Question about Toto Lloyd 1pc. E/F Toilet w/Maple Seat MS934304SF-01
Our toto toilet wont flush the water down. We plunged it to no avail, then we ran drain clearing baloons it wouldnt clear out. we keep removing the water with plastic pots. So we can try something else. Funny it worked fine till the plunger was used for the heck of it while cleaning the toilet. Any ideas or is it time to remove it from the floor and look inside? The toilet is a 4 week old lloyd model
    Problem Solver:
  • 11 Answers
Sounds like something is either in the bowl stuck or down in the waste line. I would probably pull the toilet and pour water down the waste line to see if it backs up or set the toilet up on something and pour water into the bowl to see if it comes out. At least it will help to find out where the problem is. Have you lost anything recently that might have fell in the toilet. Did something come off of the plunger and get stuck in the bowl?
Posted on May 25, 2009
My toto neorest 500 "burps" when I flush but the water does not go down
The problem may be in the venting of the toilet. If the vent for the toilet is plugged or in the northern climates frosted shut the air in the toilet drain has nowhere to go when displaced by the flushing water so it backs up through the toilet and causes the "burping" you mentioned. Hope this helps.
Dec 12, 2013 | Toto Home
A small leak under the toilette, the seal has been changed many times and the toilette has even been replaced. Plumber says deffective toilettes? The leak seems to only happen when or after it is...
I've installed a lot of Toto toilets and have had few leaks but, not from the one piece toilets. It might be a problem toilet but, I would be sure the drain is not blocked causing a small back up after the flush.I have seen this happen many times. The toilet can be pulled and a 5gallon bucket of water can be poured down the drain to test this before replacing the toilet. also be sure water is not spraying on the top of the tank lid and leaking down the back of the toilet.If you flush the toilet with the lid off it should be easy to see if that the problem. hope this helps.
Dec 21, 2010 | Toto ULTIMATE ROUND FRONT ONE PIECE TOILET...
My toliet is clogged and can't get the water to flush. i have plunged, empyt out the water, not sure what else to do...
sewer line is clogged get a pipe snake find the acess hole to ur sewer line outside and insert the pipe snake stick it all the way in and then go the other direction! this should clear it!
Nov 08, 2010 | Toto Promenade, 1.6 GPF, Elongated...
All of the water is draining out of my Toto toilet. When first flushed bubbles come into the toilet and the water level goes very high, then all of the water drains out gradually. What is going on? The...
The flapper valve in the bottom center of the tank is leaking and your float assy is set to high or has debris in the float diaphram. Both of the parts can be had and installed by you for around $15.00. (Available at any hardware.)
Feb 05, 2010 | Carolina Manufacturing TOTO MS884114#01...
My toto toilet has both 1.6 gal and 6 gal flushes. the short flush doesn't go down.
I am not a toto expert but i think i understand the gravity control toilet concept.A gravity flush tank type toilet flushes do to the force of water traveling from the tank to the bowl in a small passageway and forces the water in the bowl towards the integral trap in the toilet.In other words the water isnt dumping quick enough or the passageway is restricted.,My guess is the flush valve isnt dumping all at once.
Dec 01, 2009 | Toto Aquia II Dual Flush Toilet
I have a 3 bath rental. The last tenants were
With the toilet clean, try a large shop vac and see if that will unplug it , I had to do that when my son had flushed a toy and it was stuck. If that wont work you will have to pull the toilet.
Oct 24, 2009 | American Standard 2860.334 Enfield Two...
Flushes very slowly, not the "power" flush it used to do.
This type of problem is, for pretty obvious reasons, difficult to diagnose, especially when you can't interact with it. My guess is that you might actually have a blockage in your venting system. This system allows air in behind the water you are flushing to allow it to flow freely down the drain. If you have a blockage in it, the water has to pull air through the trap in the toilet, and that can lead to symptoms like the ones your describing. Are other drains in the bathroom running a little slower as well? Sometimes birds or squirels build nests in the top of vent pipes (which generally stick out of your roof) and end up blocking the air flow.
Sep 21, 2009 | Toto CST744S Two-Piece Elongated Toilet...
Toto seems to flush,but suction not working and waste not emtying
check the discharge hole, meaning you have to take down the toilet.
and make sure the water in the tank is at a proper high. you need the volume to create the wirlpool and push the waste.
May 20, 2009 | Toto MS853113S#11 UltraMax Round Toilet,...
Toto Lloyd 1pc. E/F Toilet w/Maple Seat  MS934304SF-01 Logo
437 people viewed this question
Top Toto Home Experts
Donni Steen
john h
Robert McCall
Robert McCall
Are you a Toto Home Expert? Answer questions, earn points and help others
