Question about Kensington Electronics - Others
I want flash drive bootable - Kensington Electronics - Others
    Scholar:
  • 77 Answers
You will need to copy the three files - ntldr , ntdetect.com and boot.ini from C:\ to the USB flash drive and also the boot from USB option should be enabled in your CMOS setup.
HTH,
Regards,
Deboo
Posted on Feb 19, 2009
Can I reinstall the os from a flash drive?
yes. format your flash drive to make it bootable
Oct 16, 2013 | Computers & Internet
Bootable USB
rreadow To Boot From A USB Flash For starters this is still a new science and many people have had good luck with at least one of these methods and others have not. Note that flash drives are often also called thumb drives, keychain drives, pendrives, etc. A FEW THINGS YOU NEED TO CONSIDER IN ADVANCE. 1. The PC has to support booting from a USB flash drive. There may be anywhere from 1-3 items to change in the BIOS to make this possible assuming your BIOS supports it. Some bios's may refer to your flash drive as a USB floppy or USB zip.
2. The USB flash drive must support booting from it in general.
3. The flash drive must contain the boot/system files.
4. The flash drive must have bootsector area. This is done with special utilities.
5. References to "A:" drive lines in the autoexec.bat and/or config.sys files you copy to the drive after you make it bootable may result in errors.
6. You "may" have to format your floppy disk first in WinXP before you create a bootdisk as XP may "not" like working later on with a disk formatted otherwise.
7. Included below is a bootable ISO of DOS 7.1 which may be used with some of these methods if you do not have a 1.44 drive.
zivider.gifzivider.gifzivider.gif METHODS Method 1 - Make your flash drive bootable using Bart's mkbt util:
http://www.nu2.nu/mkbt/ | Alt: mkbt20.zip Put a bootable floppy disk in your A: drive or create one using Windows.
Download mkbt20.zip and unpack to to new temp folder you create.
Go to the temp folder.
Extract the bootsector from the bootable floppy disk. eg Open a DOS Window and go to the directory where you extracted MKBT. Type: mkbt -c a: bootsect.bin The boot sectors from the bootable floppy disk have just been saved to a file in the temp folder you created. Format the flash drive in FAT or FAT16. Copy the bootsector to the flash drive. Open a DOS Window and go to the folder where you extracted MKBT. Type: mkbt -x bootsect.bin Z: "Z" represents the flash drive drive Letter. So if your flash drive has another drive letter, then change the "Z" accordingly. Now you can [grin] "should" be able to copy the utils you need to the pen drive.
zivider.gifzivider.gifzivider.gif Method 2 - Try these 2 HP/Compaq USB Flash Drive Utilities. They work with many other brands of flash drives as well. HP USB Disk Storage Format Tool Version 2.0.6
HP Drive Key Boot Utility Version 7.41
Download
zivider.gifzivider.gifzivider.gif Method 3 - Third Party Links http://ucsu.colorado.edu/~shaher/Bootable_USB.html Recall I did say it's a new science.
http://www.microsoft.com/whdc/device/storage/usb-boot.mspx
zivider.gifzivider.gifzivider.gif Method 4 - A Bootdisk.Com Visitor Suggested Here is my another method for creating dos bootable USB sticks using windows format. 1. From Win98 DOS-Prompt type "SYS {USBDriveLetter}:" or "FORMAT {USBDriveLetter} /U /S". If from WinXp then from start->run command.com execute format.exe copied from win95 or win98. OR 2. Simply by enabling copy system files in windows explorer format window. By default it is disabled for non-floppy drives. To enable it use windows enabler program from http://www.angelfire.com/falcon/speedload/Enabler.htm an whoila it works.
zivider.gifzivider.gifzivider.gif Method 5 - Another Bootdisk.Com Fan Suggested - Thanks Keith First if you don't have a physical floppy drive (and don't want one) you can use the [free] "virtual floppy driver" from here: http://chitchat.at.infoseek.co.jp/vmware/vfd.html With that you get an A: drive and can manipulate a floppy image as if you were using real floppy. You can then use that image to make a bootable CD. It's not that user friendly but once you get how it works it does work perfectly. Even cooler you can use a "raw write" utility like dd for windows to write the floppy image directly to your USB thumb drive. Even without that famous HP utility to do the magic this will make your USB thumb drive bootable. The 'dd' ported to Windows is located here: http://www.chrysocome.net/dd Another trick you can use with that dd utility involves MS VritualPC (which is free). You can create a virtual machine/virtual hard drive, set it up the way you want then use dd to "raw write" the virtual hard drive image to the thumb drive; this will make the thumb drive identical to the image, including bootable (again, no HP utilities required). Of course, your thumb drive will effectively have the capacity the size if the image in question (your 1GB flash drive will effectively be 1.44 Megs).
Sep 13, 2008 | Computers & Internet
Tip
Creating Bootable USB Flash Drive.
The USB Flash Drive must be configured with an active primary MS-DOS partition. It must also contain the boot files. Follow the steps below to create a bootable USB Flash Drive.
Requirements:
  • Motherboard with BIOS that supports USB boot.
  • USB Flash Drive that may be erased.
  • Bootable floppy disk or CD with Fdisk and Format commands.
Directions:
  1. Plug in the USB Flash Drive.
  2. Make the USB drive the only bootable hard drive. Method 1:
    If available, change the BIOS settings for the hard drive sequence, making sure the USB device is at the top of the list above all other hard drives. Not all BIOS Setup Utilities have this option. Method 2:
    Disable all hard drives in the BIOS. In some BIOS Setup Utilities you can disable the individual hard drives, while in others you will need to disable the controller. Method 3:
    Unplug all hard drive cables inside the case. If the cables are unplugged the computer cannot detect and boot to the hard drive.
  3. Insert the bootable floppy disk or CD into the appropriate drive.
  4. Restart the computer to the bootable floppy disk or CD.
  5. At the command prompt, type: FDisk.
  6. Delete and create a new active primary DOS partition.
  7. Use FDisk to delete all partitions from the USB Flash Drive.
    • In FDisk, press the 3 key to Delete partition or Logical DOS Drive.
    • If there is just one partition on the drive, choose 1 to delete the primary DOS partition. If there are several partitions, the extended and logical partitions must be deleted before the primary partition.
    • After choosing option 1, the screen appears with partition information and a prompt for the partition to delete. Choose which primary DOS partition to delete, and then press ENTER.
    • A prompt appears to enter the volume label of the hard drive. Enter the label exactly as it appears on the top of the screen in the partition information. If the volume label contains gibberish or lowercase letters, the partition will have to be deleted as a non-DOS partition. Try using the option to delete a non-DOS partition in FDISK. After entering the volume label, press ENTER.
    • You are prompted if it should delete the partition. Press Y for Yes, and then press ENTER.
    • The screen changes to show only the total disk space and a line near the bottom that prompts that the primary DOS partition has been deleted. Press the ESC key to return to the main menu.
  8. Use FDisk to create a primary partition on the USB Flash Drive. The drive letter will be C:, since all other hard drives were disabled in step 2.
    • In FDisk, press 1 to Create DOS partition or Logical DOS drive.
    • Press 1 to Create a Primary DOS Partition.
    • The next screen prompts if the maximum hard disk size should be made into one partition. Press the Y key, and then press ENTER.
    • The next screen prompts that the computer will now reboot. Press ENTER to continue.
  9. Exit FDisk and restart the computer.
  10. Start the computer from the bootable floppy disk or CD with the USB Flash Drive still connected.
  11. At the command prompt, run Format by typing the following command: Format c: /s. Press ENTER.
  12. At the command prompt, run FDisk by typing following command: Fdisk /mbr. Press ENTER.
  13. Restart the computer without the bootable floppy disk or CD, and attempt to boot to the USB Flash Drive. If it works, it should go to a C:\> command prompt.
  14. Change the settings made in step 2 back so that the computer operates normally again.
on Mar 31, 2010 | Computers & Internet
System32\config\system is corrupted. I want to boot from a flash drive. How it is made, the flash drive?
I recommend you to boot from a Windows CD and use the 'repair' option.
Anyways, Flash Drive is a Universal Serial Bus - Mass Storage Device (USB Memory Storage Device) also known as Pen Drive in common.
  • To install/Repair OS using a Flash Drive, you need to follow these steps
http://www.nu2.nu/mkbt/ ' Alt: mkbt20.zip
  1. Put a bootable floppy disk in your A: drive or create one using Windows.
  2. Download mkbt20.zip and unpack to to new temp folder you create.
  3. Go to the temp folder.
  4. Extract the bootsector from the bootable floppy disk. eg Open a DOS Window and go to the directory where you extracted MKBT. Type:  mkbt -c a: bootsect.bin
  5. The boot sectors from the bootable floppy disk have just been saved to a file in the temp folder you created.
  6. Format the flash drive in FAT or FAT16.
  7. Copy the bootsector to the flash drive. Open a DOS Window and go to the folder where you extracted MKBT. Type:  mkbt -x bootsect.bin Z:
Now you should be able to copy the utilities you need to the pen drive.
If you need more Methods/Options, you can check BootDisk
Aug 11, 2011 | Computers & Internet
I can't load flash drive which contains bootable windows xp, i already set in bios first boot device to Flash drive, but it's still can't load, only apears black screen with only one blinking blank. please...
i would assume you made the flash drive bootable and did not just copy windows onto it,,
if you didnt make the flash drive bootable it simply wont work
go here for more info
Jul 17, 2010 | Samsung P30 Notebook
Trying to reformat mini dell with no cd rom drive tried to boot from usb but comes up with No bootable partition in table what does this mean
Recovery discs have certain run procedures, flash drives dont. I would suggest you obtail or lend and external USB writer
Feb 21, 2010 | Dell Inspiron Mini 10 Notebook
How do you make a bootable USB flash drive
Here's a utility that would be easy and perfect for your problem, HP USB Disk Storage Format Tool - v2.1.8, please click on the link below:
http://files.extremeoverclocking.com/file.php?f=197
Instructions are on the website, hope this helps.
Nov 22, 2009 | SanDisk 1GB Cruzer Titanium USB Flash...
4GB Sandisk Cruzer Pt. 2
Hello
I have used PEbuilder to make bootable flash drives for all the different operating systems. In my shop it's much easier to have these on hand. If you made the flash drive correctly (I assume you did) did you check the netbook's BIOS to make sure the USB port was turned on and set to allow a bootable device?
Jul 28, 2009 | Computers & Internet
How to create a bootable usb pen drive
please download a software (Eg:- bootflashdos) from softpedia.com.
Using that bootflashdos program you can create a usb pen drive as a bootable device.
best regards,
Krishan
May 09, 2009 | Electronics - Others
Electronics - Others Logo
61 people viewed this question
Top Kensington Electronics - Others Experts
Are you a Kensington Electronics - Other Expert? Answer questions, earn points and help others
