do the following:
  1. pull the power cord from the modem
  2. count to 5
  3. hold down the Reset EMR button on the modem
  4. plug back in the power
  5. count to 30 while holding the Reset EMR button (the modem should be blinking a lot)
  6. release the Reset EMR button and see what happens.
Top Arris Computers & Internet Experts
Jesse Walters
Jesse Walters
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
