Question about Lexmark X9575 InkJet Printer
X9575 phone conflict
When using my ohone also on the fax line for no reason the fax machine starts uop with its high pitched dialing.
    Scholar:
  • 124 Answers
You may have wired your FAX and Phone up wrong. Go to the following website to view the Manual and try going to page 28 and try wiring it up again.
http://www.lexmark.com/publications/pdfs/2007/9500/winug/en/lxdouser.pdf
Thank you for using Fix Ya!
If you still have questions, let me know.
Don;t forget to rate the overall satisfaction of this solution.
Posted on Feb 19, 2009
My fax will not send. the report says fax sent and the result is no answer
Sounds rather conflicted...any way, first step "send" a fax to a phone that rings (cell phone, phone near the fax). Make sure that the phone you are calling rings, if not plug a phone in to the fax line and make sure you have a dial tone. If you do try to change the phone line on the fax and repeat. Basicly this step is to ensure the fax is dialing out.
Next, dial the number you are faxing to with your cell phone or another phone. Does the fax machine at the other end answer (squaking noises). If not are you dialing the right number. If the fax machine at the other end does pick up, hang up and wait a few mins (so the line will clear) and try to send your fax again.
Try sending a test fax to a known good (have sent faxes to the number before with success) fax. If this works, its a communication hand shake error. You may need to power cycle both fax machines.
Last Test, plug a different fax machine in were this one is. Using the same phone line and such try to fax again. If this is the only thing that works, the fax machine may have a bad modem.
If further information on testing the modem on the HP fax is needed let me know.
I hope one of these step gives you the help and information you are looking for.
Jul 22, 2011 | HP PSC 950 All-In-One InkJet Printer
When I dial a fax number I get a busy signal even though I know that the number is not busy because I have dialed it on my outside line and it works. This has happened repeatedly. I have unplugged...
Since you mentioned that you have an outside line, do you have to use a code to dial out normally? Try plugging in a phone to the line for your fax machine, and attempt to dial the number for the other fax machine using the phone. You should reach the fax and hear a high pitched sequence of tones. This is the other fax machine trying to establish a connection. If you still get a busy signal, try calling the owner and letting them know that their fax machine is not accepting incoming calls.
Feb 22, 2010 | Brother IntelliFAX 770 Plain Paper Thermal...
Our HP Office Jet 4255 all in one suddenly won't receive faxes for some reason. It has been working fine up until now. We can send faxes, but for some reason the phone just keeps ringing and won't...
CHECK THE TELEPHONE NO.
Verify that you are dialing the number correctly. (i know its funny to ask)
Verify that you are dialing the number correctly. You must dial all of the numbers required to make a phone call from the same line. This includes numbers that must be dialed to access an outside line or to access long distance services.
TRY DIALING FROM THE FRONT PANEL
manually dial the number from the front panel of the fax.
If you have been using a speed dial or are faxing from the computer, print the page to be faxed and manually dial the number from the front panel of the fax. If the fax can be sent when dialed from the front panel, recreate the speed dial setting and insert some pauses.
Check the connections
Check the TELEPHONE LINE
Make sure that you have plugged the phone cord directly and securely into the wall jack and into the back port of the fax product. The fax port on your product is marked "Line," "To Wall Jack," or with a wall jack symbol.
Check LIU
Make sure the Line Interface Unit (box that the phone cord plugs into) is fully seated into the back of the fax product.
Remove the SPLITTER
Remove any other devices from the line such as splitters, credit card machines, or telephone answering machines.
Can try sending the Fax on Another Line
CHECK WITH DIFFERENT CABLE
Try using a different telephone cord.
Jan 05, 2010 | HP OfficeJet 4255 All-In-One InkJet...
Fax problem. Trying to send international fax to France. I can hear the fax number being dialed ok, but no connection after 12 rings. Calling fax number from phone hooked up through mp530 connects ok! ...
Hi ...
It might be possible that the line is loose or the long distance calling code is incorrect. Follow the below instructions which might resolve the problem.
Sending Using a Long Distance Calling Code The telephone company or PBX system may use long distance calling codes on a phone line as a means to manage long distance calls. This service may extend to a fax phone line and for local phone calls as well. To use a calling code for faxing, enter a pause (or pauses, as necessary) in the dialing sequence to allow time for the phone system to distinguish between the phone number and the calling code. For example, if the calling code has to be entered after the phone number, press <Redial/Pause> after the long distance number and then enter the calling code.
Here is an example of a couple of variations that may be used by the phone company / PBX system. (For details on time sequence between the long distance number and when you must enter the calling code, please contact your phone company or telecommunications specialist.)
Long distance number: 212.555.1212
Calling code: 123456
Scenario One: 12125551212p123456 Scenario Two: 123456p12125551212
Note: The above scenarios include a pause (p) in between the dialing sequence. This pause may be necessary to allow the phone system to detect each set of dialing sequences. The pause length can be adjusted from one to nine seconds, the default is two seconds.
Tips to help you send a fax using a calling code.
  1. To send a fax using a calling code, it may be necessary to add a pause(s) before the next string of dialing digits. The above example shows how a calling code is used to dial a long distance fax number. To provide time before the calling code number is dialed and avoid misdialing, a pause should be added.
    Example: 12125551212p123456
    The number of pauses will depend on the phone / PBX system.
    It is suggested to confirm if the time before the next set of digits is dialed will always be constant. This way you can always use the same number of pauses for that dialing sequence. If needed, you can also change the pause [Pause time] length from its default 2 seconds.
  2. Connect a telephone to the fax machine.
    1. Connect a line cord from the telephone wall jack to the [L] jack (or item <1>) on the fax machine.
    2. Connect a line cord from the extension telephone port on the fax machine (top jack (or item <2>)) to an external telephone.
  3. To send a fax using a calling code, it is recommended to dial using the attached telephone.
    1. Press the <FAX> button on the operator panel.
    2. Insert the documents face-up on the ADF.
    3. Pick up the handset of the attached telephone and confirm you hear a dial tone.
    4. Dial the fax destination number on the attached telephone.
    5. When you are prompted to enter your calling code, dial it on the attached phone.
    6. When you hear the remote fax machine's high-pitched receive tones, press <Color> to send a color fax or <Black> to send a black and white fax. The audio signal heard from the handset will be cut off.
    7. Hang up the handset.
    8. When the transaction is complete, the fax machine will return to standby mode.
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon PIXMA® MP530 All-In-One Printer
GESTETNER 2212 WILL FAX OUT BUT NOT IN
Make sure that the phone cord is plugged into "line" and not "phone" You can also check by pressing "on hook" button to see if you get a dial tone. Also, Call the fax number to see if the machine is trying to receive.....you should get high pitched, varying tones (hand shake is what they call it) this will let you know if the fax part is talking to phone line.
Jul 02, 2009 | Gestetner 2212 Digital Imaging System...
Faxing
Normal 0 Sending Fax Using Calling Card:
Load document in the ADF
Press [FAX]
Adjust settings for your documents as necessary
Press [Hook] Alternatively, you can lift the handset if one is connected to the machine.
Dial your calling card information responding to all calling card prompts on the fax key pad. After dialing the recipient’s number using the numeric keys or speed dialing, wait for the high-pitched fax signal.
When you hear a highpitched signal, press [Black} for black & white sending.. Hang up the handset if you used it.
Oct 18, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Panasonic KX-FL511 cannot receive faxes but can send
check to see if your phone line is plugged in the " L" or line slot on your fax machine if it is then press the speaker or monitor key and listen for dial tone. then you put a document into the feeder and dial your cell phone number and press send, when your cell phone rings answer and listen if you are getting a high pitched squeel. if you are then it should be working. try it the other way too by dialing from your cell and listen again for the squeel. if you still don't get the squeel you have a defective modem.
Thank You,
Mikey
Thank You,
Mikey
Apr 05, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Lexmark printer 8350
Okay for starters, you need to check to see if that fax machine is automatically answering the phone when it rings. you can check to see if it is trying to recieve by call that phone number from another phone and listen if it answers and when it does, does it make a high pitched squelling sound that varies in pitch.
if it does then it should be working ok, if not then you must program your recieve mode to automatically answer.
you can also check to see if it's sending by doing the opposite: put a sheet of paper in the machine to fax and dial your cell phone or other number, when it rings pick it up and listen for the high pitch squeel, if it works then your fax is working properly.
Thank You,
Mikey
Apr 04, 2008 | Office Equipment & Supplies
Won't send faxes
did you put the originals page(s) in the machine FIRST to fax, then enter the number then press start?
If you enter the phone number 1st BEFORE putting your originals in the feeder, the machine thinks you want to make a copy.
The FAX Mode is the setting for incoming faxes.
Try that and let me know if it works.
There should also be a button called "Hook" or "speaker" or something that you hit and you will hear the dial tone.
Once you hear the dial tone, you can dial the number, (make sure the pages you want to fax is in the feeder.
Once you hear the fax high pitch noise, hit the start button.
Hope this helps.
Let me know if it does and also remember to leave a feedback and rating if I have helped you.
Thanks and good luck.
Mac =)
Feb 19, 2008 | Lexmark F4270 Plain Paper Inkjet Fax
Cant send fax
Recieving faxes
  • Plug a regular, non-digital, phone into the fax's phone line and see if you get a dial tone
    • If you do not have a dial tone, seek support from your telephone service provider
  • Dial the fax number from a phone
    • Normal circumstance is that you will have the fax machine pick up and make high-pitched noises
    • If the fax does not pick up, put a regular phone on the fax line and see if the regular phone rings when dialed
      • If the phone rings, answer it and see if there is line noise
        • If the line is clear, call the service number listed on your fax
        • If the line is staticy or unclear, call your telephone service provider
      • If the phone does not ring, call your telephone service provider
Sending faxes
  • Attempt to dial the fax number you are trying to send to from another phone.
    • If you hear electronic noises on the line, the other end has a fax machine on the other end
      • Check to see if you can recieve faxes.
    • If the remote fax does not answer, the problem is on the remote side, contact the recipient
Dec 18, 2007 | Lexmark F4270 Plain Paper Inkjet Fax
Lexmark X9575 InkJet Printer Logo
69 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
