Question about Intel D865PERL Motherboard
Intel D865GBF hangs for error thermal event
I have four mother boards of Intel D865GBF which hangs often. after rebooting system generates message of thermal event occured. Please help to sort the problem at compnent level repir. I am using 2.4 GHz. 1M cache Intel P4 processor.
  • 3,267 Answers
The solution to your problem can be found at this webpage : http://www.intel.com/support/motherboards/desktop/sb/CS-012552.htm.
It guides you on how to solve overheating problems. Personally I think you need to unseat your processors and refix after cleaning and applying a fresh coat of the Heat Conducting Paste and re-seat it very, very carefully. Gently in the beginning and once u are sure that it has got into its slot smoothly then press harder until u hear two cliks, like a double lock. Fix the Heat sink &see that the retaining clips are snug tight. Try it & post the results........sodeep
Quote "High Temperature Alerts
If Intel Active Monitor or Intel Desktop Utilities alerts you about temperatures above set thresholds, there are a number of steps you can take.
Check for proper airflow:
  • Make sure the processor and chassis fans are running.
  • Check the cabling; make sure cables are not interfering with proper airflow through the chassis.
  • Check that nothing is blocking airflow into and out of the chassis' airflow vents. This is common in direct airflow systems (BTX). Chassis manufacturers may apply a dust filter in front of the CPU fan inlet. Check that the filter is clear and free of dust buildup.
  • Make sure that the air intakes for the external fans are unobstructed and are located at least several inches away from walls and other items.
  • Make sure that the power supply fan is running properly and any other external case fans are running properly.
  • Consider adding another chassis fan.
Other troubleshooting steps:
  • If your PC uses an Intel® Pentium® 4 processor in the LGA775 package, be sure the heatsink is properly installed and 'locked'. Pay particular attention to the proper orientation of the locking pins and give a good push down on the pins (sounds like a double click) to lock them into place. For complete processor and heatsink integration information, refer to Boxed Processor Installation.
  • Verify the chassis/case and power supply are appropriate for the processor model and frequency and the motherboard you are using.
  • Verify the thermal solution for the processor is adequate for the processor and frequency of the processor.
  • Make sure the processor fan cable is connected to the correct fan header (specifically for the processor). Refer to your motherboard documentation for more information.
  • Make sure that the thermal interface material or the thermal grease is applied to the processor properly.
  • Update the system BIOS to the newest version. This will often correct problems with how the system measures temperature.
Fan Control Behavior Changes after BIOS Updates
After updating to the latest BIOS version on certain Intel Desktop Boards, the CPU fan may not go to full speed operation until the processor reaches about 72°C (162°F) and all system fans go to full speed at 75°C (167°F). You may see temperature alerts in Intel Desktop Utilities.
Previously, certain processors' thermal values were not available to the BIOS so the BIOS was unable to perform the appropriate fan control (the fans ran at 100% constantly). With recent BIOS updates, the thermal values are available and the BIOS will run the appropriate fan control. This means the processor may reach temperatures of up to 75°C (167°F) before the fan will go to full speed. The fan control now allows processor temperatures to rise to optimal levels while the slower fan speeds improve acoustics.
Setting Temperature Thresholds in Intel® Active Monitor or Intel® Desktop Utilities
By default, the temperature thresholds in the hardware monitoring software are set as follows: Zone Intel® Active Monitor
Intel® Desktop Utilities (ver. 2.0.11.46 and earlier)
Intel® Desktop Utilities (ver. 2.1.8.63 and later) Processor 75°C
(167°F)
75°C
(167°F)
75°C
(167°F)
Zone 1, Zone 2, or Motherboard Zone 50°C
(122°F)
50°C
(122°F)
65°C
(149°F)
If you've checked for proper airflow and performed the other troubleshooting steps listed above and you still consistently receive high temperature alerts in any of the temperature zones:
  • If you are using Intel Active Monitor, you may increase the temperature threshold. You can safely increase the Zone 1, Zone 2 or Motherboard Zone threshold up to 60 Degrees Celsius (140 Degrees Fahrenheit).
  • If you are using Intel Desktop Utilities version 2.0.11.46 or earlier, upgrade the software to the latest version, which sets the zone default thresholds to 65°C.
  • It is not recommended that you increase the Processor Zone threshold.
Downloading these utilities:
Intel Desktop Utilities".........unquote"
Posted on Mar 28, 2009
Thermal event
YOUR COMPUTER IS TO HOT YOU HAVE TO CLEAN IT FROM DUST AND OTHER PARTICALS.USE A CAN OF COMPRESSED AIR.THE COMPUTER SHUTSDOWN FOR PROTECTION.
Nov 29, 2013 | Intel Computers & Internet
Hello, I have a Intel esys 865 gv / 775 motherboard. and win xp installed. The system hangs up after about 5 minutes after booting up. No error messages are displayed. all cooling fans are working. and...
Your system is probably hanging because of high temperature. Check cpu temperature in bios hardware monitor. If it is to high check the heatsink is fitted properly also apply thermal paste between processor and heatsink.
Mar 08, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
My mother board D865 GBS cannot accept drivers from CD only VGA drivers. Audio or LAN card drivers are ok.
Dear Asif,
Click here to download the drivers for Intel D865GBF Motherboard. (It has Intel Extreme Graphics D865)
Choose your Operating System and get the drivers
Hope this helps! Dont forget to rate the solution!!
CreativeTECH
Nov 29, 2010 | Intel D865GBF Motherboard
How to download auidio/video drivers in the intel mother board D865gbf free drivers
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%c2%ae+865+Chipset+Family+Boards&ProductProduct=Intel%c2%ae+Desktop+Board+D865GBF
Oct 14, 2010 | Intel D865GBF Motherboard
D865gbf intel motherboard sata hdd compatibility
Check with Intel ... www.intel.com/support ... look up your board, specs, and it will tell you what you can and cannot use.
May 03, 2010 | Intel D865GBF Motherboard
Lost my Intel d865gbf mother board Cd
Go to
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=948
and download the driver for your particular operating system.
Please rate this solution. Thanks.
Aug 08, 2009 | Intel Desktop Board D865GBF (MBIND865GBF)...
Will not boot,bios does not show a hard drive,only two CD drives
The peripheral devices as Hard disk and cdrom is not connected with the IDE cable or has loose contace. Even power cable of devices is not properly done or left out. So you need to check the IO IDE cable connetions and the power cable connections of the devices being connected to the mother board.
Mar 30, 2009 | Intel D865GBF Motherboard
Can some one please let me know the name of the motherboard supporting Pentium 4 1.5 Ghz processor as well as Intel Core duo series of processors. Thanks, Ajay
The chips to which you refer are incompatible with respect to the socket used for each as well as the fact that Core duo and Pentium 4 1.5 GHz chips are from separate generations, the latter having been obsolescent since 2003. Therefore, there is no single motherboard that supports both, and the Pentium 4, Socket 478 boards can be obtained from various aftermarket sources.
Here is an example of the kind of board you need for your Pentium 4.
$11 to $290 from 21 sellers
ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc 3 reviews
ATA-100, Serial ATA-150, 0 MB / 4 GB (max), DDR SDRAM, Intel 865G, 4 x USB
Prepare for the future with the Intel Desktop Board D865GBF, a platform that is truly a generation ahead. This ATX board features next-generation processor, dual-channel DDR400 memory support, integrated Intel Extreme Graphics 2, an AGP 8X slot, 8 USB 2.0 ports, integrated 6-channel audio and next-generation storage device support.
FEATURES AND BENEFITS
Support for the Intel Pentium 4 processors featuring Hyper-Threading Technology and 800-MHz system bus in the mPGA478-pin package. Also supports the Intel Pentium 4 processors (1.60a, 1.80a, 2a, 2.20 GHz or higher) with 533-MHz or 400-MHz system bus in the mPGA478 package.
Intel 865G Chipset featuring Intel Extreme Graphics 2 using Dynamic Video Memory Technology (DVMT). Low-cost, high-performance graphics solution.
Dual-Channel DDR400 SDRAM support: Four DIMM sockets designed to support up to 4 GB of DDR400 SDRAM memory (also supports DDR333 and DDR266). Flexible support for either single- or dual-channel operation.
AGP 8X/4X graphics interface: Flexibility to upgrade via a high-end AGP graphics card.
SATA150 and Ultra ATA100 connectors: Flexible support of new-generation SATA150 (2 ports) and current generation ATA (2 channels) storage devices. « less
While the board for your Core Duo is widely available now
Mar 26, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
**System randomly hangs**
Electrolytic Capacitor Failure on some Intel mobo. Products Affected:
Intelreg.gif Desktop Boards D865GBF, D875BZL, D865GLC, D845EPI, D865PERC, D865GRH, D865PERL, D845GVSR, D865PESO, D845GLVA, D865GWV, and Intelreg.gif Entry Server Board S875WP1-E.
Should replace the capacitors shown in the photo attached. 73d0b16c-0d36-4176-be42-6dd73b32fb65.jpg
Oct 24, 2008 | Intel D865GBF Motherboard
Intel D865PERL Motherboard Logo
1,155 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
