Question about HP Refurbish LaserJet 3150 Printer (C4256A) -28971
PRINTER CANNOT PRINT,SAYS PAPER JAM
HOW DO I GET MY PRINTER PRINTING AGAIN AFTER SHOWING FAULT OF PAPER JAM?
What
asadsadsadasdasdsdsdas
Posted on Feb 19, 2009
HP LaserJet 1020 paper jam alert
Here's a video Harshit kumar suggested as a solution to your problem from YouTube:
Fixing a Paper Jam - HP LaserJet 1020 Printer
Apr 17, 2013 | HP LaserJet 1020 Printer
Keeps showing 900.57 firmware error and the paper gets stuck
Power the printer OFF and ON. Send the same file to the printer, if file has not been released from the print queue then delete all pending print jobs out of print queue.
Disconnect all data cables and power the printer OFF and ON. If the printer returns to READY, Reconnect the data cable and try printing again. If you are getting a paper jam error, please take not the error code and locate the jam. For further assistance, please contact Lexmark Technical Support.
Apr 06, 2011 | Lexmark T652DN MONO LASER PRINTER...
MY PRINTER IS SHOWING "PAPER JAM" BUT THERE IS NO
This seems to be fault in the transport of the paper in the rollers. So if you have used any adhesive sticker printing, it is possible that some glue has got clogged into the rollers. If not there can be some jammed paper in the rollers or the mechanism.
So start this work only if you are mechanically able with the right tools.
Remove the covers to get access to the mechanism . Remove the motor drive assembly , the fitting of the motor to the mechanism. Once this is removed the rollers can be turned manually so that you will be able to feed a paper to see the progress of the movement while studying if there is any obstruction or damage to the paper.
There is a in-detect sensor, usually an opto-coupler , make sure this is not clogged or dirty as this IR detection feeds the signal to the processor for starting the motor drive feed.
Reassemble but make sure the rollers are aligned to be in equal gap to feed the paper without a side pull. Now you must print and see if the fault has changed. If not repeat the above work to confirm the area of obstruction.
Nov 04, 2010 | Epson Office Equipment & Supplies
Photo printing errors
This is not the fault of printer. Choose those type of photo paper, whose thickness is equal to executive bond paper. This type of printer do not catch the thick photo quality paper
Apr 09, 2010 | HP PSC 1610 All-In-One InkJet Printer
Message shows "Paper jam" but there is no paper jam
try turning off the printer for about 10 sec. to clear its memory and turn it back on.. then print again
Oct 19, 2009 | HP Photosmart C4250 Multifunction Photo...
Paper error showing. I pulled out paper jam and none showing, yet cannot get it to print
When the Printing job initiated, the pages will print slowly and we cannot pull the paper from the printer. That will lead to the paper push becomes inactive.
Thnigs to do for rectifify the problem :
01. Please remove the toner / cartridge from the Printer..
02. Please remove the jammed sheets from the roller.
03. If any other opening available in the printer, that also can be opened.
04. Please try to pull out all loose sheets available in the printer.
05. Clean the roller with good cloth and remove all dusts from the printer.
06. Install the papers in the In Tray properly.
07. Reboot the system along with the Printer.
The above points will solve your paper jam problem in the printer.
Have a Nice day
Jul 17, 2009 | Office Equipment & Supplies
Lexmark t640: paper jam in the back door. I can see the edge of the paper. How do I release the tension on the rollers so I can slide it out? Now it is in there tight and to grab it just tears off a piece...
Hope this helps....
Explanation of the paper jam message
A 241.09 Paper Jam message indicates that the printer thinks a sheet of paper has jammed at the front of the printer. The jammed sheet of paper is most likely to be found in one of the paper trays or under the toner cartridge.
NOTE: If you select Show areas on the operator panel, you can view one or more images to help you locate and clear the jam.
Clearing the jam
To resolve the paper jam message, you must first clear the entire paper path. To access the jam area, you will need to open one or more of the paper trays. Follow the steps in the table below to help you locate and clear the jam.
Step Action Image 1 Open the printer paper tray (tray 1), and remove any jammed media you find there. pattlnk_10222007_1922-enus28872_24109paperjam1_t64x_en_us.gif 2 Open the front cover and remove the toner cartridge. Examine the area inside the printer and remove any jammed media you find there. pattlnk_10242007_159-enus28872_24109paperjam5_t64x_en_us.gif 3 If you have a duplex option installed, also remove the duplex access tray and remove any jammed media you find there. pattlnk_10302007_1559-enus28860_24x17paperjamduplex_t64x_en_us.gif 4 If you were printing from an optional paper tray, such as tray 2 or tray 3, open any optional trays, starting at the top, and remove any jammed media. Pull the print media either up or down. If it does not pull easily one way, try the other way pattlnk_10222007_1957-enus28872_24109paperjam3_t64x_en_us.gif 5 If you are printing from an optional 2000-sheet feeder, open the front door. Press the elevator button (A) to lower the tray. Remove any partially fed media from the feeder.
NOTE: Make sure the stack of print media is straight and pushed all of the way into the feeder. Incorrectly loaded paper is the most common cause of paper jams from a 2000-sheet feeder option.
For a larger image, click here. 6 Finally, reinstall all of the paper trays and press the pattlnk_10222007_2117-select_button.jpg button to try printing again.
NOTE: You may receive a different paper jam message informing you that another sheet of paper is jammed elsewhere in the printer. If this occurs, the error code will indicate the location. Click here for a diagram showing the error code locations. The paper path will vary, depending on the paper source and number of paper feed options installed.
Remove any jammed sheets of paper you find and try printing again.
Dec 12, 2008 | Lexmark T640 Laser Printer
Paper jam
don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print. showing 3e as the fault
someone replied to my problem, i tried it and its fixed 1st time, also seems to have worked for lots of others.
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving PUSH it through! and hey presto it worked for me, everything printing fine now. Let me know how you get on, from Garty
Apr 04, 2008 | Canon PIXMA MP160 All-In-One InkJet...
41 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
