Question about Linksys Ultra RangePlus Wireless Routr Router
Linksys(cisco) wrt160n router to linksys(cisco) wusb600n wireless
PLEASE HELP!!!!!!
*connection drops out every 5-10 minutes
PC Setup #1 - Dell with new Linksys WRT160n router
PC Setup #2 - Gateway with new Linksys WUSB600 wireless adapter
ok.....so the upstairs pc #1 has the Linksys wrt160n router hooked up to it and it works perfectly fine, constant connection with no interuptions....
the downstairs computer is a brand new gateway which i have the Linksys WUSB600 wireless adapter plugged into it and it connects with great status but it only allows connection for about 5-10 minutes!!! So the question is how do i set up PC #2 to stay connected without disconnection every 5-10 minutes??? Also when i reconnect to a network on the downstairs pc there is usually about 4 or 5 outside connections that i can choose from....are these other connections using my internet and could be the problem?? if so do i need to somehow setup a private network so that only the computers i chose or allow to gain access can gain access and stay connected correctly???
**Note: i can also gain perfect access and stay connected with Xbox 360 wireless, Nintendo Wii wireless and my laptop. I just dont understand why PC #2 keeps disconnecting like it does?? Is it the new computer or is it the Linksys WBUS600n wireless adapter?
  • Anonymous Apr 05, 2009
    this sucks
I have a dell now kayknoxy@aol.com
Posted on Feb 19, 2009
How to setup QoS in Cisco Linksys WRT160N for Black Ops 2?
Why don't you download the manual from the Linksys website?
Oct 14, 2013 | Cisco Linksys WRT160N ULTRA RANGEPLUS...
My linksys wusb600n willconnect to my neighbors router but not mine
Try changing the channel number in the router settings and the wusb600n.
Set them both to the same number. It should tell how in the manual, If you don't have the manual for the wusb600n.it's here: Manual.
Feb 05, 2012 | Cisco Linksys WUSB600N Adapter Wireless...
Does my WRT160N have a WPS button and if so, where is it?
The Linksys WRT160N has WPS (Wi-Fi Protected Setup). If you are using WPA-PSK encryption (recommended), then you can easily connect the C4780 to your wireless network using WPS:
1) On the Linksys router, press the WPS button that is top of the case just under the Cisco label. When the LED on the button starts to blink, then the WPS process has started.
Jul 06, 2011 | Linksys WRT160N Wireless Router
How do I get two xbox 360s to have an open NAT on a Cisco Linksys WRT160N V2 wireless router?
you need to setup both your xboxes with a static IP address for example
192.168.1.50 xbox 1 192.168.1.51 xbox 2
on your linksys router you will need to setup port forwards for both xboxes
Click the Applications & Gaming link near the top of the page.
You should now see a new menu. In this new menu, click Port Range Forward.
requires you to forward the following ports: 53,80,88,1863,3074
Mar 30, 2011 | Cisco Linksys E1000 WirelessN Broadband...
I dont have the cd to install the router
go to this website
http://homesupport.cisco.com/en-us/wireless/lbc/WRT160N
click the downloads tab
select the harware version of your router
download the setup wizard
connect the modem to the valet ( internet port )
connect the computer to the # 1 port of the valet
run the setup wizard
Sep 12, 2010 | Linksys WRT160N Wireless Router
I have a desktop and a laptop (new for xmas) and I want to set up the laptop to the wireless-N Router Model WRT160N. I am set up with internet through a bundle system through our television. Do I plug the...
first a couple of things.
if your router has wireless support your laptop (if new) should have a wireless adapter built in, so basically your destop computer can be wirely plugged into the router and your laptop shoud "connect wirelessly" to your adapter
so this is how your set up should look like
desktop
--cable-- = - cablemodem - = linksys router = ----- wire----- desktop
laptop
--cable-- = - cablemodem - = linksys router = ))wireless))) laptop
you need read up a bit, here are some links that will have info you need
manual for wireless configuration (select the proper revision for your router and check user manual)
configure wireless network for vista
read up and if you have any questions post back.
hope that helps.
Dec 26, 2009 | Computers & Internet
Can't get wireless connection from PC to Linksys WRT160N
To setup a wireless connection on a computer, the wireless card in the computer needs to be configured with the wireless router's settings.
For instructions click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Dec 11, 2009 | Linksys WRT160N Wireless Router
I get the following message when I try to open the setup on a Cisco http://192.168.1.1/ "is not available" I am trying to add a ROKU Netflix player via wireless
Follow these steps one by one and check:
1. Disconnect the Router from the Computer and connect it again.
2. Reboot/Restart the Router by turning it OFF and ON after one minute.
3. Check the connecting wire is properly connected.
4. Open the command prompt and ping 192.168.1.1
5. Try changing the connecting Wire.
6. Try to login using different Computer.
7. Reset the Router by pressing the reset button and configure it again.
NOTE: Always try to login to a Router using a Wired connection not using a Wireless connection.
Good Luck!!!!!!!!!!!!!!!
Sep 16, 2009 | Linksys WRT160N Wireless Router
Linksys Ultra RangePlus Wireless Routr Router Logo
487 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
