Question about Hotpoint WMA40 Front Load Washer
Hotpoint wma40 door seal
I have a hotpoint wma40 washing machine. The door seal has black grime on the edge and inside the seal. I have tried wiping it with bleach on a cloth but it will not shift. Do I need a replacement door seal?
You may also have a black well. If you are not using city water wells often have to be bleached out. Have your water tested.
Posted on Mar 20, 2009
  • 188 Answers
The black grime is mold. Once it is set into the rubber it is nearly impossible to remove. Bleach would have been my suggestion but since you've already tried that, replacing the bellows (door seal) is your next option. In the future, when the machine is not in use try keeping the door slightly open for any standing moisture to evaporate.
Posted on Feb 19, 2009
How do I change the door seal on my Hotpoint WMA40 washing machine
Best to watch this video on youtube which explains it in detail
May 14, 2014 | Hotpoint WMA40 Front Load Washer
Hotpoint wma40
hi take the band of rubber just inside door take soap draw out take screws out holding panel this comes of dont pull wires of control panel or mark were they go take kick plate off you have screws holding bottom of panel top ones are under top panel take two screws holding catch out were door clips in push panel up you can get to front of drum to take off takes about 15 min oh sorry top off 1st hope this helps
Jan 29, 2014 | Hotpoint WMA40 Front Load Washer
Can sumet be blocked in my washer as wen it spins the water dont empty and i get a flood out the door and powder part
You need to clean the filter.
Remove lower rear panel of washer, locate and remove large black hose on bottom of drum.
Remove and clean plastic filter inside the hose.
Jan 22, 2011 | Hotpoint WMA40 Front Load Washer
The water wont drain out of my hotpoint machine
Remove lower rea panel of washer.
Locate and remove the large black hose fastened to the bottom of the drum.
Remove and clean the plastic filter inside the hose.
Oct 21, 2010 | Hotpoint WMA40 Front Load Washer
How Do you take the top off the Washing Machine Hotpoint WMA40
you need to remove the screws at the kick panel on the lower front panel by the floor, then the top cover screws are under top cover inside machine remove these and top will lift up
Dec 24, 2009 | Hotpoint WMA40 Front Load Washer
Hotpoint WMA40 washing machine is leaking from detergent drawer- any suggestions ? Thanks
Hotpoint WMA40 washing machine is leaking This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Nov 27, 2009 | Hotpoint WMA40 Front Load Washer
Brocken door spring
If you have not rectified your problem, you need to seperate the 2 door halves by removing all screws securing the 2 halves, and prize`appart, then you can easily change the spring.
Please rate my solution.
Thanks.
Oct 05, 2009 | Hotpoint WMA40 Front Load Washer
How do I change the door seal on my Hotpoint WMA40 washing machine?
It's a push fit seal. Carefully remove the old one and for help, smear the new seal where it fits the machine and just push it into place securely.
Sep 07, 2009 | Hotpoint WMA40 Front Load Washer
Blocked filter
This is for the WD420, but could be useful for you.
The filter is inside the machine. If you machine is still under guarantee I would try and get it done that way. Otherwise turn off the power and pull out the machine to get a the back.
Remove the panel at the bottom where the discharge hose comes out. You should see a black concertina type tube coming from the drum attached by a jubillee clip. The filter is inside. Losen the clip and pull away the tube take out the filter and clean it. When you replace it don't forget to put the ball float back in and check its well fixed by running a spin cycle before sealing up.
(courtesy pollydolly10)
Feb 23, 2009 | Hotpoint WMA40 Front Load Washer
Door interlock flashing
Same issue with loose solder joint on the relays inside CCU (computer control unit)
the same bad CCU is used by several manufactures.
you have to open the CCU and re-solder the the relays to the board. they have microcracks around the legs.
you will get the door lock issue randomly.
to prove the issue open the top access panel .and pull up on the center black plastic connector and the issue will go away.
Dec 14, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WMA40 Front Load Washer Logo
465 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
