Question about HP iPAQ hw6915 Smartphone
HP IPAQ HW6915 get stuch charging non original battery
I just bought a non original replacement battery 3.7V 1200mAh for my IPAQ HW6915, but during the charging process, the telephone get stuck with the green led on, and I have to reset it in order to use it. I replaced the battery with another replacement, and I got the same result.
With the original battery the problem does not exist (mind that the original battery is slightly exhausted). Is it possible that the battery for the 65XX
series is not compatible with my 6915? Is there some other known issue around non original batteries?
I found out how to not to get stuck. :)
Just set START->Settings->System->Power->Advanced: UNcheck "Turn off device if not used for..." On AC power.
And when your PDA is in a cradle or on a charger, do not suspend it. It is also useful to set the backlight to switch off after some time when on AC.
Tadaaa!
I hope I helped.
Paulus
Posted on Aug 08, 2009
I forwarded the request to some more professional forum.
Posted on Feb 22, 2009
My screen is not visible after I put my HP iPAQ HW6915 in my pocket.
very old device, nobody uses today, its obsolete really
not supported.
why ask here, , why not ask at HP.com
the real deal , HP. we are NOT HP, at fixya.
https://h30434.www3.hp.com/
a new battery? tried?
Jul 28, 2017 | HP iPAQ hw6915 Smartphone
The hp ipaq 6915 i have just shows the serial,hp
Ciao,bisogna premere le due cornette(telefono verde e rossa)) + on/off e soft reset insieme,poi sul display per 2 secondi appare la scritta CLEAR OK,dopo premi solo le due cornette(telefono verde e rossa) e il softreset insieme per qualche secondo almeno 15 finch? non si avvia per centrare il display.Tutto qui.ciao Dario
Nov 16, 2009 | HP iPAQ hw6915 Smartphone
I have an iPaq hw6915 that keeps crashing even though there is still 60-80% battery life in it. I've had it for about 2 years, and this problem started 2 or 3 weeks ago. Do I need a new battery, or could...
It is more likely to be some kind of system corruption. If you have not installed much software and don't stand to lose much if you were to reinitialize the system, I would try a hard reset if all else has failed.
The OS is non writable, so it would be very difficult for anyone to hack into while you are online, unlike a desktop or laptop system, which is far more vulnerable to such attacks. These PDAs are however vulnerable to power surges and power cuts when connected via the cradle etc. I would also agree with others that the battery is certainly a weak point with these models, although personally I am not willing to pay out HP prices for a replacement each year, and mine also tends to show 80% charge much of the time.
You should also probably be more specific about your description of the fault - under what conditions does it crash, for example?
Sep 11, 2009 | HP iPAQ hw6915 Smartphone
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
My HP Ipaq 6915 goes off at 60% battery level or when i try to connect to wi fi, and switch off my bluetooth. At 85% battery power level i cant make or receive calls. It just loses network connectivity,...
The batteries from Ebay that are from China have lots of issues. I use an HP 6945 phone/pda and had the same issue with my original battery. I tried a cheap battery and it died within 2 months. I ordered an HP original battery and have been using it again full strength for 7 months. The new battery works bluetooth, wi-fi and gps as well as phone down to about 15% before I recharge. The HP batteries are more expensive but they are worth the extra price.
Buddy
Corporate Computer
Over 21 years of PC and printer service/support
Mar 10, 2009 | HP iPAQ hw6915 Smartphone
HP ipaq hw6915
keep on saying no gps device (no flight mode)
Jan 01, 2009 | HP iPAQ hw6915 Smartphone
Charging issues for HP Ipaq 6915 in my car
Hey,
If you only have issues in your car and it charges fine in the house the the problem is with the car charger
Let me know if you need anything else.
Thanks,
Ekse
Dec 24, 2008 | HP iPAQ hw6915 Smartphone
Amber light remains lit at all times
Did you try to replace the battery?
Nov 25, 2008 | HP iPAQ hw6915 Smartphone
Hp ipaq hw6915
Try a Reset....
Performing a Clean Reset will help
A clean reset clears all user-installed settings, programs, and data, and restores
your HP iPAQ to factory settings.
To perform a clean reset and return your HP iPAQ to factory settings:
1.Press and hold the Answer/Send, Power, and End Call buttons.
2.While holding these buttons, use the stylus to lightly press the Reset button on the bottom of the HP iPAQ until the device restarts.
3.When the HP iPAQ restarts, release all of the buttons, and then remove the stylus from the Reset button.
The HP iPAQ restarts and powers on.
Thanks
Nov 03, 2008 | HP iPAQ hw6915 Smartphone
HP iPAQ hw6915 Smartphone Logo
354 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
