Question about Reddy Heater RLP100 Portable Forced Air Propane Heater with Variable Heat Ouput
Pilot makes wind noise
I have a heater that will light and work fine maybe a day or two or only five min. The Pilot will sound like wind coming throught it and the flame will only be burning toward the end and then there will be no flame on the Therm-coup and the heater will shut off. What would cause something like that?
Thanks, JaY
    Problem Solver:
  • 10 Answers
Pilot dirty or to much gas pressure to pilot or problem in venting
Posted on Oct 17, 2009
I have a Pilot 2006. The A/C heater blower stoped working
sounds like maybe the built up leaves and stuff might have made the blower overheat and fail prematurely.
Apr 19, 2013 | 2006 Honda Pilot EX
What makes the flame and pilot goes out about five minutes
wind, if there is any wind getting in your flu it will blow out your pilot light
which heats the thermo coupling and keeps your gas valve open its a safety device so if pilot blows out gas valve shuts down so as not to leak gas hopes this helps
Jan 23, 2012 | Heating & Cooling
30,000 btu wall mount reddy heater nat. gas. pilot lights and heater will run for about a min. then i hear a click in the main control and everything shuts down. Is this the double safety i read about...
Yes your pilot light may not be surrounding the thermocouple. Check and see it the pilot is burning blue and surrounds the thermocouple . These units are very sensitive if even a little breeze across the unit. You can clean the pilot with compressed air or maybe even a small wire brush. If this doesn't work you may have to change the thermocouple.
Apr 21, 2011 | Heating & Cooling
Have a Reddy Heater RCP275 propane gas heater. If able to light - the heater will burn for 1-5 min. but then goes out. Sometimes burner will not light at all when the red pilot button is released. At times...
Sounds like the igniter needs to be replaced. It is normal for a heater to run five or so minutes that means the thermostat is working. then restart when the temp calls for heat but if the igniter does not work it will not light up again.
Jul 27, 2017 | Heating & Cooling
Pilot lit clicking noise no burner
make sure knob on gas valve(inside heater)is turned to on position.3/4" should be fine as long as heater is not larger than than 175,000 btu
Jul 14, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Pilot light out?
It fixed itself and worked fine the next day.
Thanks.
May 26, 2008 | Amana ARGS7650SS Gas Kitchen Range
Heating & Cooling Logo
165 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
