Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
MY KINGSTONE 32 GB PEN DRIVE SAY WRITE PROTECTED HOW CAN I FORMAT IT CAUSE WHEN I FORMAT IT DIRECTLY IT SAY DEVICE IS WRITE PROTECTED. I DSNT WANT MY FILE BACK BUT I JUST NEED TO SOLVE MY PEN DRIVE PROBLEM. PLS HELP ME MY EMAIL ADD: bheart4u2007@yahoo.co.in (m) +91- 09324037724 BHARAT RATHOD
    Genius:
  • 1,550 Answers
You download the repair tool from the link below
Repair tool for write protected pendrive
Connect your pen drive to your system just open the downloaded file.
Hope this helps .
Thanks for using Fixya
Posted on Feb 19, 2009
I HAVE A 4 GB KINGSTONE DATA TRAVELER SAY WRITE PROTECTED HOW CAN I FORMAT IT CAUSE WHEN I FORMAT IT DIRECTLY IT SAY DEVICE IS WRITE PROTECTED BUT MY USB DEVICE DOES NOT HAVE THAT KIND OF SPECIFICATION TO...
Click Start
Click Run
Type CMD
Press Enter
Type CHKDSK q: /F
where 'q:' is the drive-letter assigned by Windows to your Kingston.
Press Enter.
When "check-disk" has completed, Windows will remote the "write-protect".
Nov 13, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I have a 32 GB Kingston pendrive. when I insert it to the computer it shows that "The disk cannot be written to because it is write protected. Please remove the write protection from the volume in...
Solutions:
• First of all try to locate a small switch (if any, that you may have not noticed) at some place on the drive or memory card reader. This is the prime reason for this error. If there is one, switch it to the other side to turn the protection off.
• Yes I know this problem is also occurring these days without this switch but not to worry. Just download this helpful software from here and run it to execute a "low-level format" on the drive. This software is quite handy and may take few attempts to actually remove the error.
• The problem can also be caused by some virus activity so just get it scanned by some updated good anti virus which may solve your problem.
• BUT if none of the methods listed above solves your problem then your pen drive might have gone corrupted, so just get it replaced.
Hope any of the methods listed above solves your problem.
After the low level format, you may need to "Partition the drive". Dont worry, partitioning a pen drive means allocating it its File System and Cluster Size that was lost after the Low Level Format.
For that:
  1. Run diskmgmt.msc in Run.
  2. In the disk management window, select the pen drive, right click on it and click on Format.
  3. Now choose the File System and Allocation Unit Size and do not check the boxes below.
partition_the_pen_drive.jpg Click OK and the drive will be reusable after this.
Update 2 (Better Solution):
Follow the steps in this post and just put the value 0 (zero) in step 5.
This will surely solve your problem now.
Update 3 (Solution Working):
Thanks to one of our readers Jim, who let us know about the tool called Neo 9, using which we can easily this write protection problem.
Oct 31, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I have kingston pen drive 32 gb which is write protected .what i
The write protected message appears due to many reasons detailed steps to fix the issue can be found from the following link
http://www.troublefixers.com/remove-write-protection-on-usb-pen-drive-or-memory-card-or-ipod/
May 28, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
32 Gb Kingston pen not working
Format the pen drive first, then copy the files.
Nov 16, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Pen drive shows device is write protected while formatting. So please give me solution so that I can format the Pen drive & use it again. Kingston Pen drive with 4 GB capacity. Using Windows XP...
if you see your pen drive properly you will find a lock that you need to switch to other side for unlock device
this lock make device write protected
hope it helped you
Sep 30, 2009 | Electronics - Others
My kingston 32 GB pen drive shows write protection, even formatting of pen drive is not possible, so can u suggest sumthing. Also there is no switch on pen drive.
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Aug 14, 2009 | Fuji (MAP3367NP) 36.7 GB Hard Drive
Removing write protection of USB pen drive
if u format ur pen drive. then use this step
Check out the registry under:
1)click on start button
2)clik on run dialog box
3)type regedit
4) HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
The value 'WriteProtect' should be absent or set to '0' and when you try to format it you have to format it as FAT16
Good Luck!!
Palwinder
Oct 31, 2008 | iLO (2 GB) MP3 Player
HOW TO FORMAT A WRITE PROTECT USB DRIVE
the drive isnt write protected the usbport or the connection is loose so that the computer is showing the drive as read only drive also you can format it using command and also setting off the read only attribute that may have been put by a virus also softwares like usbcillin makes pen drive writeprotected take care
Aug 26, 2008 | Transcend (TS40GSJ25) 40 GB Hard Drive
MY KINGSTON DATA TRAVELER SAY WRITE PROTECTED HOW CAN I FORMAT IT CAUSE WHEN I FORMAT IT DIRECTLY IT SAY DEVICE IS WRITE PROTECTED BUT MY USB DEVICE DOES NOT HAVE THAT KIND OF SPECIFICATION TO HAVE A WRITE PROTECT DISK.
I had same problem. I fix it with suggestion of 1st guest. I download program from site http://www.apacer.com/en/support/downloads/Repair_v2.9.1.1.zip, and program formated USB and he work fine now. TY for advice.
Jan 10, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
482 people viewed this question
Top Kingston Computers & Internet Experts
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
