Question about Samsung Pleomax PKB-7000X
Hello, I have keyboard pleomax samsung corporation.Ihave windows xp professional sp2 instalattion,I can not typing on my lungage - latin serbian or croatian.Can you help me.Thanks.
  • Anonymous Mar 10, 2009
    my keyboard need a software to be instolled at first before using the divice
Hello,thank you for help.I was solved my problem with pleomax 7oo keyboard.I was installed another sw with drivers wich supported many lungages .Now is all ok.Thank you for your cooperation.Sorry for my english.Mirsad.H.
Posted on Feb 20, 2009
I need to install the driver for windows xp pleomax camera pwc 3800.
typing your product name and model number in google or your product's website followed by download
Sep 26, 2010 | Samsung Pleomax PWC 3800 Webcam
Unable to type z key
try start>all programs>assessories>assessibility> and use your on screen keyboard. if it still doesnt work it's an operating system problem
May 03, 2010 | Microsoft Windows XP Professional SP2 for...
Pleomax laser mouse doubleclick not recognised with centre button
You need to have a driver for your mouse to operate windows 7 normally. Obtain the driver from its official website. Windows 7 is new that is why there are some many hardwares are yet to be compatible for it.
Dec 23, 2009 | Samsung Pleomax SCM-9000 Mouse
Do I have Windows XP SP2 SP3?I need help please!
your game requirement says the minimum requirement is SP2 but recomemded SP3, your game still runs in SP2
Sep 18, 2009 | Microsoft Computers & Internet
I need a driver for pleomax f24
hello! salvation has arrived!
go to this link:
on top of the screen - "pc accessories" and then - "webcam"
choose : "PCW-2100 PLEO CHATCAM" on below.
download the driver and than plug in the camera. your computer should find the driver automatically.
Apr 01, 2009 | Samsung Pleomax PKB-7000X
Integrate SP2 in WinXP CD
Step 1
Create 3 folders - C:\WINXPSP2 C:\SP2 and C:\XPBOOT
Step 2
Copy the entire Windows XP CD into folder C:\WINXPSP2
Step 3
You will have to download the SP2 Update, which is 250MB.  Rename the Service Pack file to XP-SP2.EXE  Extract the Service Pack from the Run Dialog using the command:  C:\XP-SP2.EXE -U -X:C:\SP2
Step 4
Open Start/Run... and type the command:  C:\SP1106\update\update.exe -s:C:\WINXPSP1
Click OK
Folder C:\WINXPSP2contains: Windows XP SP2
How to Create a Windows XP SP1 CD Bootable
Step 1
Download  Code:  Code:
( no download manager !! )
Extract file (xpboot.bin) in to the folder C:\XPBOOT
Step 2
Start Nero - Burning Rom.  Select File > New... from the menu.  1.) Select CD-ROM (Boot)  2.) Select Image file from Source of boot image data  3.) Set Kind of emulation: to No Emulation  4.) Set Load segment of sectors (hex!): to 07C0  5.) Set Number of loaded sectors: to 4  6.) Press the Browse... button
Step 3
Select All Files (*.*) from File of type:  Locate boot.bin in the folder C:\XPBOOT
Step 4
Click ISO tab  Set File-/Directory length to ISO Level 1 (Max. of 11 = 8 + 3 chars)  Set Format to Mode 1  Set Character Set to ISO 9660  Check all Relax ISO Restrictions
Step 5
Click Label Tab  Select ISO9660 from the drop down box.  Enter the Volume Label as WB2PFRE_EN  Enter the System Identifier as WB2PFRE_EN  Enter the Volume Set as WB2PFRE_EN  Enter the Publisher as MICROSOFT CORPORATION  Enter the Data Preparer as MICROSOFT CORPORATION  Enter the Application as WB2PFRE_EN
* For Windows XP Professional OEM substitute WB2PFRE_EN with WXPOEM_EN  * For Windows XP Home OEM substitute WB2PFRE_EN with WXHOEM_EN
Step 6
Click Burn tab  Check Write  Check Finalize CD (No further writing possible!)  Set Write Method to Disk-At-Once
Press New button
Step 7
Locate the folder C:\WINXPSP2  Select everything in the folder and drag it to the ISO compilation panel.  Click the Write CD Dialog button.
Press Write
You're done.
Oct 19, 2008 | Computers & Internet
hi there my friend,
we have the hard way and then we have the easy way...
the hard way is to bootup with your bootable xp cd .follow the installation guide ..then.put in your key when you get the chance to ..and finish the installation. then apply service pack 2 to your installation .. and you're done...
the easy way would be to make a Slipstream Windows XP Service Pack 2 CD....which you can use each time you need to fix your system.
1 - Download the (full) "Network Install" of the Service Pack (English version [266 MB]), and save it to a directory (folder) on your hard drive (in my case D:\XP-SP2). Other languages can be downloaded from the Microsoft Download Web site.
Note: do not use spaces in the folder name!
2 - copy your Windows XP CD to your hard drive. Just create a folder (I used \XP-CD), and copy all the contents of your Windows XP CD in that folder.
3 - , open a Command Prompt (Start > Run > cmd), and go to the folder where you downloaded SP2 (cd \foldername). Type the command: servicepack filename /integrate:drive/path. In my example the command is WindowsXP-KB835935-SP2-ENU /integrate:D:\XP-CD.
Extract SP2 files
If you get the error:
This service pack can't be integrated error
This is caused by the fact that your Windows XP CD contains updates that will be automatically installed when you run setup. This type of CD's will usually be from larger OEM suppliers (like Dell, HP, or others).
You cannot use this type of CD to create a slipstreamed SP2 install.
First, the files will be extracted, and next they will be integrated in your Windows XP files:
Updating Windows Share
When ready, you should get a confirmation. Windows XP Service Pack 2 has now been Slipstreamed into your original Windows XP files.
Slipstream Completed
Creating a Bootable CD
For this part I used IsoBuster and Nero Burning ROM 6
After you install IsoBuster, you can choose to use only the product's free functionality for what we want to do, IsoBuster will look like the image below (you need to have your original Windows XP CD in the CD-ROM drive).
Start to extract the boot loader from the original Windows XP CD. Using IsoBuster, select the "folder" Bootable CD, and right-click Microsoft Corporation.img. From the menu choose Extract Microsoft Corporation.img, and extract it to the folder on your hard drive where you have your Windows XP files (D:\XP-CD in my case).
Extract Boot Image
Next, start Nero Burning ROM, and choose CD-ROM (Boot) in the New Compilation window. On the Boot tab, select Image file under Source of boot image data, and browse to the location of the Microsoft Corporation.img file. Also enable Expert Settings, choosing No Emulation, and changing the Number of loaded sectors to 4 (otherwise it won't boot!)
Nero Boot Settings
The ISO tab should be configured correctly as shown below:
Nero ISO Settings
If you have an older version of Nero you won't have the option Do Not Add ";1" ISO file version extention under Relax ISO Restrictions. You won't be able to boot your new CD, so update Nero!
You can configure the Label tab to your liking, I would however recommend that you keep the Volume Label the same as on your original Windows XP CD. Here are some (English) Labels:
* Windows XP Professional: WXPCCP_EN
* Windows XP Home: WXHCCP_EN
* Windows XP Professional OEM: WXPOEM_EN
* Windows XP Home OEM: WXHOEM_EN
Nero Label Settings
Next press New, and from the File Browser window, select the files and folders from your slipstreamed location (in my case D:\XP-CD). Now drag & drop the selected files in the ISO1 window.
Copy Files
Next, burn your new CD.
You now have a Bootable, Slipstreamed Windows XP Service Pack 2 CD!
Apr 28, 2008 | Computers & Internet
Samsung Pleomax Keyboard
I have same problem with my PKB-7000x keyboard. Did you find solution?
Dec 21, 2007 | Samsung Pleomax PKB-7000X
Computers & Internet Logo
425 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
