Question about JVC GR-X5 Mini DV Digital Camcorder
JVC GR-X5e camcorder, lens cap message. Does not show a picture.
It shows all menus, numbers and graphics on LCD, but seems like there's no picture coming through the lens. In both modes, video and still. It seems like it can not see anything as if the lens cap was on all the time.
Could this be a problem with sensor.. CCDs? Lens? Something else?
Thank You.
Oskar A.
  • 2 more comments
  • daozenbeatz Feb 19, 2009
    It shows video on tape in PLAY mode, so I think the LCD screen is fine, but in RECORD mode, its set on VIDEO and M (Manual) it just dont show any picture. Just like it would be in the complete darkness. When I zoom in, I can see noise. The grain gets bigger. It does record audio, but the picture is blank black.
    Thank You again,
    Oskar A.
    Nothing happens. Set it to M and pressed exposure twice. That just opens Gain settings for a second and lets me by rolling the wheel set the gain ... + / - but thats it.. :(
  • kinkayufilms May 11, 2009
    i have the same problem from 2 years ago. i live in central america and here no body open JVC cameras, nobody repairs it. this is a malfunction from the factory. when this problen happened to me i try to do everything but nothing works. my camera only works 8 months and then just stopped. i never gone a buy a JVC again.
    my camera now only play the minidv tape, but never record an image agian.
Posted on Aug 02, 2009
  • 423 Answers
There are a few things to check here.  First: Check to make sure your LCD screen is not turned off. Go into the video display settings and go to "on screen". There are 3 settings there. Make sure LCD is on. Second: if the LCD screen is on in the menu, make sure it's brightness setting is all the way up. Again, it's another menu item. Third: make sure you are recording video. Either connect the camcorder to a DVR or VCR with the DV cable, or connect it to a PC with a usb cable. If you see your video there, then it is recording video and maybe the screen is toast. Let me know how it goes.
Rob
Posted on Feb 19, 2009
  • Rob
    Rob Feb 19, 2009
    If you will permit, lets try something else. Have you checked the iris and exposure lock? Maybe the iris is locked almost closed.
    Set to M and press exposure twice. That should return it to automatic iris.  Let me know if that works.
I have nikon coolpix s210. when i turn on the camera, the view finder screen is black, i cannot take pictures as they come out black. though the flash and other functions work well. i can also see photos...
This problem (the screen with no picture) can be caused by a number of problems). One is that a connection with in the camera has disconnected. Another is the possibility of the LCD being bad or broken (some of these LCDs are hard to detect broken screens). Another problem could be with in the circuits has stopped working. Another could be that there is a problem with the CCD sensor. If any menus can be shown, then the problem is within the lens or sensor or something related. If you can see nothing on the screen, no matter what you pick, then the problems are harder to detect as to what is wrong.
Sep 11, 2010 | Nikon Coolpix S210 Digital Camera
The lcd screen shows stored images and menus but does not show any current images through the lens. If I try to take a picture it is totally black.
This is known problem of ccd imager chip failure in Canon A95 camera, ccd imager chip need to be replaced to get live view in camera mode to take fresh pictures.
Local camera repair shop will help you to get it fixed because ccd imager chip replacement requires expertise and soldering work.
Jul 24, 2010 | Canon PowerShot A95 Digital Camera
Describe your Panasonic PV-GS35 Mini DV Digital Camcorder Problem: When I turn the camcorder on in the video camera mode the lcd panel and th evf show black, it does not show current picture to record. All...
There was an earlier post that explained the black ribbon between the LCD viewfinder and the body of the camera is split. You would have to buy a new LCD viewfinder for about $90 or send it back to them to fix for around $250. The same thing happened to my camera and I can actually is the split. If you close it down more than half way the picture shows up. I called Panasonic and they said you have to buy the whole LCD, that you can't just buy the ribbon. They don't even have a part number for just the ribbon. Good luck.
Oct 18, 2009 | Panasonic PV-GS35 Mini DV Digital...
Black lcd screen on Ixus 70 shows icons but will not take picture
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 13, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Shooting mode shows nothing.
I just had this issue with my camera (my 15 year old son solved it for me ;-) ).
The viewfinder was active in "record" mode and the LCD was "active" because you could see a little back light but no image. The "playback" mode would let me review pictures in the LCD though so I know it is capable of showing information.
If you push the display key/button a couple of times you can see the picture move from the viewfinder to the LCD and have just a picture and or a picture and information.
So try setting the camera to "record" mode (lens comes out) and then push the "display button" which is on the back of the camera just to the right of the LCD on the lower right side several times and see if the LCD starts to work.
It could be that somehow the display button was pushed by mistake.
Bill
Dec 07, 2008 | Canon PowerShot S3 IS Digital Camera
LCD/EVF screen come on but is "snowy"
The problem is the lens is not opening, If you look into the lens you can see it is closed. This will require a trip to the repair shop.
Aug 16, 2008 | Kodak EasyShare Z650 Digital Camera
Can't take pictures or video
Lens assembly is defective in your camera. If you know about camera, open it and inspect.
Jul 31, 2008 | Sony Cyber-Shot DSC-P92 Digital Camera
No image in lcd screen
Hi:
This sounds internal and could be a bad ccd (sensor). If you call Nikon at their toll free number and ask them, it may be possible that they will fix this for free. They will let you know if it is too much to fix, in which case it will be returned to you. With Nikon you will need to pay for shipping to Nikon's repair facility.
For possible repair see this link and call the toll free number at the service center... https://www.nikondealernet.com/sal4/
Take care
Jul 15, 2008 | Nikon COOLPIX L3 Digital Camera
The camara won't show a picture on the lcd screen
Your lens is Damage. Prevent nextime from sunlight , it damage your lens if not in use.
Dec 24, 2007 | Canon PowerShot A75 Digital Camera
JVC GR-X5 Mini DV Digital Camcorder Logo
618 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
