Question about Lenovo ThinkPad T61 Notebook
Lenovo 3000 N500 - unable to connect to Wireless Internet
Lenovo N 3000 N500 running Windows Vista Business
I can't connect to wireless internet. The problem is almost same as below. This is what's happening so far...
Using Access Connections, I can use the wireless radio to find the network I want. It's a public wireless connection (in a library). It has signal strength of 60%. This has been more than fine for me in the past. Everyone else is using it so why can't I!?!?!
When I try to connect through Access Connections, I get the following message:
Unable to connect to the selected wireless network. You may need to configure your system to support the authentication method that is in use. Do you want to configure now?
I click Yes, (don't really know what I'm doing at this point so just OK out of that window)
Then it tries to connect. It then goes through Applying wireless settings - OK, then when it says 'waiting for association, it fails.
If I connect through networks, I can connect to the local network only, but not the internet.
What I've tried to fix it (don't even know if any of this is relevant...):
Made sure it's automatically setting IP address.
Switched off Windows Firewall
Boot in safe mode.
Checked the network adapter and it is working properly and has up to date drivers.
In Control Panel- Network connections, under Wireless Network Connections, I've disabled/enabled TCP/IPv6 and TCP/IPv4 in various combinations.
Thought I may as well let the cat have a go at fixing it after all that lot.
Run command prompt as administrator.
ipconfig /release shows: No operation can be performed on Wireless Network connection while
it has its media disconnected
ipconfig /all shows:
Host Name..............Default-PC
Primary Dns Suffix.....:
Node type..............Hybrid
IP Routing Enabled.....No
WINS Proxy Enabled.....No
Ethernet adapter Local Area Connection
Pl help asap!
  • Lenovo Master
  • 32,281 Answers
You need to get the wireless authentication details from the library's front desk to configure your wireless connection. They should be able to help you.
Posted on Feb 19, 2009
2 Suggested Answers
puertobori
  • 7733 Answers
SOURCE: Cannot get IPv4 or Ipv6 to connect
There is a great article at Working with Windows Wireless Networks
If you need more help post back! Thumbs and testimonial are welcome!
Posted on Jan 18, 2011
How to connect wifi in lenovo g575
In order to connect to a wireless network and the Internet on an IBM Lenovo machine, you must first enable wireless networking via your computer's operating system. Allow about five minutes to enable your IBM Lenovo computer's wireless capabilities.
Click the Windows logo in the bottom left of your screen. Select "Control Panel" from the menu. Click the "Network and Internet" icon in the Control Panel. Click "Network and Sharing Center." Right click "Wireless Network Connection" icon. Select "Enable." Enable Wireless via Switch Check your IBM Lenovo laptop for a wireless networking switch. It is usually on the front of the computer above the keyboard. Slide the wireless switch to the "On" position. Look for a wireless light on the front of the laptop. In some cases a light will come on to indicate that wireless networking is active. Other switches, when active, reveal a green strip of plastic.
Troubleshoot network connection problems http://windows.microsoft.com/en-US/windows-vista/Troubleshoot-network-connection-problems Lenovo support http://www-307.ibm.com/pc/support/site.wss/migr-50402.html
Apr 02, 2013 | Lenovo G575-438343u Amd E-350 1.60ghz...
I have a lenova n500 laptop. When i log in it says i need to reactivate my OS (Windows Vista). I have a Vista CD which I am trying to install. When i insert this nothing comes up. I have run out of ideas.
When Vista tells you that you need to reactivate the OS, it will give you the opportunity to do it now. You should not need to reload windows to reactivate it. All you need is a valid key (which should be on the CD or the bottom of the Laptop).
Alternatively, if you cannot connect to the internet, you can call Microsoft to activate the product.
Aug 15, 2011 | Lenovo 3000 N500 Notebook
I have a lenovo n500 laptop loaded with vista.which mouse is best the usb optical.my problem is i use at work in a wireless eviroment and at home i am on a wired connection to phone line what problems does...
What is your question?
If you are asking about a mouse, any should work.
The wireless mice typically do not use the same type of wireless that you would be using for internet, so there's no issue of interference.
May 14, 2010 | Lenovo 3000 N500 Notebook
How to download lenovo 3000 G430 laptop with wireless internet connection driver in the internet
click here
then select your operating system like xp or vista.
Then downlaod wi fi driver.
Let me know if you need more assistance.
Thanks.
Oct 05, 2009 | Lenovo 3000 Y410 Notebook
How to install the hardware drivers and set the wiresless internet access in lenovo y330 series
Broadcom Wireless Driver (Windows Vista)
http://consumersupport.lenovo.com/en/DriversDownloads/drivers_show_661.html
Broadcom Wireless Driver (Windows XP)
http://consumersupport.lenovo.com/en/DriversDownloads/drivers_show_326.html
Intel Wireless Driver (Windows Vista)
http://consumersupport.lenovo.com/en/DriversDownloads/drivers_show_310.html
Intel Wireless Driver (Windows XP)
http://consumersupport.lenovo.com/en/DriversDownloads/drivers_show_1263.html
Just download them and run the setup file to install the drivers :)
If you found this helpful , please rate my solution below
Kind Regards
1234s282
Jul 02, 2009 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
"Auto detection"
If you have wireless or wired connection you can go online and install any drivers from ibm website.
Thanks, GF
Apr 23, 2009 | Lenovo 3000 N500 Notebook
"Windows vista booting corrupt"
try to boot ur laptop with disc manager cd or win XP.
if doesnt works then try win 98 cd and delete ur C:/ partiton and install new vista
Apr 18, 2009 | Lenovo 3000 N500 Notebook
I formatted my lenovo 3000 c100 and i am missing the drivers. I don't have wireless internet
Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows XP or Vista device drivers for your model laptop,
Use this link :-
http://www.ibm.com/products/finder/us/finders?pg=ddfinder&cm_re=other-_-suprcn-_-download
Mar 27, 2009 | Lenovo 3000 C100 Notebook
Prob to get wireless internet connection of lenevo 3000 N100
Hmmm 3000 N100 comes by default with the Intel wireless 3945abg. There is a problem with the XP driver that you can grab off their website I fear, that is probably why it worked in vista, but not in xp. Had a lot of users coming to me with this issue
Try replacing your driver with this driver:
http://www.driversdown.com/drivers/Lenovo-3000-N100-Notebook-Intel-wireless-3945abg-driver-10.5.1.59-Windows-XP_79954.shtml
That one should be the most up to date driver. Please get back to me if this resolved the issue or not. If not, then tell me if you see even the available wireless networks or not at all. Does the network card show up fine in the device manager or do you got any marks on it like a red cross or a question mark?
If the solution helped, please rate me. :)
Jan 30, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Lenovo ThinkPad T61 Notebook Logo
1,830 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
