Question about RTO X-40 High Output On-Demand water heater & hot shower
No hot water to shower since new rad was added
My dad fitted a new rad and i think he drained the system.Now ihave no hot water coming out of the shower head but the mixer feels very hot.
  • 332 Answers
Take the shower head off and make sureits not clogged,, if it's not then valve has dirt in it you need to take the cartdrige out or the stem depending on the diverter and clean it out, but it does appear to be dirt, maybe solder got into the water line and came up there
Posted on Jun 06, 2009
My hot water to the shower goes cold after 3-4 mins could please help?
a couple of things to check on the side of the hot water system you will see a valve with a small lever
lift that lever until there is a solid stream of water coming from the pipe
that ensures that the heater tank is full
next -if you have a temperature mixer on the hot water pipe out of the tank ( stops scolds in the bath, shower sink) by controlling the temperature mix at the tank
They are known to fail and shut down the hot water supply by adding extra cold water into the system
other than that get a plumber in to fix the fault.
Apr 20, 2015 | Water Water Heaters
I own a salon and have 2 Rheem 60 gal 50,000BTU Gas hot water heaters. I am still running out of hot water during the work day. My question is because the hot water heaters are on the 3rd floor, it is...
I think before I spend the kind of money to get a tankless added I would get the rheems serviced . two should produce more hot water than 30 people could shower with all day
Feb 21, 2015 | Rheem Water Heaters
I have a problem with low hot water pressure can you help would an elec shower help
1) If possible, it is Best to solve pressure problem before installing new shower.
http://waterheatertimer.org/Low-hot-water-pressure.html
2) If the cold water has good pressure, then Electric shower could fix problem ... but shower would have to be connected to the cold water line and not the hot.
3) Seems the expense of adding a electric shower would be greater than having plumber fix low hot water pressure.
Assuming you have access to plumbing pipes, and this is not apartment building.
Jan 05, 2013 | Water Heaters
I have to turn the hot water tap on full open to get hot water
Type of water heater is unknown
If you have single-handled faucet the faucet cartridge might be bad.
If you have recirculation system, then check valve might be bad.
Copy following links for troubleshoot.
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Jul 16, 2012 | Water Heaters
Too much water draining from Vulcan Electric H/W relief valve.
Dear Julie. Do you have an expansion tank installed? If so it is probably waterlogged. If you come home shower etc. use lots hot water then go to bed or leave the cold water in your tank heats and expands as it heats. In the old days a toilet ballcock valve would relieve this pressure but modern toilets with diaphragm valves wont so the pt valve relieves pressure. Installing an expansion tank on the cold water line near the heater will absorb the extra water & stop the pt valve from activating.
Dec 29, 2009 | Water Heaters
I have hot water coming out of house taps but not from out of the shower, we do not have a bath tub. there seems to be no obvious leaks. HELP! what can i do i have 4 stinky kids that badly need a shower
The tap fitting on the shower may have failed. Some of the modern fittings have a more complicated internal mechanism than the traditional taps and can fail rendering the tap inoperable. Turn off the water at the mains. First take off the tap handle and then with a spanner carefully unwind the tap spindle. Be very carefull not to use excessive force in case you damage the pipework behind. If it does not come ralatively easily leave it for someone else. When you have this out have someone crack the main valve and you should have hot water coming out. If the fitting itself is the problem you may be able to take the spindle and washer out of a standard brass garden tap and use it as a temporary fix untill you get a propper replacement. Just another thought, you may have an isolation valve on the hot water line to the bathroom. Could a kid have turned it off?
Aug 30, 2009 | Rheem Tankless Hot Water Heater...
Water heater has hot water in it but cold water is still flowing
Nothing wrong with waterheater. Did you perhaps reverse hot/supply lines on new shut off valves?? try reversing lines. Maybe
Please rate. Thanks jj505
Mar 28, 2009 | Whirlpool Water Heaters
Hot Water inconsistent
Something you can do, following your fathers logic,   is to attach a hose to the drain of the tank and run water from the bottom of the tank into a drain untill all the sediment is removed (Water runs clean). This is normally done once a year as preventive maintenance  on all tank type water heaters. The logic sounds good to me.
Feb 16, 2009 | General Electric GE SmartWater Household...
Boiler overheating
the problem there a relay stuck or thermostat bring on the pump & you can lower your high limit aquastat!! also the flow valves can bypass hot hot water risers time to put in a seperate water heater domestic coil are not energy efficient !!!! aquastat high limit set @ 180f deg low limit set @ 140f deg!!!
good luck!!! tim
Oct 08, 2008 | Water Heaters
RTO X-40 High Output On-Demand water heater & hot shower Logo
119 people viewed this question
Top RTO Water Heaters Experts
Donni Steen
Mike
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
