Question about Canon CLC 1150 Color Copier
Canon clc3200 error code E000020-03b0
My canon clc 3200 has error code E000020-03b0 for copy or print work
can i help me?
5 Suggested Answers
57 varieties
  • 1653 Answers
SOURCE: Error code E000020-03b0
This means that you need to replace the Cyan Drum.
Posted on Oct 13, 2009
Testimonial: "This is exactly what the problem was. Cyan drum replaced by service tech. Thank you"
  • 287 Answers
SOURCE: Error code E000020-0181
Hello Brass, This error code means that the yellow drum/developer unit has failed. Your machine has 4 drums, cyan,magenta,yellow and black. At best they are good for about 40,000 copies. You can order one online and it is fairly simple to replace. Let me know if I can help further.
Posted on Jan 05, 2008
  • 22 Answers
SOURCE: Error code: E000020-03b0
Replace the Cyan Drum !!!!!
Posted on May 07, 2009
  • 270 Answers
This is the error code indicating a problem with the Cyan drum - drum is coming to an end. The 020 is for the drum or developer. The 03 is for cyan and the BO is for drum life. Chang ethe drum out and all should be good.
Posted on Sep 15, 2011
Canon ClC 3200 , ERROR CODE E-000602-FF13 , HOW CAN I FIX IT ?
program u r hdd or go to service moode press copier , function . system and press hdd check select this one & press ok it is starting from 100% & it will be cuming to be 0% or ok.
May 04, 2011 | Canon CLC 1120 Color Copier
Canon CLC 3200 error 000002-0102
This is mainly caused by Power Problem in cannon 3200, Change the complete fuser assembly as one of the thermistors has gone open circuit, just by ordering up the single parts costs the same as buying the complete thing. Also, if required, reset the code *28* function.
good luck, feel free to get more assistance, do rate the solution if got help.
Dec 09, 2010 | Office Equipment & Supplies
Ive attached the finisher unit to the canon clc3200 how do i set
do you have correct finisher? On these macine you can have two finishers atached. FinisherM-1 and FINISHER N1/Saddle finisher N2.
Is these hapend on installation of new finisher or it worked before?
Check that wright slot for connection is connected.
If you want service manual for finisher send me mail on
Jul 12, 2010 | Canon CLC 1150 Color Copier
Do you recommend Canon ClC 1180 for business
Depends on what you want to do with the copier. This a graphic's machine if you require high quality photo type output this is a perfect machine. It's not fast and will not run heavy stocks. It performs best with Hammermill color laser paper. If optioned with the Fiery Print Controller it will produce great print from photoshop and other graphics programs.
The CLC-1180 is Service intensive and will require frequent service calls and I highly recommend you have a service contract.
If you just require general office color such as Powerpoint , Word and don't require photo quality output, I would recommend the ImageRunner C-3200, ImageRunner C-3380 or ImageRunner 5180. These machines require less service and cost less per copy to operate.
Feb 19, 2010 | Canon CLC 1180 Copier
CLC 1110 E71?0007, E071?0002, E072 error codes.
On my CLC 1150 copier machine, I have an error code E071 – 0002.
Sir plz send soluation this error
Dec 12, 2008 | Canon CLC 1110 Copier
Do you have a CLC1150 or a CLC3200. If you have a 3200 you have to open the front door and go to the low toner color and unlock the lever and remove the toner cartridge and then open the new toner box and remove the orange tabs and install the new toner cart ridge and lock the lever and close the front door. You may have to wait till the copier catch's up with replenishing the toner and you are done. If you have a 1150 you have to open both front doors and on the left side of the hopper there is a black release lever, that will allow you to pull the hopper out to open the correct toner that is low. Opent the door and install the new toner bottle and remove the emptied toner bottle and push the hopper back into place and close the front doors. Good Luck
Nov 28, 2008 | Canon CLC 1150 Color Copier
Error code E000001-0003 on Canon CLC 3200
E001 on a canon is a fuser problem. check to see if the fuseer lamps come on, if yes then the problem is a Thermistor (controls the temperature of the rollers) change.
Jul 16, 2008 | Office Equipment & Supplies
ERROR CODE E020-02D0 on Canon CLC4000
you need a full developer change . do you know how to do that
May 15, 2008 | Canon CLC 4000 Copier
Canon CLC 1150 Color Copier Logo
598 people viewed this question
old marine
old marine
