Question about Nokia E71 Smartphone
Unable to remove the yahoo go application in my nokia e 71 phone
Hi, please help me to remove the yahoo go application in my nokia e 71 phone,
  • 395 Answers
Please follow these simple step.
Step 1. Go to Menu > Installation > App. Mgr.
Step 2. You can remove the yahoo go application from there.
Regards
Posted on Aug 21, 2009
Hi, need unlock code please for my E-71 IMEI 353782040061398 Please send to Larsonkaos@yahoo.com Tyvm :-)
hi to purchase codes visit mobileunlocksolutions.com here they ask you the network name to which your mobile is locked .then visit mobileunlockguide.com here they provide free instruction guide about how to use codes in your mobile.
Jun 01, 2012 | Nokia E71 Smartphone
Nokia n81 problem
Hello thereThe phone you are using is same as mine,yes last year my phone also having this problem but I have solve it by formatting my phone.So, try format it by using the short code *#7370#.Good luck.Thanks for visiting fixya
Feb 16, 2012 | Nokia N81 Smartphone
Hi sir i am unable to use any installed applications in my nokia 3110c. like opera mini.
im sad to say that opera mini is not compatible with your phone and your phone is quite old so most of the new application wont run on it.... you cant run applications that are not compatible with your phone.... so please check the compatibility list before installing/downloading the application to make sure that it will run in your phone....
akuma_ryu21 don't forget to rate.. i hope that i helped you..
Apr 27, 2011 | Nokia 3110 Cellular Phone
After downloadin i keep gettin an error sayin 'unable to install'. Am using a nokia n95. Please help me.
I have nokia n 73 and i too come across this problem quite a times. First of all try switching off the phone and then try reinstalling the application after restarting the phone.
OR
There is nothing wrong with the phone for this issue but what happens is some times the application we download has its certificate expired and when we try to intall the application it says unable to install.
So try downloadng the latest version of the application and if possible from some different site or official site of the application provider.
I hope that will solve your problem as it solved mine number of times.
Thanks
Nov 08, 2010 | Cell Phones
N73 when i try to open bluetooth application it show error msg as unable to perform bluetooth operations wht to do ??????? please suggest once i had already restored by*7780# still same problem continues
The error massege shows as unable to perform bluetooth operations when memory is full.
Try to delete some of the data applications and try to perform the bluetooth operation.
Even if you find the same problem to perform bluetooth the remove the battery when the mobile is switched on and remove the sim and reinsert after 2 mins.
Hope I helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 09, 2009 | Nokia N73 Cellular Phone
Iam unable to install a SIS file ( application softwares/games ) to the Nokia N73 Music Ed: Handset. The error message that I get is " Unable to Install". Can somebody help please. my E-Mail Address is...
n73 is S60 3th version, and sis is application instaler for earlier edition... you have to use sisx files for your phone...
I hope this helps...
Apr 24, 2009 | Nokia N73 Cellular Phone
Advance device lock for nokia e 71
my phone is nokia n 81 8 gb .its locked i cant enter in my normal phone, so please give me the solution for that, please help me out
Feb 19, 2009 | Nokia E71 Smartphone
Nokia 7610, Web unable to process
CHECK YOUR CONNECTION SETTINGS ,THAT CHANGE YOUR CURRENT ACCESS POINT TO SET US DEFULT
Jan 05, 2009 | Nokia 7610
Hi, its about my N73 lock code
The default security code for Nokia is 12345
IMEI: 356406013883474
Master code: 0615326066
Close all applications on your phone.
With your phone switched ON, remove the battery.
Then remove the SIM card.
Replace the battery without the SIM card and switch your phone on.
Type in the security codes (any code) until the phone request the Master code, when it does, leave your phone still, don’t use it for 15 minutes, then type in the Master code.
This is the code needed to reset the Security code, nothing else, and it’s for your phone only.
If it does not request the Master code, your phone will have to be connected to a computer via an unlock box to restore the Security code.
Sep 10, 2008 | Nokia N73 Cellular Phone
APPLICATION CLOSE...
There might be a problem either with the program you are using or with nokia 6600 .if you are using facing problem with program try to reinstall that file,but if you think that your mobile is having problem than you can format your mobile or flash your mobile .When you flash your mobile ,it will become new as you you purchased means factory settings....
A. Blank screen phone unable to boot-up. B. Phone is only able to boot-up to “Nokia” screen (may flash “Nokia” 4 times also).
C. Install a program but unable to uninstall it.
D. Unable to delete certain files on C drive. WARNING: This will ERASE EVERYTHING on your phone
If you have any files that are important to you, make backups.
1. Make sure you phone is fully charged.
2. Backup your contacts list and personal files to MMC memory card (if possible).
3. Switch-off your 6600 phone.
4. Press and hold these three keys together
-Green dial key,
-Star key (*)
-Three key (3)
then press the power on/off to swtich on the 6600 phone.
DO NOT let go the three keys until you see the “formatting” screen displayed
5. After a few minutes, the format will be complete. Your 6600 will now be at its original factory settings.Disclaimer: I will not be held responsible for anything that happens to your phone as a result of following my guide. Use this guide at your own discretion and risk.
If this answers your question please rate this as fixed.
If you need more help just add a comment and I'll be glad to help you further... Thanks
dilipbagdi - johny_inmexico@yahoo.co.in
May 11, 2008 | Nokia 6600
Nokia E71 Smartphone Logo
280 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
