Question about Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television
Wanting new screen for projection tv as scatched old one
Panasonic tx43p400h
Repairman fixed it
Posted on Feb 21, 2009
Panasonic rear-projection tv with no picture
sounds like a high voltage problem (flyback transformer) best thing to do is have a tech look into it, can be dangerous. Julio milleniumtvsvc@gmail.com
Jul 16, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX42F outer most screen cracked
Look for a used Panasonic PT-47WX42F One in Local ads, Or place a wanted ad for your model. ~ Or if you want A new one, Get ahold of a TV Shop And OR Panasonic and be ready to spend lots of $$$$ ~ And yes there easy to replace!, Make sure you have a large clean area to work in, And a helper. Becarful and replace them back in as they came out! ( Top Bottom) they should be marked with a small tag or mark.... Geo*
Jul 06, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic dlp new bulb clean filter error message reset info not
For the Air Filter message, the filters are located inside the unit, if already cleaned, perform a reset of the unit, Press Hold, VOL - on set and TV/Video on remote for about 5 sec. If a Lamp timer reset message, try VOL - on the set and Mute, Move or PIP on the remote (try all three)
Mar 29, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic 36 inch flat screen tv 6 years old (model unknown) just stopped turning on. Act as if it is unplugged. Could it just be the fuse? If so, where is it located and how do i replace?
Fuse sounds right.  Had a Toshiba 32" that did the same thing.  Had to have a repair man come out.  $150 charge all told.  Worth it, because a new TV would be a lot more.  Unless you are some kind of electronics wizard, you don't want to take that thing apart.  They are very delicate-looking inside (and really cheap-looking, actually!).
Nov 15, 2008 | Panasonic Televison & Video
Panasonic projuction screen tv.
3 blinks is the error code for the convergence ICs. You need to replace both STK392-110 convergence ICs. You can get replacement ICs at the following link and they provide installation instructions with pictures.
http://servicemanuals.vstore.ca/
Oct 12, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Screens
IF YOU WANT A NEW SCREEN CALL DIRECT TO THE COMPANY 1-800-332-5368 IF YOU WANT A USED ONE, CALL TO THE TV SHOP AND ASK FOR A USED SCREEN IN GOOD CONDITIONS.
Dec 24, 2007 | Panasonic PT-47WX49 47" Rear Projection...
PT 44 LCX 65 Panasonic Red spot upper rt quadrant of screen
This is a FIRMWARE problem. do not let someone replace any parts in your TV.
I had a repair guy come out with a small computer and he took the back off of my tv, plugged in the computer and the red dot slowly began to disappear.
this was in March 08, no problems since
Dec 18, 2007 | Panasonic PT-45LC12 45" Rear Projection...
Protective screen
I replaced the screen on my 62 inch big screen for about $50 and the picture is very good! You simply need to purchase a piece of plexiglass from a glass shop or hardware store and have it cut to the EXACT dimensions you require for your TV2.gif. NEXT the plexiglass must be FROSTED. This can be done by a fine particle sandblaster or power sander with a fine grade paper. I used a power sander and sanded BOTH sides methodically and vertically on BOTH sides. I recommend buying a couple of 12 inch wide strips to test which method pleases you most by placing them in the path of the projected image where the old screen was removed. In any event, I recommend frosting BOTH sides.
Nov 01, 2007 | Hitachi 51F510 51" Rear Projection...
TV fell from 4 feet
try partstore.com vancebaldwin.com tritronicinc.com you will need your model number for each site Good luck
Sep 02, 2007 | Zenith E44W46LCD 44" Rear Projection...
Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
