Question about CDA Microwave Ovens
Power but no heat
Unit clearly taking power, as we have LED display and turntable turns, but there's no heating taking place. What needs replacing?
If you have no power in the microwave, check to see if the outlet is good by plugging something else into it. If there is power, you may have blown the internal thermal fuse, or the door switch may be defective. Either of these will keep your microwave from working. The thermal fuse protects both you and the oven by blowing if there is too much power going through it. When a fuse blows, it means that the wire inside that conducts electricity has broken, usually because of an electrical overload. When it blows, you need to have a professional microwave repair person replace it. If this is not the problem, it may be that your door switch has become defective. If the door switch isn't working properly, it won't let the circuit complete to operate microwave components.
Posted on Feb 19, 2009
My under cabinet microwave is not working correctly.
The possible reasons are: 1) The high voltage transformer is broken, 2) The magnetron is broken.
For the 1st problem, no power can be applied to the turntable.
For the 2nd problem, the magnetron is broken with no microwave can be issued.
Jul 14, 2015 | GE Microwave Ovens
Fan failure and Intermittent heating
When the unit displays a message like "Change Filter", It's not apparent to the user how the unit knew the filter needed to be changed. On many units, it monitors the amount of time it has been cooking and after say 100 hours, decides its time to change the filter. The unit doesn't know that the filter has been changed. The filter timer must be reset. Check your owners manual to find out how that is done.
Jan 04, 2018 | Microwave Ovens
Fan failure /Intermittent heating
quite likely your microwave is trying to prevent it self from self destruct, because if the fan is not keeping the electronics components cool enough while its running the high limit thermo will disconnect power from the heating circuit, if the fan is not working it should be replaced , that's a techs job.
Feb 12, 2014 | Microwave Ovens
GE microwave not heating, sensor error.
first suspect is the inverter board (power) and magnatron a distant second----in either case the part involved unless an expensive unit is pricey.
Aug 26, 2012 | GE SpaceMaker Microwave Ovens
Tappan over range has no heat!
You have a bad high voltage diode, bad filter capacitro or a bad magnatron. The diode and capacitor does not cost very much. You can get them at . Replacement would mean removing the unit from under the counter, remove the case. Locate the diode and capacitor. They should be near the power section and the diode is attached to the chassis and one side of the filter capacitor. After replaceing both parts if the unit will not heat you would need a new magnatron. The part is fairly expensive but depending on the cost of your unit it may pay to replace it. Let me know if you need anymore help.
Thanks for using FixYa
Feb 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave MCO160UQ lite and turntable work. does not heat and power level cannot be set. (power level display toggles between "-20" and "0-10")
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
So if you need further free help, please post a
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, and your symptoms.
Jan 09, 2010 | Magic Chef Microwave Ovens
Over the last week the light on the inside of the microwave has dimmed and now it doesn't come on and the turntable doesn't work. Will replacing the light bulb correct the problem? Somehow the microwave...
I think you very possibly have a 2 part problem. Firstly, replace the lamp assembly, then replace the turntable motor. If you have a little electrical knowledge, place a tester on the turntable wires when microwave is on and check for voltage.Remember, run microwave as if you were cooking (Place water in unit when switched on).If there is power, then the motor is faulty.
Sep 25, 2009 | Bosch 500 HMB5050 Microwave Oven
Whirlpool MH1140XM: has power, but no heat, turntable not spin.
Test the high voltage capacitor, the rectifier diode.or the magnetron.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
May 11, 2009 | Whirlpool MH1140XM Microwave Oven
Microwave not heating...power going to it...turntable runs, lites heating
If you have the experience with discharging a capacitor and you have a (VOM) Volt Olm Meter. Unplug microwave, discharge capicitor, and check the resistance of the two thermal cut-off discs by removing the lead and set VOM to RX1. If you don't get a reading of zero, replace the discs. If you found any of these suggestions helpful, please rate my solution. D. Lange
Apr 26, 2009 | Microwave Ovens
I have a JVM1603BJ03 space saver micro wave. The turn table cracked in two, the plastic support device to turn the glass table has desenigrated into several small pieces. It appears the micro wave is...
Do you cook a lot of popcorn?
Do you place your food items in the center of the turntable as opposed to placing them off-center?
Both can cause repeated heating of the same spot on the turntable, which can stress it and allow it to crack.
You can buy replacement parts here.
I suggest that when you cook popcorn, place a paper plate or two upside-down under the bag and always place your food items off-center on the turntable tray.
Once you have the new parts, I would suggest at least a quick heat test. That is to heat one cup of water on high and it should boil in about 2 to 2-1/2 minutes.
If you would like to perform a more standard heat test, please see my Ask Mr. Microwave page.
If your magnetron is indeed running too hot, then it is probably dying. Sometimes - like a star - they can burn hotter right before they die.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 04, 2008 | GE Microwave Ovens
Microwave Ovens Logo
247 people viewed this question
Top CDA Microwave Ovens Experts
William Miller
William Miller
Are you a CDA Microwave Oven Expert? Answer questions, earn points and help others
