Question about ASUS EN7200GS/HTD/256M-256MB PCI-E DDR DVI-D TV OUT Graphics Card PCI Express Graphic Card
My1 gb ram didn't make any change even in games in my pc even those games which used to run at a particular speed earlier before the added ram are running just like thet speed even after adding 1gb more ram! what is the problem
    Scholar:
  • 53 Answers
Ok, let's explain this. RAM does not necessarily make your pc faster.
Your pc can be faster if you upgrade your CPU or graphic card(only graphic application will make you notice the increased speed in graphics).
RAM can be a bottleneck for application that need a lot of memory like photoshop when working on multiple very high resolution images or 3D cad when working on large assemblies, or VMWare.
Vista manages the RAM in such a way that you might notice a slight performance increase and less disk usage during standard desktop activities, but XP doesn't.
if you don't use very many applcations at a time and/or you don't use memory consuming applications, the added RAM is not used at all and your computer won't be any faster than it used to be.
Video memory is basically the same. you will notice a difference in performance from a large video memory(512MB-1GB-2GB) only if you game at high resolution like 1080p or higher, usually supported only by large monitors like 20" or larger.
Posted on Feb 19, 2009
  • Aenim4 Feb 23, 2009
    I explained you the problem, why are you rating me so bad? it's like if a doctor tells his patient what's the matter and the patient fires him because he is ill...it really doesn't make a point...
    You did not ask if you were going to have a faster pc installing more RAM, and I certainly did not lie to you advising you to buy a lot of RAM. Computing is no magic, it's just physics...
    Thanks a lot...
  • Aenim4 Mar 03, 2009
    thanks for re-rating me...I appreciate that.
What type of RAM is compatible for my desktop pc for increasing speed ?
Your motherboard can support up to 8 Gb of ram, of type DDR2 667 MHz or 800 MHz. In practice 667 would do I believe as the performance difference is not great in practice. The board has 2 DIMM sockets for this.
It depends somewhat on your OS and what you want to do. I'd try 4 Gb first. Bear in mind that added ram doesn't actually speed the computer as such, only a faster CPU does that, but it will allow more windows to be kept open, and cut down on data swapping to virual memory on the hard drive.
Jun 05, 2016 | Intel Computers & Internet
I recently added 2 sticks of 1 Gb Ram to my desktop, to now have a total of 4 1 Gb sticks. This newly added memory is PC2 @ 5300Mhz speed. The older 2 sticks of 1 Gb memory are PC 2 @ 6400 speed,...
It depends on what you would like the end result to be. If you need to multi-task, and have 10 windows running at once, go with the 4GB @ 5300 because while it might take a little longer your computer will still be able to handle all the information. However if you are just using it for light browsing and would prefer speed over bulk (when it comes to data processing) go with the 2 @ 6400. I don't think it would be worth it to get 2 more @ 6400, technology is advancing so fast. If you have 60 bucks you can upgrade to two 4GB @ 10600 (8GB total for $60) 1333MHz PC3. Lookup Corsair XMS3 4GB RAM.
Jul 29, 2011 | ASUS Computers & Internet
If i upgrade my 1 gb ram to 2 gb,there is a possible to increase the performance of my laptop(hp nc6230)for online games?
RAM plays a vital in overall system performance. 1GB RAM is enough for general everyday work however, gaming demands more memory as well as processing speed, graphics card performance, internet speed etc.
From the above details, it is clear that RAM is one of the factors on which the overall performance of a PC depends. Increasing RAM may NOT give significant/ notable difference, but it would surely result in some improvement. HP NC6230 has Centrino processor ( with Windows XP Operating Probably) and if you add more RAM, it means more memory would be available for the Operating System as well as applications/ online games.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 20, 2011 | HP Compaq nc6230 Notebook
My pc is very low.I need fix
Slow PC does not mean it has problem only with motherboard. Speed of the PC also depend on the following factors :
  1. Processor
  2. RAM
  3. Virtual memory
  4. Operatin system
  5. Video graphics card
To fix the problem you should first check which type of processor is used in you PC. Is it pentium4, Dual core, Core 2 duo or core 2 quad ? Core 2 quad is much faster if used with 4 GB RAM. RAM is also the cause to slow the PC. If you are using less RAM automatically your PC will be slow. So use RAM higher i.e 2 GB or more.
Virtual memory does not have much impact on speed but it is also a factor to slow down the PC. But if you can correct any of the three parts then no need to check virtual memory.
If you are using operating system like Vista then computer may be slow. Instead use XP professional, Windows 7.
If your PC doesn't have graphics card then it will be slow while playing games, watching videos. So if you are a game lover then change your graphics card with higher value such as 2 GB or more.
If you will fix these problems then you can speed up your PC
May 29, 2011 | Computers & Internet
I have cpu , intel pentium 4 3.20 GHZ with two cores and nvidia card geforce 7600 GT , 1 GB RAM , 160 GB HDD . the problem when i play games even like counter skrike or blood , or even when i play a...
this problem would indicate that the power supply that came factory with your pc cannot handle the power demands of your added video hardware. you should be able to gain access to the performance features of your video graphics card , via your instalation software. make changes that would require less power consumption. the other solution would be to buy a power supply sufficient enough to support your upgrades.
Jan 19, 2011 | E-Machines eMachines Desktop PC
Nvidia 8500 GT video card with latest drivers Trying to play Janes WWII Fighters,,game plays for about 8 minutes but then locks up any ideas why? I have used the Nvidia control panel with various...
1 GB of ram? Check the software for minimum PC system requirements.It will say how many MHz is necessary to play the game.It will also give you what video card (min),RAM(min),DirectX (7 or Higher?) this game requires MINIMUM to run.Quite often the game will run,but poorly.Your AMD 2200 runs at 1800 which isn't lightening fast,but sufficient.I think the addition of at least 1 more GB of RAM is what you need,a total of 3GB would really make the computer happy when playing games.
http://oca.microsoft.com/en/windiag.asp
Run this program from Microsoft to test your current memory for errors.
My computer is much like yours,I have XP Media-The 8600 card,a dual core 2.8 processor and 3GB of RAM.This setup will run a online racing game without hick ups at 1152 x 864 resolution.When I only had 1GB of RAM it would stutter like it was constantly trying to load the program,so I added another Gig and it started playing allot better.It couldn't keep up with Halo online until I added another 1GB for a total of 3GB.I am using a 32x version of XP,going to a 64x setup would improve performance even more.
Sorry,I'm talking too much.Try the RAM after you test what you have,you'll be glad you did!
Feb 19, 2010 | XFX NVIDIA GeForce 8500 Graphic Card
Trying to uprade
upgrade the RAM and find better processing speed of video card and using DDR3 memory
check your motherboard if capable of higher speed RAM..that will help too.
Mar 16, 2009 | E-Machines eMachines Desktop PC
RAM Memory Speed compatibility
all memory will operate at the slowest speed chip unfortunately. the only way to get the higher speed is to have all chips capeable of that particular speed.
Feb 14, 2009 | ASUS Computers & Internet
Unstable after RAM increased to 1.21 GB from .5 GB
If you have another PC, use ImgBurn or another program to burn a bootable CD (ISO) or bootable floppy (if your laptop has a floppy drive) of MemTest86+
If you don't have another PC to burn the image with, remove the newly-added RAM to get your laptop back to a stable state and create the CD or floppy disk.
(Reinstall your added RAM if you removed it earlier)
Boot your laptop with the MemTest86+ CD. Make sure the "Passes" goes to at least 2. If any errors are found they will be listed. If errors *are* found, then either your new RAM is not 100% compatible with your system, it is defective, or it is not compatible with the RAM already on your system (if your laptop has more than one slot for RAM).
Change the RAM configuration (replace the RAM, remove old RAM if your laptop has more than one RAM upgrade slot) and repeate the MemTest86+ test until you get through at least 2 passes without any errors.
Despite what people (even manufacturers) say, not all memory is created equally, and faster memory modules don't always work in place of slower ones. Likewise, you can have two memory modules that work perfectly fine in a system when they are alone, but don't work together in the same system.
Aug 13, 2008 | Toshiba Satellite M35X-S149 Notebook
Ram Sharing
there is a hardware compatibility list for all pc, chances are your pc have exceeded its maximum allowance for any upgrade, even though you have installed a higher value or capacity of RAM.
try reinstaaling once again and make sure you have the right speed allocation on your RAM , make sure that the ols RAM and the new one has the same PC___
Aug 08, 2008 | Lenovo 256MB ATI X1600 Pro VGA DVI-I...
ASUS EN7200GS/HTD/256M-256MB PCI-E DDR DVI-D TV OUT Graphics Card PCI Express Graphic Card Logo
131 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
