Question about Jandy AQUALINK RS TELELINK KIT
My hot tub won't turn off. I turn the pool on and
My hot tub won't turn off. I turn the pool on and it switches back to the hot tub. Then the heat turns on by itself. The pool/spa seem to have a mind of its own. Help!
  • Anonymous May 14, 2009
    hot tub jets will not shut off
  • Anonymous May 18, 2009
    The pump and heater keep running...I even lowered the temp to 95. It is registering 102* and the heater keeps running...it is less than a year old, so not an older model.
  • 125 Answers
Check the owners manual. I believe your are experiencing the auto set feature, default perhaps and see if there is a setting to change the auto switching. The older models used to do that all the time.
Posted on Feb 26, 2009
My hot tub doesn't heat up all the way even though it says it's ready
If a floating thermometer is more than 3-4 Degrees F off what the control panel display temperature then the temperature sensor has likely failed.
Jul 17, 2012 | Pool & Spa
Why won't my dream maker spa heat up past 95
bad temp sensor or recirculation pump overheating and turning off
Jan 16, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
Spa thermal overheating
Turn off all power to the hot tub as soon as you realize it is overheating. The spa should have an automatic shut off when the water temperature reaches about 112 degrees fahrenheit. Call your hot tub dealer or manufacturer for service options. There are a variety of conditions that could lead to the overheating of your hot tub, but may differ in various hot tub models and brands. Check the water level of the hot tub. Low water levels could be the culprit for the over heating, so you may just need to add more water to the hot tub.
Check the shut-off valves in the hot tub. If they are closed while the hot tub heater is on, it could cause the water to reach unsafe temperatures.
Clean the hot tub filter. A dirty filter could be blocking the flow of water, causing the water to sit in the hot tub and overheat.
Turn the power back on after finding the problem and talking to the hot tub dealer. The hot tub will probably not start back up until the water reaches a safe temperature
Jan 06, 2012 | Endless Summer Pool & Spa
My hot tub is not heating up is their a relay that turns the heater on or could the heater be defective the controller seams to be working
You could have a bad heating element, a bad heater fuse or a bad pressure switch.
Make sure you have water flowing (pump working and not clogged)
Check pressure switch for contenuity
Check for error codes.
Sep 11, 2010 | Qca Spas Paradise Hot Tub
I have a 2004 great lakes hot tub with a balboa controler. My hot tub heats up fine when the pump runs on high but the temp light never comes on when the pump runs in low.
check to see that the flow switch is working properly, it may not have enough flow on low speed to allow the heater to turn on. Make sure your filter/s is/are clean. If you have a pressure switch instead of a flow switch, it may need to be adjusted or replaced.
Feb 04, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
Hot tub not heating need owners manual to reset
You need to provide the exact make and model of your spa
Dec 12, 2009 | RTO 2 Person Spa Hot Tub 8 Hydrotherapy...
Hot tub has power but nothing else works
MY control panel was replaced ,it cycles but, no lights ,no jets,no heat works..What's the problem .
Oct 01, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Jandy AQUALINK RS TELELINK KIT  Logo
2,922 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Bill Jordan
Craig Butler
Craig Butler
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
