Question about HP Pavilion dv9000z Notebook
HP doesn't do anything
My HP notebook doesn't work at all. the blue light comes on around the power cord and that's it. there are no flashing lights on at the front and pressing the power button does nothing at all. any help??
    Novelist:
  • 148 Answers
do one thing
take out the AC adapter and then take out the battery, then press hold the power button for 15 seconds and then put in the battery and try to start.
Further Queries are welcome
Posted on Feb 19, 2009
How do i fix my LCD on my laptop?
this sounds like your laptop's back light system has a loose connection, try moving the screen around, if the lights flash, it has a loose connection.
Jun 11, 2013 | HP Pavilion dv1000 Notebook
No power from my laptop .... cord has power but computer wont power up. No lights coming on computer or anything. Cord has blue light on .
Can you try to remove the battery then plug in the power cord then try to power on the computer, if it still doesn't work, call you manufacturer as you might be having a hardware issue.
The power supply may not be working on this instance.
Jul 10, 2011 | Dell Inspiron 1545 Notebook
I have an HP Pavillion dv9000 the blue lights come on for just a sec and then nothing. It will turn on periodically and works great when it on. But that is the problem it hardly ever does. Just the blue...
This could be lots of things. so lets try the easiest.
Blow out the dust in and around the fan(s)
replace the AC power cord and/or battery.
replace hard drive
and the big one replace Motherboard (which i done once in my lifetime)*
* = most likely not it.
Nov 02, 2010 | HP Pavilion dv9000z Notebook
Hi my hp 6735s laptop has just started turning itself off when knocked or moved slightly. When you try and power back up the orange light around where the power lead plugs into the laptop flashes about 10...
Check the power cord at the connector. Hp has a problem with the cords breaking internally. I had a problem with mine and found that if I played with the cord then it worked for a while. I ended up buying a new power supply.
May 26, 2010 | HP Compaq 6735s Notebook
Will not power up. Blue light around inserted AC is on.
Take out the battery and plug it in. If that does not work then the AC jack on your laptop is no good, either that or the power supply inside the computer. You mentioned the blue light, is that on the cord or on the computer?
Mar 13, 2010 | HP Pavilion dv9000z Notebook
Let the battery power down, plugged back in and now computer will not come on at all, took battery out, nothing, not even the little battery flash light, even tho power cord in and blue light around cord
Need to check the power cord to see if it is running at 19.5 fisrt. The power cord may be your whole problemand it cheaper than the other problem I see.
If power cord is ok take battery to the battery store to check it's cells. it sounds like to battery is bad. but the power cord should still bring the unit up. If the battery is ok and the power cord checks out the charging unit is bad and is costly.
Dec 07, 2009 | HP Pavilion dv9000z Notebook
HP Pavillion dv9700 won't power up
Try removing the battery and using only power cord to turn the laptop on. If that fails, try turning it on without power cord, just on battery.
If none of those work, then most probable cause of your problem is motherboard. Hopefuly you are either under manufacturer warranty or you have extended warranty with your vendor where you've purchased the laptop.
If your laptop turns on on power cord, but without battery, then battery is the problem. Also, if laptop turns on when it's only on battery but it doesn't when you plug ac cord in it, then the adapter is the problem.
Jun 01, 2009 | HP Pavilion dv9700t Notebook PC
Hp pavillion will not turn on, took battery out and put back in still not working. blue light around power cord on and blue lightening bolt flashes
Hi Iceprincess5
The three flashing lights indicate the battery is dead. Since it still wont power up with the cable plugged in I'd say the port has gone. Try wiggling the adapter about in the port to see if it begins to charge. If not then you would need to take it to a laptop repair centre to get a new dc port soldered on or buy a docking station.
May 15, 2009 | HP Pavilion dv2700t 2.5GHz Intel Core 2...
Compaq presario notebook v6128tu won't turn on
You can try to remove that battery and try to turn it on again.
Sometimes this will happen if that don't work the remove the power supply and try to turn it on.
If you see the blue light around the power input then it's obviously getting power but it's redirecting it somehow which brings us to the battery again heh.
Let me know if this does not work
Happy Holidays
Dec 27, 2008 | HP Compaq Presario V6120us Notebook
HP Pavilion dv9000z Notebook Logo
156 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
