Question about Candy Washing Machines
CNA 166 washing machine which has failed a PAT test due to amperage being vented into other parts of the machine when it is switched on. This machine has had little use being located within a museum where it is used to wash white gloves and lab coates and was installed at the end of 2006. Many thanks, Ann Inscker Manager history & Archaeology Team Nottingham City Museums & Galleries
4 Suggested Answers
Sea Breeze
  • 4638 Answers
SOURCE: Washer is turning my white clothes gray
Oil from transmission is a good possibility. The machine is still young but sounds like you do a lot with the washer. Better have a friend that don't mind looking it over, make sure that's oil and go from there!
Posted on Feb 02, 2009
  • 512 Answers
SOURCE: water will not shut off in washing machine
Check to load size selector switch, sounds like tube came off of it. The tube goes from switch to bottom of tube, tells machine what size load and when to turn off water.
Posted on Aug 18, 2009
craig6773
  • 116 Answers
SOURCE: Hi,My daughters washing machine (Hoover Nextra HNL
You should have a drain filter. They do become clogged and need to be cleaned out. If the draine filter is clogged you will immediately know it upon removal and inspection. If this is the culprit, be sure to show your daughter how to access it, remove and clean it and then to reinstall it. This can be quite frequent (8 to 12 months) depending on her environment, like allot of pet hair and things like that. Let me know if this is the culprit. By the way, you are going to have to bail as much water out of the drum as posible unless your model has an easy water shut off just prior to the filter. Otherwise, all the water left in the drum will run out of the filter assembly when you remove it. With any luck the filter is the culprit and not the pump.
Posted on Nov 21, 2010
HansPP
  • 2510 Answers
SOURCE: hi could you please tell
Try this site for a manual for your machine:- www.pdfnmanual.com/search/candy+cna+166
Posted on Jan 23, 2011
The washer work but stop along the way,ie unable to complete the circle
see this steps and fix it. God bless you
Lid Switch Assembly
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Enter your model number to see parts for your washing machine.
Help me find my model number
Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Jul 13, 2013 | Washing Machines
Skipping wash cycle
follow this steps and fix it. God bless you
Lid Switch Assembly
Water Inlet Valve
Main Control Board
Timer
Jul 13, 2013 | Admiral 3.4 cu. ft. Top Load Washer in...
Affinity stops in the middle of a cycle a just shuts off no signal or anything?
use the following steps. God bless you
Lid Switch Assembly
Water Inlet Valve
Main Control Board
Timer
May 23, 2013 | Frigidaire ATF6000ES Front Load Washer
Washer heavy duty cycle issue
Lid Switch Assembly
Water Inlet Valve
Main Control Board
Timer
God bless youcb4af627-0171-42f5-ad0a-5f8e85e72ae0.gif6634bf88-8eca-4d0f-b59c-0e8829e5d59d.gif419f93c3-fea0-4d93-af85-2e59d98d88e0.gif
May 23, 2013 | Whirlpool AWG320 Front Load Washer / Dryer
I have a kenmore elite smartwash quietPak9. I continue to get an F11 code and a dL code. What does this mean and can it be fixed?
F11 Serial communication error
Communication between the Central Control Unit (CCU) and the
Motor Control Unit (MCU) cannot be sent correctly.
Possible causes/procedure:
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
Central Control Unit (CCU).
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic test or any
cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing the
MCU connectors.
F dl Door lock error
A Door Lock Error occurs if the door cannot be locked. It will try to lock
it six times before displaying the error code.
¦ Door lock mechanism is broken or removed from door.
¦ Door switch/lock unit failure.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door
switch/lock unit and Central Control Unit (CCU).
Your tech sheet is attached to the base panel.
Use that tech sheet as a guide for diagnostics.
Use this service manual to ID and exchange parts
Jan 21, 2011 | Kenmore Washing Machines
I have a Ultrima WF860 1600 spin hotpoint washing machine, The control panel keeps reading TEST, and it will not let me programme a wash, i tried switching it off and unplugged it. But TEST keep...
The safety switches that disable (at least) the spin cycle when the door is opened, may have failed. This is a fairly common problem.
To decide if this is a DIY project to replace or whether you need a pro, go to the Sears parts link below and enter your brand and model to see if they have an illustrated parts drawing of your machine which often helps to locate a failed part.
Sears parts dept.
If they have it in their extensive library of appliances, you can often order it as well.
Jan 11, 2011 | Hotpoint Washing Machines
Where are the fuses to the dryer thanks mm email medicalenterprise@hotmail.com
There are 2 items named as thermal fuse item #6 (307473) on heater page and #30 (306604) on the motor page There are 2 other items #11 (303396) Hi-limit on heater page and #26 (306911) operating t-stat on motor page. On electric unit when one of the thermal fuses fails or the hi-limit shorts open. It's recomended to replace all. The primary reason the thermals fail is due to vent restrictions. Inspect and test vent exhaust behind dryer and to the outside is free flowing and not crushed or excessively long. Inspect lint and blower housing for blockage.
Ric
Mar 10, 2010 | Maytag LSE7806A Top Load Stacked...
Machine was not working
Mixer has failed PAT Test due to worn main power lead .Want to know where I can buy a replacement lead near to Burton on Trent
Mixer is Kenwood Major Classic KM800
Dec 19, 2007 | Kenwood KM800 Major Classic Stand Mixer
Washing Machines Logo
53 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Kolbrun...
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
