Question about Acer Aspire 3000 Notebook
Memory Size I purchased a Aspire 3000 laptop about 4 years ago. I have been told that I can not add more memory to it (it only has 192MB) as I will lose everything on it is this correct/
    President:
  • 2,110 Answers
  • 256 MB / 2 GB (max)
  • Technology DDR SDRAM - 333 MHz
you can maximize upto 2 GB....you will not loose the data..
Posted on Feb 19, 2009
How do you access the memory slots on an acer aspire z3731
Memory Sockets or Slots are the place where memory RAM modules are inserted in the motherboard. The Acer Aspire Z3731 has 4 (4 banks of 1) memory expansion slots. A memory bank is a group of memory expansion sockets, a bank must be completely filled with memory modules of the same size and type in order for the system to recognize and address the memory. i.e. :
2 sockets (2 banks of 1) This indicates that there are 2 memory slots. These are divided into 2 banks, and each bank consists of one memory slot. So you can add memory one piece at a time for the system to use.
3 sockets (3 banks of 1) This indicates that there are 3 memory slots. These are divided into 3 banks, and each bank consists of one memory slot. So you can add memory one piece at a time for the system to use.
4 sockets (2 banks of 2) This indicates that there are 4 memory slots. These are divided into 2 banks, and each bank consists of two memory slots. So you must add memory two pieces at a time (they must be the same size and type of memory) in order for the system to benefit from the upgrade.
8 sockets (4 banks of 2) This indicates that there are 8 memory slots. These are divided into 4 banks, and each bank consists of two memory slots. So you must add memory two pieces at a time (they must be the same size and type of memory) in order for the system to benefit from the upgrade.
12 sockets (3 banks of 4) This indicates that there are 12 memory slots. These are divided into 3 banks, and each bank consists of four memory slots. So you must add memory four pieces at a time (and they must be the same size and type of memory) in order for the system to benefit from the upgrade.
Mar 09, 2012 | Acer Aspire All-in-One Desktop PC - Silver...
I have a Toshiba satellite 2775xDVD laptop with 64mb. of ram soldered to a mainboard. It is based on Intel 443ZXM chipset. The official Toshiba manual says that I can acquire a maximum of 192mb of ram on...
A good website to check out would be http://www.crucial.com.
On the main page you can select the maker and model of you computer and it will give you all the options for your laptop. You can even purchase the memory direct from them at a decent price.
If the manufacturer states that you can only have 192MB of RAM then that may be all that the BIOS can recognize.
Mar 07, 2011 | Toshiba Satellite 2775XDVD Notebook
How much memory can I add.
This laptop model supports a maximum of 2 GB of memory.
Sep 18, 2010 | Acer Aspire 3000 Notebook
It islow and to upgrade, they recommend to add
I am running windows 7 is a laptop....and it is using over 1 GB plus my startup programs. Your laptop can handle and use 4 GB of ram. (2) 2GB sticks. Below are the specs.
  • Module Size: 2GB
  • Package: 200-pin SODIMM
  • Feature: DDR2 PC2-5300
  • Maximum Memory: 4096MB
    Nov 15, 2009 | Acer Aspire 5100 Notebook
    Memory problem
    you may have purchased a memory stick that requires more speed than your memory block can give. the speed for this lap top should be around 455-500 MHz on the memory block. if the memory stick requires more than that, its not going to work.
    Mar 11, 2009 | Gateway M305CRV Notebook
    4 GB at the begining, now 2 GB???
    Hi
    where did you see that the computer had 4 GB of ram? ram can only be removed by removing ram memory modules from inside the computer.
    Dec 28, 2008 | Acer Aspire 5580 Notebook
    Need more video and memory.
    Very few laptops allow you to change the video, it is integrated (built in) to the motherboard. All computers also have a maximum limit to the memory capacity based on the number of slots and the type and size of memory modules supported by the CPU.
    The Acer Aspire 3624WXCi was a budget system with a Celeron 1.6GHz processor. The Celeron series is just not that good at video tasks, such as your flight simulator demands. The integrated video is an Intel Media Graphics Accelerator 900 with 128MB ram, not bad but not optimum for your applications.
    The Acer Aspire 3620 series uses DDR2 memory and has two slots. Each memory slot can hold a maximum of 1GB, so the system is limited to 2GB of ram. If you are at this limit, it is true that you can not add more but must move onwards and upwards to a newer more powerful system.
    Dec 28, 2008 | Acer Aspire 3624WXCi Notebook
    Is there more than one memory slot on a toshiba 4080 xcdt?
    check your manual on the maximum amount of memory your motherboard can handle. 192mb is rather very small. check online for your computers specs.
    Nov 08, 2008 | Toshiba Tecra 8000 Notebook
    Virtual memory
    yes upgrading your ram (random access memory) helps alot
    also incressing your virtual memory paging file might work if it is set 2 low.
    Windows XP loadTOCNode(2, 'resolution'); 1. Click Start, right-click My Computer, and then click Properties. 2. In the System Properties dialog box, click the Advanced tab. 3. In the Performance pane, click Settings. 4. In the Performance Options dialog box, click the Advanced tab. 5. In the Virtual memory pane, click Change. 6. Change the Initial size value and the Maximum size value to a higher value, click Set, and then click OK. 7. Click OK to close the Performance Options dialog box, and then click OK to close the System Properties dialog box.
    Dec 07, 2007 | Acer Aspire 3000 Notebook
    Acer Aspire 3000 Notebook Logo
    83 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Alun Cox
