Question about Sony VAIO VGP-BMS33/B
My Bluetooth laser mouse VGP-BMS33 stopped working. Green light is on. I tried to push the connect button until the green light started to blink but the computer still can not find it. Help me pls
  • 2 more comments
  • saurabhpur Feb 27, 2009
    I'm also having the same problem
  • Anonymous Apr 18, 2009
    same problem.
  • lisa_11 May 12, 2009
    same here
  • Anonymous May 20, 2009
    Same problem here, can anyone assist?
You may be really understand what I say since of my poor english but I solved same problem with my Sony VGP-BMS33.
1. go to control panel,
2. go to system management tools,
3. go to computer management,
4. go to serivces and applications,
5. go to serivces
6. find bluetooth support serivce,
7. right click then choice detail,
8. go into log-in,
9. change from "this account" to "log-in local account" then ok,
10. system will ask you stop then yes,
11. restart this service,
12. back to your bluetooth device and find your sony mouse and setup as usual,
13. done
Posted on Jun 20, 2009
There is an easy solution to this problem if you had made a Recovery Disc upon first receiving your computer. If you have a Recovery Disc, go ahead and pull it out and put it into the disc drive. If it does not automatically start up and instead a dialogue box appears, choose to autorun. 1) A dialogue box will appear giving you the options to either Reinstall programs or drivers or Restore your complete system. Hit OK to choose to Reinstall programs or drivers. 2) Let it load up and do its thing... 2) Once its done loading up, choose Reinstall Programs or Drivers from the list on the left of the window, then click the Start button in the bottom right. 3) Now choose to Skip (near the bottom) instead of doing Windows Backup and Restore or VAIO Hardware Diagnostics, then click the Next button. 4) A Caution will appear. You may choose to read it, but otherwise just hit the Next button again. 5) A list will appear with two tabs: Programs and Drivers. Click the Drivers tab and locate the Bluetooth Driver in the list. Check off the Bluetooth Driver box and hit Next. Follow any dialogues that pop up, and once all that's over with you will be prompted to restart your computer. 6) After the restart, remove your old Bluetooth mouse and re-add it, and it should work like a charm. Good luck, and I hope this helped at least someone out!
Posted on Aug 13, 2009
Pairing code of Sonay Vaio VGP-BMS21?
Try this
> (Go To) Control Panel > Bluetooth Devices
If your device is already there
Highlight device then in menu bar select Remove Wireless devise
Click on Yes
When device removed or if it was not there in the first place
> Add Wireless Device
When computer finds your device select it
Click on Next
Choose Pair without CODE
Click on Next.
Computer should then install drivers
This works with my Sony VGP-BMS33
Jun 06, 2014 | Sony VAIO VGP-BMS33/B
Laser mouse
NOTE: This mouse never came with any software in the first place.
To get the mouse to work again proceed as follows:
Open Control Panel > Bluetooth Devices>Select VPG-BMS33 >Bluetooth Settings>Options> place a tick in the "Allow Bluetooth devices to find this computer">Apply>OK then close the open window.
The mouse should now work.
If this does not fix the problem then try this:
Go to Control Panel click on Bluetooth devices. Select VGP-BM133 (your mouse) then select Remove Wireless Device. After it has been removed NOW Select Add Wireless Device ( your computer will search for the mouse) When it finds it and it appears in the window, select it and then select Next. The computer will load the drivers for it and after you close the window the mouse should work.
Note often when my mouse has stopped working it has been because the batteries were flat and all the above fixes would be to no avail.
Nov 09, 2013 | Sony VAIO VGP-BMS33/B
Sony VGP-BMS33 mouse doesn't move cursor
the laser could be faulty i would take it back to where you got it fro and get it replaced.
Jun 30, 2010 | Sony VAIO VGP-BMS33/B
Sony vaio bluetooth mouse VGP- N50 doesnt appear to like to connect to apple mac any ideas why
Try going to the Sony site an downloading the appropriate drive package......
Apr 17, 2010 | Sony VAIO® VGP-BMS33/S Mouse
Vgp-bms33 laser mouse stops working at times might start back working again later but not all the time. i checked battery level and tryed new battery's still not working. it is working fine right now so...
To conserve your batteries, most of these mouse types have a "sleep mode". If it has, you need to press the scroll wheel or a side button to wake it up after being idle for a short time. Make sure your bluetooth receiver is not obscured by anything and perhaps re-pair it again to realign the frequency.
Apr 08, 2010 | Sony VAIO VGP-BMS33/B
Connection
Check the connection of mouse is properly connected to the back of C.P.U in mouse slot.
You can solve the problem.
Thanks.
Mar 02, 2010 | Sony VAIO® VGP-BMS33/S Mouse
I have just upgraded from vista to windows 7 and my sony vgp-bms33 laser mouse does not work. The system shws it as there, but the cursor does not work
Simples.....The led may showing as there is power, but charge.change for new/recharged.
If no result, suggest you reinstall micky prog or access sony to see if your micky prog has update for win7?
Nov 14, 2009 | Sony VAIO VGP-BMS33/B
Bluetooth mouse VGP-BMS33
Turn the mouse off. While holding down the connect button, turn it on. Keep holding the connect button untill the green light starts to blink. Now try searching for the mouse.
Sep 06, 2008 | Sony VAIO VGP-BMS33/B
Sony VAIO  VGP-BMS33/B Logo
2,498 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
