Win XP re-starts after Turn Off computer.
System: Intel P4, 3 GHz HT, ASUS P5QL SE Mobo. 1GB RAM. Mobo is new. Did a Win XP pro repair with a student version with SP3 included. All works OK except that on the Shut Down - Turn Off command, the machime re-starts after about a second or two. The fans actually stop for a while then all starts up again. A normal re-start still works OK with the fans not stopping. Have cheched all BIOS settings and Windows power management settings. Have also sequentially and progressively unhooked case speaker, power and HDD LEDs, case fan. No change. Has anybody had the same?
  • 530 Answers
Hi im josh! may i help you? i had the same problem of yours before but it was already resolved.i found out that the power led connection was mislocated. you can found this inside the pc.on the motherboard connection to power button.two small wires there try to check. hope i helped you.good luck.
Posted on Feb 19, 2009
Hi
Well about guaranteed your 2 gigs ram is probably DDR II ram which has maximum of four gigs with 64 bit processing and 2 with 32 bit is. So motherboard needs upgrade. 35.00 for good giabit or board with 1000 megs a sec ethernet lan. With ddrIII ram. And upgrade operating system I believe win 8 has max 16 gig ram win 7 uses 8 gis vista and longhorn 64 use 4 and xp normal edition 32 bit uses 2 max. So you about have to run win 7 or 8. Win 7 will become direct x incomparable at some point making us change to win 8. Win8 cost like 300 to 350 and tiger direct.com has good deal of the win 7 pro media center for 75 bucks. So spend 150 on good speed 8 gig ram, 125 bucks for 12 core and at 4 GHz I think. And a board for 35. Reuse all other componets. And you\'ll have a 2500 dollar computer and best on the block. TigerDirect com Electronics Tablets Phones Office Supplies Video Games
May 16, 2014 | Video Game Consoles & Games
My pc keeps hanging when i install an additional ram which is 4gb my current ram is 2gb My specs is: Intel Core i3 530 2.93GHz 2GB RAM 2GB Palit GeForce GT 610 1TB HDD Windows 8 Pro 64-bit Asus...
what clock speed is $are 2gb Cards. You should use 2 2gb cards rather than 4 1GB cards. If you can boot up down load Belarc Advisor and run identify particulars. It's free.
Sep 03, 2013 | Gateway Dx4831-01e Intel Core I3-530 2.93...
My P5QL-E Mobo won't let me use my Western Digital
You have to enable AHCI in 7. Follow this:
http://www.ithinkdiff.com/how-to-enable-ahci-in-windows-7-rc-after-installation/
Dec 05, 2009 | ASUS P5QL-E Motherboard, LGA775, Intel P43...
Which intel motherboard ( model detatil) is suitable for an intel dual core 2.6 Ghz processor?also what should be the capacity of ram that may suitably mathe the intel dual core 2.6 Ghz processor?
Assuming the CPU you have is an E5300 2.6 duo 45nm then use an LGA 775 mobo.
For Win XP / Vista run at LEAST 2gb (Preferably 4GB) Ensure the mobo specs are compatible with the type of ram also.
Dec 03, 2009 | Computers & Internet
ASUS P5QL PRO memory problem
This problem occurs because of confliction between RAM memory frequency.
For that you must have 2 RAM with same memory frequency and same company chip .
Then it works fine with 2 RAM.
Let me know if you need further assistance.
Thanks.
Nov 03, 2009 | ASUS P5QL PRO Motherboard
Computer saying error loading operating system
You can configure your boot setup from your bios screen (for dell, either F11 or F12) then set up your optical drive as your 1st priority then, save settings. After that, you need to insert your windows XP cd in order for it to boot.
inform me of what happened after you have done this.
Mar 16, 2009 | Famous Brand Dell Optiplex GX280 Intel...
Computer automatically restarts after shuting down
Did you install the drivers for the motherboard already? If so check the connections from the power switch to the board which all should be on the bottom right of your mobo. I switched a + and - one time and it went into a infinite look of turning on and off = / Beyond that ASUS Customer support sucks and I would just try to RMA it and start over.
Feb 20, 2009 | ASUS P5QL-E Motherboard, LGA775, Intel P43...
Bios Utility Setup
Tell it(The BIOS set up screen) to load default settings. Start up CD driver first. Then  Save and exit. Now install Xp disk and turn computer back on. After windows loads . Run the install disk that came with *********** board.  If I missed something or is doesn't work exactly as I stated , write back and I wil assist you farther.
Feb 16, 2009 | ASUS P5QL-E Motherboard, LGA775, Intel P43...
Computer shuts off
go to the bios then check, your processor deatials
Oct 24, 2008 | Computers & Internet
Motherboard supporting both windows-98 and win-XP-pro
it would be difficult to advise you as to which board to go for, as there are many different things to take into consideration, i would look at www.ebuyer.com and choose one then do a google search for any buyers comments. The problem with Win 98 is that newer mobo,s will not have driver support for it, as with Win98 you have to continually revert back to your win98 cd to install certain files which are no longer compatible with new boards. If you wish to dual boot a system; using XP and vista would be more suitable for the type of hardware you will be using.
Jun 29, 2007 | Intel 865 S478 8X 10/100 Lan Motherboard
Computers & Internet Logo
119 people viewed this question
David Payne
David Payne
