Question about Vizio L37 Television
My mute does not work
I press the mute and hold it dow n. then let it go and it does not mute the sound
  • 718 Answers
You will have to isolate the problem. HDTV, remote unit, infrared receiver in set.
Operate the mute from the buttons on the set to see if it works.
If it works then the problem is probably in the the remote unit since the infrared unit on the set is receiving other commands from the remote unit.
If it does not works then the problem is in the TV set.
(This is a better problem than having the mute on all the time.)
Posted on Mar 07, 2009
When my phone get into mute I do not know how to set off the mute to listen the phone again
Hi Joaquin
Try this...
Turn silent mode on or off
Press and hold On/Off.
To turn on silent mode:
Press Mute.
To turn off silent mode:
Press Sound.
Feb 29, 2016 | Samsung Galaxy Cell Phones
My volume buttons on my compaq presario c769us are not working , is there a combination for the volume buttons
From the manual:
http://h10032.www1.hp.com/ctg/Manual/c01114193.pdf
Hotkeys are combinations of the fn key (lower left of keyboard) and one of the function keys:
Mute and restore speaker sound. fn+home
Increase speaker sound. fn+pg up
Decrease speaker sound. fn+pg dn
To use a hotkey command on the computer keyboard, follow either of these steps:
Briefly press the fn key, and then briefly press the second key of the hotkey command.
- or -
Press and hold down the fn key, briefly press the second key of the hotkey command, and then
release both keys at the same time.
Muting speaker sound (fn+home)
Press fn+home to mute speaker sound. Press the hotkey again to restore speaker sound.
Increasing speaker sound (fn+pg up)
Press fn+pg up to increase speaker sound. Hold down the hotkey to increase speaker sound incrementally.
Decreasing speaker sound (fn+pg dn)
Press fn+pg dn to decrease speaker sound. Hold down the hotkey to decrease speaker sound incrementally.
More manuals for this model:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lc=en&product=3678775&
Jan 25, 2013 | HP Compaq Presario C769US Notebook
HP probook 4420s stuck on mute
Look on you system at the keyboard and you will find a key that toggles the mute if he pressed it. It will toggle between on and off. Normally the mute key or button will look like a megaphone and if it is muted it will have an x over it. Press it to unmute it. Sometimes if it is a key, you might have to press the FN, CTRL or ALT key while you press and hold the key that toggles the mute.
Another way to remove the mute is to Double Click on the megaphone if you see it at the bottom right near the time. This will bring up the volume control and you just remove the check mark from any that is muted.
Also you can click Start/Control Panel look for volume controls that might be muted and remove the check mark on mute.
Also click Start/Programs/Accessories/Entertainment/Volume Control and remove the check mark on muted items.
Apr 07, 2012 | HEWLETT-PACKARD HP ProBook 4420s XT940UT...
Hi I have ACER 4738Z Laptop in which i have windows 7 installed, But i have audio problem in that, like in the Volume control it shows as not muted but there is no sound either in speaker or either in...
Try to check the sound level. For an Acer laptop/ Windows 7 operating system, you can set the audio to zero but it does not say it is muted. Just click on the sound icon and the sound level should appear. Adjust the sound level and that should allow you to hear something.
If this does not work, try to go to the control panel (start > control panel > change the view to small icons > choose sound ) You should be able to see there two available sound drivers. Enable the one that says Realtec.
Jul 04, 2011 | Computers & Internet
I have a dell d520 laptop and it has no sound. Also I cant find the volume button. Where is the sound card placed?
The sound card is inside the laptop and is part of the motherboard. This means that you cannot take the sound card out and replace it.
You may need to reinstall the audio drivers for the machine but check first that the volume has not been muted. Look to the bottom right of the screen for an icon that looks like a speaker and click on that and see if it has been muted or just turned down.
If there is no speaker icon there it may have disappeared from the system tray. You can use your keyboard to turn the volume up or down and to mute and un-mute it.
The keyboard toggles are as follows >>>
To turn the volume up hold down Fn and press the PageUp key.
To turn the volume down hold down Fn and press the PageDn key.
To mute hold down Fn and press the End key.
It is also a good idea to check in the BIOS to make sure the on-board audio has not been disabled.
If there is anything else please post back.
Good luck and kind regards.
Apr 28, 2011 | Computers & Internet
My cisco ip phone 7960 is stuck in boot up mode after performing the soft reboot. i press 123456789*0#
You can try a couple of things: Unplug the power cable from the phone, hold dows the # key, and then plug the power cable in again. The phone begins its power up cycle. Release the # key after the Speaker button is no longer lit. You should see the following message on the phone: "Reset key sequence detected" Press 123456789*0# within 60 seconds after the Headset, Mute, and Speaker buttons begin to flash. If you enter this key sequence correctly, the phone displays this prompt: Keep network cfg? 1 = yes 2 = no In order to maintain the current network configuration settings for the phone when the phone resets, press 1. In order to reset the network configuration settings when the phone resets, press 2.
Or to perform a full reset: Press **#** to reset the Cisco IP Phone 7960
Mar 15, 2011 | Cisco 7910 IP Phone
How to enter service mode 43h83 toshiba mute 3 times mute again and hold menu on tv dont work also volume alway down on tv press hold 9 no go also help need to adj convergence
Its press mute on the remote twice. Then for the third time on the remote press the mute on the remote and while pressing the mute that third time press menu on the front of the TV
Nov 28, 2009 | Televison & Video
NO AUDIO AND SOUNDS OF MY COMPUTER.WHAT WILL I DOWNLOAD?
make sure that the speakers are plugged in right and check the system isnt muted by goin to the system tray and double clicking on the speaker and make sure its not muted or turned dow, then depends on the hardware, download the drivers for it. If its intel based then its most likely a realtek hardware.
Oct 21, 2009 | Microsoft Windows XP Professional
Compaq C770
Your computer has a program on it called quick launch. It could be that the function key won't work until the program is loaded up into the memory of your computer.
Jul 16, 2008 | Compaq Presario 700 470024-192 Notebook
No soun thru speakers
First try resetting the unit. If that don't work try this:
Press and hold the SETUP button for at least 3
seconds.
2 Press the UP button repeatedly to select
“mute”.
Each press of the UP button changes the
modes as shown:
NOTE
If you press the DN button the display scrolls in
reverse sequence.
3 Press the TUNE button to toggle the mode
between MUTE ON and MUTE OFF
4 Press the SETUP button to set the selected
mode.
→ NORMAL/HI-FI → AMBER* → DIM → SUB
DEMO ← AUX ← SCR ← MUTE ←BEEP ←
May 30, 2008 | Alpine CDA-7876RB CD Player
Vizio L37 Television Logo
213 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
