Question about Husqvarna Rose
Will not sew more than a few stitches.
When I sew, the thread icon comes on...it beeps three times and quits after a few stitches.  I have re-threaded it...no luck. I tried different threads..no luck. I have the Rose model. No one in town works on them. The only way it will sew is if I keep starting over...only 3-4 stitches at a time. It's useless and very irritating.
  • Anonymous Feb 23, 2009
    I have an Iris that behaves the same way. Very frustrating, I just keep pumping the foot pedal and it keeps going. My Brother 2000 from Walmart sews better, never complains about thread or anything I put to it.
I had the same problem with my Rose. I rethreaded and cleaned it many times without success. This problem is about 2 years old and caused many headaches!
Today I opened the machine with my husband's help and removed all the covers( watch out for all the sensitive clips). The problem was a small wire to the back of the upper thread tension wheel. The thread is going over it with every stitch and it got stuck on the upper side. I bended the wire and oiled the fitting. After closing the mashine works perfectly!
Posted on Jun 21, 2009
    Problem Solver:
  • 5 Answers
Remove throat plate and check under and around the bobbin case for stray thread.
Posted on Feb 27, 2009
Brand new sewing machine wont stitch. Any ideas?!?!
I'm sure you've done this, but I'll just throw this out there. Did you pull the bobbin thread through the groove that slants on the left side of the needle plate starting from the upper left corner of the bobbin cover?
Feb 24, 2015 | Singer 8763 Curvy
Machine will stitch for a few stitches and then stop and beep.
Your problem is most likely that you've run out of bobbin thread (or about to and the bobbin thread is now loose around the bobbin), your top thread is broken/about to break, or you have a birds' nest (a messy knot of thread) forming underneath the fabric/presser foot and/or within the feed dog. Upon occasion, it's a false alarm. Remove the fabric from the machine and clip your threads. If your bobbin and top thread are fine, place your fabric back in and start sewing again. If you get the stop and beep again and the threads remain unbroken, try rethreading both the top thread and the bobbin. Should you still get the alarm, hit the button to start and see if it resolves itself after a couple of tries. If it doesn't, afraid you have a problem I haven't encountered yet. But so far, the above steps have always resolved the problem for me in the last 6 years.
Mar 04, 2011 | Singer CE-100 Futura Computerized Sewing...
I bought a Husqvarna Rose at a yard sale. The lady told me she used it only a few times because the thread broke icon always pops up and she has to start over again. I tried it and sure enough it stitches...
Hi. You need to start with getting the manual for your machine. I found one at http://www.sewingpartsonline.com/instruction-book-viking-605-sewing-machine-instruction-manual.aspx.
Then, check the threading diagrams to make absolutely sure it's threaded properly. Check the troubleshooting section of the manual.
Hope this helps!
Robbie
Jul 24, 2010 | Husqvarna Rose
After a few stitches my machine quits
The problem you are having is with the sensor on the top tension unit. There is a sensor that registers the movement of the spring which lets the machine know that it's sewing. When the spring either sticks or the sensor moves out of position because of vibration, the machine "thinks" that the top thread is broken. The machine needs to be taken apart and the top tension spring checked to see if it still has enough pressure to return to it's starting position, or to see if the sensor is in it's correct position. A trip to your service tech is required
Jul 04, 2009 | Husqvarna Rose
My Futura CE-150 beeps and stops sewing after only a few stitches
Look for the buttonhole lever, just in front of the presserlever, on the lefthand side of the machine. Pull it down and push it back to the top. Good Luck
Jan 10, 2009 | Singer CE-200 Quantum Futura Computerized...
Embroidery thread breaks after about three stitches
I had the same problem....I tried cleaning it just like you did. Eventually, I changed the needle and it took care of the problem :)
Hope that helps!
Nov 30, 2008 | Singer Quantum XL-1000 Computerized Sewing...
Sewing machine either breaks thread or comes unthreaded every time i try to sew.
Your threading is not right, totally remove your thread and rethread according to the manual directions and dvd. If, you still have problems call Singer at 1-800-4singer
Sep 29, 2008 | Singer 3116 Simple
Janome Memory Craft 9500 Troubleshooting
Have you tried a new needle?
If re-threading, changing the brand of thread, etc. does not work, then it's likely your machine is out of time. Search for sewing machine timing or take it for service.
May 24, 2017 | Janome Memory Craft 9500 Computerized...
Beeps several times and stops sewing.
I had the same problem. Through trial and error, I found the problem was with the thread tension. Usually the thread became wrapped around the spool holder as it was coming off the spool. As you continue to press the pedal, tension is created. When you release the pedal, some slack develops in the threading process and you are able to sew a few more stitches before the beeping starts again. If the thread is caught on the spool holder, simple re-thread the machine.That generally works for me. Also you can try to push to spool holder in as close as possible to the spool pin to alleviate any gaps. If the beeping continues to happen, place you thread in a cup behind the machine and thread as usual. You can also purchase an inexpensive thread holder. I made one out of a wood block and other odds and ends found around the house. Good Luck!
Apr 27, 2008 | Kenmore 19233 Computerized Sewing Machine
Beep sound on Kenmore 19233 sewing machine
I had the same problem. Through trial and error, I found the problem was with the thread tension. Usually the thread became wrapped around the spool holder as it was coming off the spool. As you continue to press the pedal, tension is created. When you release the pedal, some slack develop in the threading process and you are able to sew a few more stitches before the beeping starts again.If the thread is caught on the spool holder, simple re-thread the machine.That generally works for me. If it continues to happen, place you thread in a cup behind the machine and thread as usual. You can also purchase an inexpensive thread holder. I made one out of a wood block and other odds and ends found around the house.
Nov 05, 2007 | Kenmore 19233 Computerized Sewing Machine
Sewing Machines Logo
242 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
