Question about EliteGroup L7VMM2 Motherboard
PLEASE SOMEBODY HELP ME!!!
"intel cpu uCode loading error
press delete to reconfigure your setup
chassis intruded!
fatal error... system halted!"
this shows up fter i restarted my pc,, i have no idea wat happen,, pls. help me!!!
  • 530 Answers
Hi im josh of cbu phils. may i help you. the problem of your pc is hardware maybe there is a part there being loosen like memory or RAM try to tighten the memory or clean the memory bank that is the most common problem. second your hardisk tighten the ide cable and the last is your power supply do the same. good luck!
Posted on Feb 19, 2009
(1)cpu fan error (2)chassis intruded (3)fatal error.....system halted
The reason for this error is Overheat! Please replace the CPU Fan with a new one and add additional Fan for the CPU Cabinet in order to cool the CPU. Then, reset the BIOS to default value by pressing the F2 Key or Delete Key at the Startup and select Load Optmized Defaults or Load Fail Safe Defaults option. This should resolve the issue.
Mar 02, 2011 | Computers & Internet
How to fixed chassis intruded fatal error system halted
Good day! here's the following steps hope it will help you.
Unplug the computer
Take the MOBO battery out
Remove the chassis jumper
Wait a few minutes
Replace the chassis jumper
Replace the MOBO battery
Plug the computer in
Jul 24, 2010 | ASUS P5V800-MX Motherboard
Chassis intruded... fatal error.. system halt..
If your case is not setup for chassis intrusion, the motherboard has dropped a jumper.
The location is by the last PCI slot between the CD audio connector and the USB bus plug. (it is right next to the CLRTC jumpers)
Good luck
Jul 21, 2010 | ASUS P5KPL-AM SE Motherboard
Chassi Intruded" then "Fatal Error...System Halted" asus pvc5mx
okae...
first should you do is.. buy a new motherboard.. because like my motherboard, there is no solutions for that error nd problem...tnx
Dec 17, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
Chassis intruded ? fatal error... system halted in asus p5sd2-vm mother board
first you have to check the RAM,, then mother board or processor,, ,,, make sure the pc while booting memory check is going with out problem..s
Sep 29, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
Chassis Intruded, Fatal Error...System Halted
you need to go into the bios of your pc.....usually pressing the delete key when you see the first logo screen after booting up....look for a section that relates to errors and what the bios is supposed to do when it encounters an error.
i.e if you see a line in the bios that says "halt on all errors" disable it and when you next boot up the bios will not stall.
Mar 20, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
Chassis Intruded, Fatal Error.....System Halted
I'm not familiar with that particulat model, but I'd guess the motherboard has a chassis switch connector, and senses the chassis be open. Could be because: - chassis open (close it), - switch defect (as a workaround, you could short-circuit it, or just unplug it - whichever solution works for you). As another workaround, you can probably disable this switch in BIOS.
Pc halted
very simple shut down computer put side panel back on and restart go into bios and under the settings somewhere you will see enable chassis intrusion. Just disable that. If you put cover back on then proceeded by turning power on and you still get this error than it is time to clear CMOS and then you must go into the bios and hit setup default and then go into any timings and voltage settings for CPU Memory and such. and also disable the chassis intrusion. You can enable it at anytime. just as long it is not powered up when removing side panel. I hope this is helpful.
Feb 22, 2009 | ASUS P4P800-E DELUXE ULTRA ATA133...
Intel uCODE loading error
problem for all ASUS PC Desktops Intel uCODE loading error button1-share.gif
May 18, 2008 | ASUS Computers & Internet
EliteGroup L7VMM2 Motherboard Logo
204 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
