Question about HP ZT3380US (PF083UA#ABA) PC Notebook
Hp zt 3380 us memory replacement
I have a hp zt 3380 us and i'm trying to replace the memory. I can access the first sodium but not the second one. I tried to remove the bottom cover to no avail, how do i get to the second sodium?
    President:
  • 2,653 Answers
It's probably under the keyboard.
Posted on Feb 20, 2009
Why are pages printed on my HP LaserJet 3380 rather faint. Per haps the toner needs replacing but is there anyway to find this out. I do not want to buy another toner unless the toner does need to be...
Open the copier and remove the cartridge. Shake the cartridge back and forth, up and down for a few moments and reinstall. If copy quality improves, start saving up to buy the replacement. If it doesn't, use a credit card because you need it now.
Mar 04, 2015 | HP LaserJet 3380 All-In-One Printer
How can I change the baud rate on my HP Laserjet 3380?
There is no baud rate to this printer, it's either parallel cable or USB cable. Baud rate refers to the old serial cable connections, com1 or com2. You can add memory to this printer to make it print more documents faster. Try this location:
http://reviews.cnet.com/multifunction-devices/hp-laserjet-3380-all/4505-3181_7-30822993.html
May 11, 2010 | HP LaserJet 3380 All-In-One Printer
After replace ccd in hp 3380 ,it is showing scanning error.Pls send manual lakshmanponnuchamy@gmail.com
You can download/print your manual here:
http://www.lavc.edu/IT/Manuals/Printer_HP_Laserjet_3380_User_Guide.pdf
Dec 05, 2009 | HP LaserJet 3380 All-In-One Printer
Hp laserjet 3380 - MS Vista - scanner error, copying is ok
clear glass, replace ribbon scanner cable if no result - replace scanner
Aug 24, 2009 | HP LaserJet 3380 All-In-One Printer
HP laserjet 3380 needs fuser replaced
Unfortunately, the scanner assembly must come off. It's all screws and covers from then on.Try buying a service manual from eBay.
Mar 07, 2009 | HP LaserJet 3380 All-In-One Printer
HP laserjet 3380 ADF
It sounds like the rollers need to be cleaned in your ADF. Please make sure there isn't any torn paper or labels in the path of the ADF. Try qtips and some water to clean rollers. If you have roller cleaner that would be great or 91% alcohol but be very careful with the alcohol. DO NOT use anything below 91% because it can cause damage to the rollers. If this does not work you will need to replace the rollers in the ADF. Good luck.
Feb 12, 2008 | Office Equipment & Supplies
Installed hp laserjet 3380 on apple desktop pro - message printer stopped
See if it is the right driver. Intel Mac is not the same driver set as regular Mac.
Also, Apple + HP or Okidata often = issues.
Jan 12, 2008 | HP LaserJet 3380 All-In-One Printer
Replacing scanner assembly
Honestly it is cheaper to buy a new machine. This is a very common problem withthat model. If you are technically inclined you could try removing the top glass, (not easy) and cleaning all the mirrors as well as the scanner. Many times if the scanner cant find home (because the optics are dirty) it will give you a scanner error message. Also HP has had many issues with this model and the scanner, so you may want to try calling them and see if they will repair it under warranty.
Good luck.
John
Jan 08, 2008 | HP LaserJet 3380 All-In-One Printer
HP 3380
It needs a scanner assy.
Dec 05, 2007 | HP LaserJet 3380 All-In-One Printer
HP ZT3380US (PF083UA#ABA) PC Notebook Logo
67 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
