Question about Linksys WRT150N Wireless N Router - 300Mbps, 802.11n , 4-Port
My internet icutting out unless i plug power adapter from router
Wrt150n wireless-n router is cutting out unless i plug out power adapter and plug in from router ,then it work after short time it cutting again and i have to plup out and in power again.....my internet gateway is working good...
  • Linksys Master
  • 6,487 Answers
This is a problem with the router's firmware, so i suggest you go to linksys web site and download the latest firmware for this router and upgrade it , so everything will be working but if still the same problem after the update better call linksys support and have the router replace...
Posted on Feb 19, 2009
I am trying to connect a wrt150n wireless linksys router to my dsl. I am using a desktop windows 7 and laptop windows vista. Please help, I have tried everything but it just does not want to work.
unplug everything, including ethernet cables. then work in this exact order.
if you get a wireless signal and no internet, plug a computer in into the router in one of the available ports and check for internet. If no internet, unplug everything and test the modem without the router. If internet available without the router, then follow these instructions
  1. plug phone line into modem
  2. plug power into modem
  3. wait for all lights to become steady
  4. plug ethernet cable into modem
  5. plug other end of same cable into port labled "internet"
  6. wait for lights to become constant on both router and modem
  7. check your wireless device for wireless service.
if you dont get a wireless signal at all, plug your device into the rear of the router and type 192.168.1.1 in the adress bar
the password and username are both "admin" or simply leave the password blank if that doesn't work
navigate to the wireless option and turn on the wireless transmiter.
GOOD LUCK AND PLS RATE THIS POST!!!!!!
Dec 01, 2010 | Linksys Wireless-N WRT150N Router
Linksys wrt150n wireless router won't connect to internet. Power, Wireless and security lights are on, but not internet light. I've unplugged power cords, ethernet cords, pressed reset button on router,...
1)If internet light not on then login to router and check the summary!!!and try to diagnose the test which is there in router!! and check for ppp is it active or down? Might be authentication credential is not correct that could be the reason?
Sep 18, 2010 | Linksys Wireless-N WRT150N Router
Linksys wrt150n power button blinks.
The blinking power on your router is a bad sign that it has some problem on it. You can follow the step by step procedure from my TIPS to fix that blinking power problem on your router.
http://www.fixya.com/support/r3801591-fix_blinking_power_light_linksys
Jun 02, 2010 | Linksys Wireless-N WRT150N Router
I forgot my password how do i reset it
On the back side of the router , you will find the small reset button ( red coloured hole). Just press that button for 30 seconds. release the button. Unplug the power to the router and plug it back in. Waite for 1 minute.
Once you reset the router , it will come back to the factory default settings.
You will need to reconfigure the router according to the Internet service provider.
That means you will need to set up the router for the Internet.
Click Here for more information about router set up
Feb 18, 2010 | Linksys WRT150N Wireless N Router -...
I forgot my security code to my Linksys WRT150n wireless router
If you cannot remember the passphrase, you will need to reset the router to factory standard and then reconfigure your settings. On the WRT models, there is a pinhole on the back of the router.
Push the pin in with a pen for about 10 seconds, then unplug the device. While still holding the button in with the pen, plug the router back in. Wait for about 20 seconds, then release. The router should wipe all settings and complete its boot process. You should then be able to reconfigure the settings. This time, write your passphrase down and keep it in a secure place.
Jan 05, 2010 | Linksys WRT150N Wireless N Router -...
Mu WRT150N Router appears to have stopped working. If I hook the modem direct to the laptop it works. If I put the router inbetween with the same direct connection, no internet. I have tried several cables...
Are any of the LED lights switched on in the router when it is powered up?
If not check the power adapter plug with a multi-meter, the output voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter.
If the voltage is zero or very low then the power adapter is faulty and needs to be replaced.
Dec 13, 2009 | Linksys Wireless-N WRT150N Router
Router problem
Feb 19, 2009 | Linksys WRT150N Wireless N Router -...
Cannot access internet with a linksys router
Make sure DHCP is turned off on the modem or else you will get ip conflicts. Also make sure it is plugged into the wan port on the router
Jan 15, 2009 | Linksys Wireless-N WRT150N Router
Linksys WRT150N Wireless N Router - 300Mbps, 802.11n , 4-Port   Logo
102 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
