Question about Sony KP-51HW40 51" Rear Projection Television
Black & White Song Rear Projection TV
The Colour has gone in my Rear Projection TV. Its Black and White!! Im Just wondering if it can be fixed and if so how much would it cost roughly
Try unpugging from the wall for about 5 min. they say this resets the tv i tried it and my pic came back on worth a try
Posted on Feb 22, 2009
Lg 56dc1dab dlp projection tv is now in black and white? The lamp indicator has been on for a while. Is the colour gone due to further damage or can we replace the lamp and fix the colour?
lamp going out should not cause color to go out. I would check all connecting cables at both ends to be sure that is not the color issue.
Be sure you did not accidentally turn color down in trying to adjust video controls due to weak lamp. Then replace the lamp.
Jul 24, 2014 | Televison & Video
Im looking for audio output on lcd tv
Commonly the audio output of TV is on rear or side of a TV..
It is usually color white and red..It marks L/R..
Nov 16, 2011 | Sharp LC32L400M TV
Hi my problem is yellowing colour on the white but only in the middle not on outer 150mm section of screen though. also im only new to this mamoth r.p.tv so i wondered if a new bulb will fix my colour...
laurenkristy,
You have a bad color wheel. The lamp may also need replaced depending on how old the set is and the number of hours. I have a tip at http://www.fixya.com/support/r4251975-replace_dlp_light_engine which will help you replace the light engine and give the best place to get a replacement. I also have a tip at http://www.fixya.com/support/r4251975-replace_dlp_light_engine which explains when you need to replace your lamp, why and where to get the best price.
Thanks for using FixYa and for the great rating.
hardrocko
Aug 20, 2010 | Samsung HLM617W 61" Rear Projection...
Convergence Issues...
pls check convergence set on remot cantrol.
pls . menu dispaly open select convergence adjesment see on the screen croos line is 3 colour Red /BLUE /Green. set up -down and right -leaft key to move colour cross line maching with cantrel and cross line is totaly white .pictur is natruly and normal .
Oct 07, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Too much red in the screen
Hi and welcome to fixya, it is the colour wheel problem,,,,,,,,,this is common problem please check it ...it may be also cathode ray tube... thank u.........
Jun 03, 2009 | RCA P52812BL 52" Rear Projection...
Black and white dstv
look on the TV menu for (system) in south africa we use PAL, if you cant change it on the TV, with the decoder remote press menu then 7 then 4, it will ask for a pin code press 9-9-4-9 it will read "RF modulator" press OK, it will then read 1 MODULATION press ok again and it will highlight PAL I now press the right key and press OK, if this persists then the decoder it probably faulty... good luck
May 28, 2009 | Sony KP-EF61 61" Rear Projection...
My VS-50609 Big Screen tv is showing only black and white
Maybe your colour setting is wrong or worse your color tube is no good. You will have to change the screen settings (color). If it wont work probably color tube is gone.
Good Luck
Dec 12, 2008 | Mitsubishi VS-50609 50" Rear Projection...
No Colour
PAL chroma operates at 4.43 mhz and NTSC operates at 3.58 mhz. Here is a link to PAL to NTSC convertors.
http://www.world-import.com/samar.htm
Dec 31, 2007 | JVC HD-52Z575 52" Rear Projection...
JVC HD-52Z575 52 inch Cannot get a colour pic only black & white
Your HD-52Z575 will only be able to display an NTSC signal, PAL is not compatable. There is nothing that can be done to make it play a PAL signal.
Dec 18, 2007 | JVC HD-52Z575 52" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
