Question about Dell Dimension 5100 (D51L1) PC Desktop
My dell pc key board has swapped the @ key with the 2 how do i fi
Fix fix fix it please
  • 479 Answers
Might be that @ key is swaped with the : and vice versa.
This happens because of the language settings so go in control pannel and go to the language and regional settings and select the laguage as English US inplace of UK.
If then also the issue is not resolved then u will have to format the machine and while formatting select the English US then only the issue will get resolved.
Posted on Feb 19, 2009
Turn on wi-fi on laptop
It can depend on the type of laptop you have. On a dell inspiron they have keys across the top with F1, f2, F3 etc. There is a little key F2 on the dell that has a ficure of a tower with a signal coming out. Hit that key to turn it on and off
Aug 25, 2014 | Acer Computers & Internet
Wifi button location
To enable Wi-Fi you may try following the below steps:
    (1)Turn on the computer.
    (2)Keep tapping the F2 key at the startup, BIOS screen appears.
    (3)Move to wireless tab.
    (4)Select Internal Wi-Fi and enable it
    (5)Now move to wireless hotkey and select Wi-Fi & BT.
    (6)Save this settings and boot to windows.
    (7)Now press FN key+ F2 key to enable Wi-Fi.
    Thanks and Regards.
    Kiran Kumar.
Jun 16, 2014 | Dell Precision M90 Notebook
I am sure half of gallon of bleach is alot of fluid.
You will have to open up the laptop and inspect it. I advised to take it to a trained technician.
Jun 07, 2014 | Dell Inspiron Computers & Internet
I Can't Turn On My Wi-Fi
i think it is the blue FN key bottom right and the F2 key above the no 2 key
so press FN+F2 both at the same time
hope this works for you
Feb 01, 2011 | Dell Inspiron 1501 Notebook
I have a stuck key on my lab top computer but i do not know witch one is stuck how do i determine witch key is stuck. this is on my dell latitude c610 labtop
There is not an easy way to see which key is sticking on your laptop. The good news is that a replacement keyboard will fix the problem, and it is easy to swap out, and not too expensive. They are usually only about $20 on ebay, and instructions are available too. If you buy a keyboard, and don't feel up to changing it, most computer shops will help you swap it out for not too much cash...
Hope you fix it!
May 03, 2010 | Dell Latitude C610 Notebook
Latitude d505 won't display image through projector. Being used with Sanyo plc XU41 and Promethean board. Board is interactive but no help if there is no image to see! Other Dell laptops work with this...
Dell laptops normally have a 3-way toggle for the display destination: 1=screen 2= external display and 3=Both. To toggle from one mode to the next press hold the 'FN' key (lower left corner of the Key board), and the briefly press the 'F8' key. Wait a few seconds for the hardware to catch up and you should see a display through the projector. If not, repeat the 'Fn' + 'F8' combo again.
You could also try running diagnostics to verify that teh video card is working properly. To do that, sthar with the laptop off. Hold the 'Fn' key down while you press the power button. Release both as the machine begins to boot up. It should start in diagnostics mode. Run the quick test and watch for the color bars. If you see then, the video card so=huold be OK.
Good luck, And please let me know how it turns out for you.
~ Spoem
Oct 01, 2009 | Dell Latitude D505 Notebook
I cant boot up my computer(memory address line failure)
This is clearly a problem with the memory. You can try two things:
1) Remove and reseat the memory sticks (with the unit unplugged)
2) Swap the boards around. Windows is not very tolerant of errors in the lower portion of memory. Swapping around the boards will change the relationship of physical memory addresses to virtual addresses. At the very least, the memory swap may help to determine which memory stick is defective.
Please keep us posted.
Aug 20, 2009 | Dell OptiPlex GX110 PC Desktop
you have to do a complete power drain to your pc
follow the below steps
1) unplug all the power cables from wall socket
2) Hold the power button for 5miins
3) then reconnect the power cables then restart
it while restarting please click F8 key in the key board continously
4) In that you will able to find the menu option
Last Known Good Configuration
select the option and click on enter key
the issue will get fixed
still if you face any issues
please do not hesitate post the issue
in detail
i will guide you more in step by step
Mar 26, 2009 | Dell Dimension 3100 PC Desktop
Dell Inspiron 6400 cant get wireless connection
The Wi-FI light turns on when wireless networking is enabled. To enable or disable wireless networking, press and hold the blue <Fn> key and press the <F2> key. The <Fn> key is located on the lower left hand side of the keyboard.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Jan 19, 2009 | Dell Inspiron 6400 Notebook
Dell Dimension 5100 (D51L1) PC Desktop Logo
Alun Cox
