Question about Brother MFC-425CN Multi-Function Center All-In-One InkJet Printer
Screen message: "Unable to print
Screen reads See Troubleshooting and Routine Maintenance Chapter in User's Guide. I have checked for foreign objects and have switched it off for some time. No better.
  • 3 more comments
  • jane40 Feb 19, 2009
    Yes, I have done that. It didn't change anything.
    Done that. No good. Thanks for the ideas. Have you any others?
    I hope you haven't given up on me?
    I can't say that you have resolved my problem at all, yet. I hope you are still onto it.
    Cheers,
    Jane
    Can you give me any idea how to replace the print head, as suggested?
  • 423 Answers
What is the screen message? Unable to...what? Please clarify. There are several "unable to's" ie. Change, Clean, Init., Print, Scan. Put it in your post. Thanks.
Posted on Feb 19, 2009
  • Rob
    Rob Feb 19, 2009
    Ok, now I see it. Sorry.
  • Rob
    Rob Feb 19, 2009
    When you unplugged the unit from power? How long did you leave it unplugged?
    This might sound silly, but seriously, try this...unplug it from power and turn the unit upside down, give it a gentle shake and turn it back right side up. Plug it back in again and turn it on. Does the message go away?
    Sergeant:
  • 326 Answers
You will have to open the printer remove the cartridges.there will be a lock in the cartridge carriage you will have to carefully open that lock by pressint it .the carriage will come up loose and slowly you can lift the hed.
    Brigadier General:
  • 6,966 Answers
Hi and thank you for using FixYa,
Unfortunately, almost always, this error message indicates a problem with the print head. If you have tried cleaning a couple of times with no corrective results, may I suggest you explore replacing the piezo printhead. Importantly, it would be to your advantage to first get a quote. In most instances the repair cost, down time and effort to effect a repair may no longer prove to be economically reasonable. Should this be the case, then either consider a warranty claim/repair or re-evaluate your options and consider purchase of a replacement printer. Sorry but have to state the options.
Good luck and thank you for using FixYa.
  • Louie  Role
    Louie Role Feb 19, 2009
    An MFC426 uses the same chassis/engine as with most MFC models including a 420-C and/or 210C. Your best initial move would be to get hold of a service manual that details Maintenance/Service modes and resulting machine error codes. An abbreviate procedure of removing the print head is available here and here. Service manuals maybe purchased here or here.
    Genius:
  • 1,550 Answers
Try reset .
Unplug the unit from power chord for 30 minutes and plug back the power chord to the unit .
This will reset your unit .
  • 1 more comment
  • SAM ANDERSON Feb 19, 2009
    Take your cartridge out from the printer and check it well and place it once again and check for any paper bits inside printer .
    Also check whether roller is moving freely .
    Hope this helps .
    Have you tried reinstalling the driver file with the latest updates .
    If you have not tried this . Do it now .
    You can download the driver file from the link below
    Driver for Brother printer
    Replacing Print head is bit expensive . You can go with new printer . Try the suggestion i gave for downloading the driver file with latest updates . That will solve your problem .
Init Unable 48, See troubleshooting and routine maintenance chapter in User's guide
What is the condition of your print cartridges? They could have dried out during the 2 month period that you didn't use the printer. Try, cleaning the contacts of the cartridges and the printer. If you have new cartridges to try....even better.
Jan 15, 2008 | Brother MFC 240C All-In-One InkJet Printer
THE LCD SCREEN SAYS PRINT UNABLE 50 AND SEE TROUBLESHOOTING AND ROUTINE MAINTENANCE CHAPTER IN USERS GUIDE.
Read the users guide and do what they say in the Troubleshooting and Routine Maintence Chapter for the "Print Unable 50" error message.
Mar 29, 2011 | Office Equipment & Supplies
Says unable to print 4f, see troubleshooting and routine maintenance. please help.
This is a print head failure of some type. Turn off the printer, disconnect the power cord and lift up the scanner unit. Check for any paper or foreign object. See if you can slide the printhead and check under it. If the printhead will not move easily, do not force it. If the printhead is all the way to the right, you will not be able to move it. Use a flashlight to check for any foreign objects or paper scraps soaked with ink. Remove any foreign stuff that you find.
Sep 15, 2010 | Brother MFC-5460CN All-In-One InkJet...
Print Unable 36 LCD Screen on printer reads: Print Unable 36. See troubleshooting and routine maintenance chapter in User's Guide But i cannot find my User Guide can you please e-mail me what is in the...
That error is a carriage travel error, the printhead is not moving freely. Most often paper scraps either on the extreme right side where the printhead parks, or on the extreme left side where it's hard to see.
Feb 19, 2010 | Brother DCP 165C Compact Color Inkjet...
Problem with my printer Brother MFC-240C "Print unable 4F"
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing. thanks
Jul 13, 2009 | Brother MFC 240C All-In-One InkJet Printer
Will not print
www.brother.com has those user guides by model number..
Jul 27, 2008 | Brother DCP 130C All-In-One InkJet Printer
Will not print
What 2 digit error code does the machine display, too?
May 12, 2008 | Brother DCP 130C All-In-One InkJet Printer
Unable to print, See troubleshooting and general maintenance in User's Guide, however, I do not have a User's Guide! What to do?
unable to print, See troubleshooting and general maintenance in User's Guide, however, I do not have a User's Guide! What to do?
Nov 14, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-425CN Multi-Function Center All-In-One InkJet Printer Logo
200 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
