Question about Valira Isabella
I need a replacement rubber gasket for Six cup Cafetera Isabella
The 'gasket' is between the coffee and the 'percolator' section.
  • 134 Answers
You need to contact the manufacturer here
Posted on Feb 19, 2009
How to brew coffee
1.Wash the Percolator thoroughly before using for the first time.
(See "Cleaning Instructions" section in this manual.)
2.Remove Cover, Basket, Spreader and Pump Tube. Use cold, fresh
tap water to fill Percolator. Fill according to markings on inside
of Percolator for number of cups desired. Use cold tap water -
the automatic brewing cycle is timed to begin with a cold
water start.
NOTE: The bottom of the Pump Tube Spring marks the maximum
capacity of the Percolator.
3.Wet Coffee Basket to help keep small particles of coffee from sift-
ing through. Place Basket on Pump Tube. Add desired amount of
regular or percolator grind coffee to Basket.
4.Place Pump Tube with Basket into Percolator so bottom of tube is
set into Center Well. Place Spreader on top of Basket and snap
Cover onto Percolator. Attach cord to Percolator and plug into
standard household 120 volt AC wall outlet. Brewing begins
within seconds and continues at a cup-a-minute speed
5.When coffee brewing is complete, percolating will stop. The
Percolator automatically switches to "KEEP WARM" setting to
preserve fresh-tasting coffee at hot, ready-to-serve temperature.
For best flavor, remove Coffee Basket, Spreader and Pump Tube
when brewing is completed.
Aug 04, 2014 | Faberware FCP280 Coffee Maker
How hot should the coffee be in a Farberware percolator
It should be about 180 degrees. The percolator should perc about one minute for each cup of coffee. If it stops too soon and the water is not hot, then the thermostat is bad. The thermostat can be replaced.
Feb 06, 2014 | Faberware FCP280 Coffee Maker
Farberware millenium coffee percolator does not heat
There is a thermostat in the bottom of the percolator that is broken. It would normally cut in to perc the coffee and then cut off the percolator heating element after the water reaches a certain temperature. It can be replaced but it takes a little skill. There is a video on eBay.
If you want to bypass the thermostat and just unplug the percolator, time it for 1 minute per cup.
Mar 04, 2013 | Farberware Coffee Makers & Espresso...
I lost the user manual to my 30 + cup coffee percolator and I need to know the amount of grounds to use when brewing coffee!
Use approx. 1/2 cup of coffee to 10 cups of for a full pot use 1-1/2 cups... then adjust to taste..
Sep 09, 2011 | Microwave Ovens
My Moka Easy Bialetti electric espresso maker switches off before all the water has been percolated through into the upper pot. I have recently replaced the rubber seal etc. at the base of the pot.
I emailed support at Bialetti and here is what I got:
Check the coffee funnel for any dents around the edge of the funnel. Normally if this brewing problem happens after changing a gasket the problem is a dent or the funnel is out of round and the new gasket isn't formed to it like the old gasket was. Don't bang the funnel to get grounds out or it may dent or get out of round. Try pulling the funnel over to one side in the water chamber and if you see a space on one side pull it tight with the other finger to bend back into shape if possible or replace the part.
Take the gasket and filter plate out from under the upper unit and hold the filter plate up to the light to check for any clogs right in the center where the coffee brews up. You should be able to see through all the holes in the filter, brush clean if needed
Jan 13, 2011 | Bialetti Moka Easy 6-Cup Espresso Machine
Farberware 4 and 12 cup percolators stopped making good coffee
I thoroughly cleaned my 4-cup percolator by brewing a couple of pots of plain white vinegar and scrubbing the build-up from the bottom of the pot (and running a couple of plain water brews through the pot after all the cleaning). The percolator now brews hot, strong coffee again!
Nov 05, 2008 | Coffee Makers & Espresso Machines
West Bend 36 cup coffee maker amounts
It's a percolator. Use about 1 heaping teaspoon of coffee per cup. Each coffee pot is different. You will have to adjust the amount of coffee for what you like.
Dec 03, 2007 | West Bend (58036) 36-Cup Coffee Maker
Valira Isabella Logo
544 people viewed this question
Top Valira Coffee Makers & Espresso Machines Experts
Are you a Valira Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
