Question about Epson Stylus Photo R200 InkJet Printer
Red light on green light on
I've just put in a new black cartridge in an effort to get the red light to go out but it hasn't made a difference. I only want to use black. Is there a way I can "turn off" the coloured cartridges as I don't use them and maybe one of them (there are five) is causing the red light problem. I can't afford to replace all the colour cartridges in an effort to work out which is at fault.
2nd question - how do I tell how much ink is left in a cartridge? And how do I perform a printhead clean?
  • Epson Master
  • 419 Answers
The other two solutions are completely incorrect for this problem so ignore them... They're fixating on the "service required" issue instead of reading the problem properly.
Right... to answer the question properly.
Short version is "No" You cannot printer using just black cartridges without having your other cartridges registering as full or at least not empty.
The reason for this, whilst understandably frustrating, is that your printer is a colour inkjet printer and by design is not intended to print just black. As a result it's expected to be able to produce a colour document or image at any time and needs to keep itself ready to do so.
So, the printer will regularly eject ink out of it's nozzles to keep them clear of rubbish, dust, or clogged ink so it can print successfully when you are ready to print in colour.
All these little cleaning routines are performed regularly and after a while they predictably get empty and need replacing. If the printer just ignored them then the colour nozzles would become damaged, clogged and not work so the printer is programmed to scream blue murder and refuse to work unless you sort it out.
It's a pain but in truth the best solution to the problem is to get a mono laser printer and use this instead. It's cheaper, more forgiving of inactivity and does what you need.
Not exactly a solution I realise but hopefully it explains some of the logic that goes into these things and why it has a sort of license to drive you slightly nuts :)
Hope that helps.
Posted on Mar 09, 2009
  • Epson Master
  • 541 Answers
Put this in to google (ssc) download it and this will reset your printer
Posted on Mar 03, 2009
I've tried, in vain, every recommendation that has been suggested. I've emptied the toner bin, changed out the toner cartridges, bought a new USB cord and installed it in a different port,...
Hi
There might be a problem with the paper sensor. Check the rear portion of the printer where you get the paper out try to open the back of the printer and check if the sensor is working well. Usually it will be stuck and need to be released. And if you can just give a little bang on the back of the printer this may cause the sensor to trip and start working.
DO NOT FORGET TO RATE MY ANSWER
Jun 29, 2011 | Samsung CLP 300 Laser Printer
When should I replace the toner cartridge? I found that red light is flashing( the lower light, totally there are 2 lights: upper one is green now). I don't understand what does it mean.
It mean when your toner is near empty,then red light flashing.tow light is fixed or red mean toner cartridge is empty.must be replace toner cartridge.You buy a new cartridge and put in your printer then printer is OK.
you can also get better idea please read printer user guide.
Mar 04, 2010 | Samsung ML-2240 Laser Printer
Epson C60 - The green power light and middle red error light
-reseat the new cart
-clean the contacts (cart and carriage)
-try a new cart
Sep 04, 2009 | Epson Stylus C60 InkJet Printer
Epson 830u Printer Red light stays on even with new ink
I realised that I had to replace both the ink cartridges even though I only wanted to replace the black for it to work. Once I replaced both the black and colour cartridge the red light went off. Thanks
Feb 11, 2009 | Epson Stylus 830U InkJet Photo Printer
HP 57 refill problem
You are doing nothing wrong. The nozzles are clogged. Try taking a clean syringe and put your finger on one of the magenta (red) refill holes. Fill the syringe with air. Put it on the second magenta refill hole and blow the air inside. That should force out the ink that has dried and that is not letting the new ink come out. You might have to do that several times. Sometimes, it can help.
If that doesn't work, go to a refill shop, they should be able to clean the print nozzles on your cartridge, no need to buy new ones.
Feb 12, 2008 | HP Easy Refill Kit for (HP) Black Inkjet...
C88 only green and yellow
You are out of black and magenta (tricolor cartridge) ink or ink has dried up.
Try touching the nozzle plate (underneath print cartridge) with a water dampened cloth (not alcohol) for cleaning clogged nozzles (do not rub).
Ultimate remedy : put in contact nozzle plate with hot water for about 5 seconds.
If color still missing your printer need new cartridges.
Jan 06, 2008 | Epson Stylus C88 InkJet Photo Printer
Red light
It could be a faulty printer cartridge(it happens). One way to check for this is put in your old cartridge(even if its empty!). If the printer goes to a ready state with your old cartridge, then the new cartridge you replaced might be the problem! if you are refilling cartridges, check out this site http://www.inksupply.com/chipreset.cfm let me know how this turns out regards, babb
May 10, 2007 | Epson Stylus Photo 1280 InkJet Printer
Epson Stylus Photo R200 InkJet Printer Logo
98 people viewed this question
Top Epson Office Equipment & Supplies Experts
Michel Smith
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
