FixYa.com
Tags:
IBM Color Scanner Flatbed Scanner
IBM/Plustek Color Flatbed Scanner
By Perkins - usenet poster
Has anyone gotten the IBM Color Flatbed Scanner (OEM version of Plustek
4830P) parallel port scanner to work on Windows Me? Neither IBM nor
Plustek mention anything other than Windows95/98 drivers at their site but
then again I'm very surprised this device won't work on Windows Me. I've
had it ever since using it on Windows 3.1! Been thru Windows 95, Windows
98, and Windows 98SE with never a problem.
Can't imagine what changed so drastically in Windows Me to cause it to no
longer work. It's virtual device driver, scandev.386, isn't registering
with the application driver anymore. I have tried a completely clean full
Windows Me install but no luck.
Have a new computer, don't have option of going back to Windows 98 SE
without no doubt creating other problems on the preloaded WinMe OEM
configuration.
Thanx,
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 01, 2007
Thanks for Trying (70)
Bomber
Bomber - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I have a plustek optic pro4800p, which is older than yours and haven't had any
problems with it i windowsME, have you tried the latest drivers even though
they are for windows98?
also ae you installing it where you want it or where the program wants to
install? the reason being, the installation program doesn't like locations
longer than 8 characters, so if you are installing it in "c:\program
files\scanner" then it must be entered in the old DOS format ie
"c:\progra~1\scanner".
i hope this helps, they may be old scanners, but they're good
regards Doug
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Scanners problems?
Scanners
problems scanning
I have a new Photosmart C7200... Answer This...
Scanners
how to put the drain hose out...
hook up the drain hose so the... Answer This...
Scanners
Scaner
I need Draive Scasi Scaner... Answer This...
IBM IDEASCAN FLATBED SCANNER...
Hi there. I recently had 2... Answer This...
Driver for Vista Business OS...
is there a IBM Ideascan 2000... Answer This...
Repair Service
Find Scanner Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
