Question about Epson FX-2190 9 PIN Matrix Printer
What do you call the Black Roller in a Epson FX2190 Printer
I need a part number for this roller
    Problem Solver:
It is called the Platten Assembly. Part number 1242
Posted on May 11, 2009
Er-a320 nr100I need a ink roller for sharp
Hi. It's an Epson type printer and the ink roller code number is IR91. You can still get them from many office supply companies, or on the net.
Oct 28, 2015 | Sharp ER-A320 Cash Register
Plain paper feeds no problem but photo glossy paper wont feed! (epson 830)
Hi
This looks to be a problem with the paper pickup roller. Hence use a little thin Photo paper or replace the Pickup roller and also the Paper feed toller (Long black roller )
Jul 15, 2011 | Epson Stylus Photo 830 InkJet Printer
I have alot of jamed paper in my Epson Stylus Photo RX595 printer. I also have tore paper jamed in the printer per following the directions in the Epson manual. Please help.
ithink problem come from paper roller, maybe the paper roller is broken, or gear box of the roller is nor connect properly, contact srvice center to fix it
Dec 03, 2010 | Epson Stylus Photo RX595 Series
Printer shows worn dev unit what is this please
The dev unit (developer) is the part that the ink toner cartridge fits into, one for each colour (K-black, C-cyan, Y-yellow, M-magenta). Two things wear out on dev units, the bearings at each end of the developer roller or the roller itself. The roller is made of metal and is magnetised so a thin film of toner sticks to it, the magnet is recharged by electrical "rubbing" contacts inside the printer as the drum rotates. Gradually the contacts rub away and so the roller loses its magnetism, this will be noticed by an increasing amount of toner being spilled inside the printer. The roller bearings speak for themselves, gradually the roller will become more & more difficult to turn smoothly and so the toner will not be evenly distributed. The only way to fix this is to replace the worn dev units although cleaning the contacts will help to preserve their life.
Jul 08, 2009 | Epson Aculaser C1100 Printer
R360 wont feed paper in to printer
You need to clean the pinch roller at the back of the printer using a cleaning sheet. These come with packs of Epson Photo Paper and are slightly tacky which removes the paper dust and grime from the pinch roller.
Mar 12, 2009 | Epson Office Equipment & Supplies
Epson aculaser c1900 error code e014
Error code 014 indicates that the cooling fan on the power supply board is not operating when the printer is switched on. Does n't explain the poor print quality though. I suspect it is a worn 2nd BTR roller (the black foam coloured roller inside the rear door). To check this send a coloured print through and press hard against the rear door during printing. If the print quality improves then it is a worn roller, if it doesn't let us know and we'll try something else.
Please take a moment to rate this solution. Thanks.
Mar 10, 2009 | Epson AcuLaser C1900 Printer
Epson aculaser c900
When printing, as thepaper is being transported up the printer, try pressing the right door panel of the printer firmly with your hand. If the colours are much improved then the printer requires a new Transfer roller.
1. Open the Right Door.
2. Remove the Transfer Roller while opening the shaft holder (white color) levers found at the left and right shaft ends of the Transfer Roller to unlock it. Lift out the roller.
Jan 21, 2009 | Epson Aculaser C1100 Printer
Roller Marks
Try this to clean the rollers:
Put in blank sheets of paper in then print out from microsoft word a blank document.
This should clean the rollers. Also, there might be special cleaning sheets that you can purchase from Epson.
Oct 29, 2008 | Epson Stylus RX500 All-In-One InkJet...
Epson stylus cx3200 paper jammed
if you look down where the paper feeds there is a roller as you pulled the paper back upwards out of printer you have forced the roller the wrong way you will have to push the roller round by hand it will click and clunk till it goes back into its proper location
Aug 20, 2006 | Epson Stylus CX3200 All-In-One InkJet...
Epson FX-2190 9 PIN Matrix Printer Logo
67 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
