Question about Intel D845GLLY Motherboard
BIOS SETTINGS WHEN I TURN ON THE SYSTEM THE MESSAGE"select proper device and reeboot" is displaying.If i select harddisk as the first boot device in the bios then the operting system is loading
When I change boot device priority to CD rom first after restarting the system it changes with floppy repeatedly happening this what is the solution
Posted on Apr 26, 2009
    President:
  • 2,110 Answers
Go to BIOS setting by pressing F2 or Del while booting..and change boot priority as first boot device as hard disk then save and exit...
Posted on Feb 19, 2009
How can i boot my dell studio from cdrom so i can reinsall from external drive?
Turn on the machine, press F12 once the Dell splash screen is displayed, the boot menu will show up. From the Boot Menu, use up-down arrow keys on the keyboard and highlight the CD/DVD/CD-RW and press Enter.You will see another menu, select "Boot from Cd-Rom" and press enter to select it. The system will boot up from the CD-Rom. Please note that this settings is only for one time boot, once the system is restarted, the boot sequence will be restored to the previous saved settings. If you wish to set it from the Bios, enter the Bios settings by hitting F2 or Delete (should be shown at the bottom of the Dell splash screen) while you see the Dell Splash Screen. In the Bios settings menu, go to Boot options and make the changes with the boot sequence.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
May 21, 2011 | Computers & Internet
Booting up new motherboard
You need to re enter system setup Press Del and change boot device order to floppy, CD/DVD and Hard Disk
Worldvet
Jul 05, 2008 | ASUS P5PE-VM Motherboard
Will not reboot
did u by chance change any settings in the bios.... if yes please change the settings.... if u donno hw to chnge the bios settings... please ask me...
Jun 07, 2008 | Compaq Presario 5000 PC Desktop
My computer is displaying 'reboot and select boot device or insert boot media in selected boot device and press a key
If your computer give that message, means that you don't have a operatig system available for loading.
Your Hard Disk might not be detected or the operating system installed before was erased somehow.
Make sure that you have in BIOS the Hard Disk Drive set as Primary boot device or check if the HDD is detected in the first place. If not, make the corect setting then save your BIOS settings and reboot.
Nov 02, 2010 | Acer Aspire One PC Notebook
When turning on computer it gives me an error message saying no boot disk please insert boot disk
press f12 during start up and select your harddisk and if that doesnt solve it take out your harddisk (large plate that you can remove at bottem of laptop)
and boot your laptop switch it off put in harddisk and switch on again
Apr 20, 2010 | Acer Aspire One PC Notebook
What will i do if this message appear on the screen of my computer everytime i attempt to open it : Reboot and select proper device or insert boot media in selected boot device and press a key.
I dont know if youre are familar with bios settings, nut every time you start
the computer, you can press esc or del or something to load the bios. in the bios you can select the boot device. set it to harddisk.
Apr 19, 2010 | Microsoft Windows XP Professional for PC
Dell Dimension E520 has "NO BOOT DEVICE AVAILABLE" message. Pressing F1 F2 doesn't help. What should I do?
Shutdown the system and disconnect the power cable.Disconnect external peripherials.Hold the power button for 10 secs to drain static power.connect the power cable to the computer.turn on the computer and hit the F2 key to boot in bios.If you are in the bios turn on the caps lock,scroll lock, and numlock key.then Hold the Alt key + E, then Alt key + F, Alt key + B. Computer will restart check for hdd or boot device.If hdd is detected it should boot to desktop.If issue persist .Shut down the system.disconnect power cable.Hold power button for 10 secs.Open the tower and disconnect the hdd from the sata or ide cable.Connect hdd in a different sata or ide connector.Connect power cable and turn on the computer and follow steps 1.If still getting same error possible hdd gone bad.Good Luck.
Sep 03, 2009 | Dell Dimension 8400 PC Desktop
Will not boot,bios does not show a hard drive,only two CD drives
The peripheral devices as Hard disk and cdrom is not connected with the IDE cable or has loose contace. Even power cable of devices is not properly done or left out. So you need to check the IO IDE cable connetions and the power cable connections of the devices being connected to the mother board.
Mar 30, 2009 | Intel D865GBF Motherboard
Disk Boot Failure
you need to select ur harddisk as the first bootable device., that option is in BIOS settings. When switch on the system before loading OS press F2 to get the BIOS settings and select boot option in the menu and select your harddisk as the first bootable device. Restart the system now. If the same error is displayed your harddisk data cable may be failed or your harddisk may be corrupted...
Jul 11, 2008 | Computers & Internet
Hp pVILLION DV 1000
This error message may appear when the computer BIOS is set to boot from a network and cannot find a bootable operating system on the network or on any of the storage devices included in the notebook PC's boot path.
The following steps are for most HP Pavilion and Compaq Presario Notebook PCs. The boot order can be configured on the Advanced tab in the BIOS settings menu. The steps to modify the boot order may vary depending on the model of your computer. On most HP notebooks the boot order can be configured using the following steps:
  1. Turn on or restart the computer.
  2. While the display is blank, press the F10 key to enter the BIOS settings menu. NOTE: Some notebook PCs use the F2 or F6 key.
  3. Use the right and left arrow keys to select the Advanced tab.
  4. Use the up and down arrow keys to select Boot Order .
  5. Follow the on-screen instructions to change the boot order.
Reset the boot order to the default settings Use the following steps to reset the boot order to the default settings:
  3. Press the F9 key to reset the BIOS to default settings.
  4. Press the F10 to save the changes and exit the BIOS settings menu.
I think it will you to fix your problem.
If still have problem then tell me more about it.
Thanks
Iqbal
Mar 18, 2008 | HP Pavilion Elite M9060N PC Desktop
Intel D845GLLY Motherboard Logo
229 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
