Canon PIXMAiP1500. I have just replaced the black ink. I haven't used the machine for several months. It won't print black but will print colour. I have done all the mechanical stuff recommended like automatically cleaning the print head. I don't want to go to the expense of taking it to a service centre. What is your advice?
  • 1 more comment
  • jane40 Feb 19, 2009
    That could well be the problem. But how do I fix it?
    Thank you for that. I'll give it a go. Many thanks.
    Rob: You are brilliant. It has worked. Many, many thanks,
    Jane
    Genius:
  • 1,011 Answers
Sir,
Try to  clean the nozzle, print ahead alignment and deep cleaning... it solves the problem. If not, let me know.
Thanks good luck
Posted on Feb 19, 2009
    Guru:
  • 832 Answers
Hi there!
thanks for using Fixya.com!!
If you have done the cleaning of the print head.
If you have already changed the black ink to anew.
And try a few print head deep cleanings, if still does not help then you pls try to soak the print head in a shallow plate of hot distilled water. Soak the tip of the print head. Do not use alcohol based liquid. If you can use any better cleansing solution that is recommended.
If still nothing happened, I suggest to if you will bring to the accredited service center. Hope you still have your warranty card so that you will not pay so much.
Check this as well: http://www.uktsupport.co.uk/canon/bj/s400.htm
and this
http://www.neilslade.com/papers/inkjetstufff.html
thanks and hope this will help you somehow.
have a nice day!
cheers!
  • Dennis Jambalos
    Dennis Jambalos Feb 19, 2009
    hello again!
    I think it is with the nozzle problem. Maybe it is clogged, due to dried ink. Just clean the nozzle. And put it back again and pls do the auto printing head cleaning to do the job. You may do it several times and it depends with the clog if it is very bad. Just do it right. Hope I am not too late to help.
    thanks again. don't forget to mark! cheers!
  • 6,487 Answers
Since you have just replace the black cartridge with a new one and its not working , I will advice you to try returning that cartridge and have it replace so we can check if this is a problem with that new cartridge that you have...
  • 423 Answers
The black ink is not the problem, it's the nozzle. The nozzle for the black ink head is clogged with dried up ink. If it were mine, I would remove the print head and use a q-tip dipped in alcholol to clean the nozzle. Let the alcohol dry and put it back together and run another auto print head cleaning.
You're probably going to have to do it a few times. It's going to depend on how bad the clog is. This will fix you...just be patient. Remember that ink has been dried on several months. Don't forget to rate my help. Thanks for coming to FixYa.com
Rob
  • 10,594 Answers
I hope you replaced original Canon black ink cartridge in printer as after market or cheap cartridge gives such problem.
Canon 5220 prints - NO ink
Try running the cleaning program.
Mar 20, 2014 | Canon Pixma MG5220 InkJet Printer
Canon IP3300 won't print color
hi chette,
its a common problem for printer dye ink,have you try to use other cartridge? a brand new one maybe?
if you insist using the old one, try these step.
1. use vinegar to clean your cartridge head
2. put a little vinegar into the cartridge
3. try deep cleaning it.
it only work for dye ink base not else :D
ciaw.
Jul 11, 2012 | Canon PIXMA iP3300 Printer
The machine won't print. It won't feed paper, The
Your machine needs to be serviced.
replace the cartridge with the original one.
it can not print if one cartridge is missing or not original.
Jul 12, 2011 | Canon Office Equipment & Supplies
Hp photosmart 8050 won`t print black even though it says it full
Hi there! If you haven`t used the printer in 2-3 months the black ink cartridge has gona dry.Wich means the printer is seeing full ink but the ink isn`t actually coming out from the ink head.Take a peace of clean cloth or cotton and clear the bottom part of the ink head(be verry carfully while cleaning it cuz you may dmg the head.If that doesn`t help just go and buy a new ink cartridge and it will solve your problem.
Nov 10, 2010 | HP Photosmart 8050 InkJet Printer
Printer spits out black ink and smudges when printed
Your printer apparently needs to be cleaned, using your canon software utility. If the cleaning doesn't help, try to replace cartridges
May 31, 2009 | Canon MX700 Office All-In-One InkJet...
Black not printing, other colors fine, replaced cart and deep cleaned several times, no result
Assuming genuine ink cartThis worked for me on a HP printer 1.Try print black text ,and run many copies black only. I ran 25x12 times still no black. Run head clean after about each 50 sheets. Persevered and finally BLACK ink OK
Good Luck Inkypete
May 01, 2009 | Canon PIXMA iP3500 Printer
The black ink will not print on my canon pixma ip4200
printer head problem remove ink put about ten drops of alcohol in where the ink goes in run clean cycle ten times
Mar 29, 2009 | Canon Office Equipment & Supplies
Won't print black ink
I am on my second Photosmart C6180, the first one I had quit printing black ink after 6 months, after hours with the HP help desk, the finally decided to replace the printer. I have now been using the replacement for several months and just this weekend it too quit printing black ink...no copying, no printing and no faxing.  I am now shopping for another, not a HP.
Sep 08, 2008 | HP Photosmart C6180 All-In-One InkJet...
Black Printing
Possibly the printer head needs replacing. That's the actual black 'box' the inks fit in. I've generally found they last no longer than about 18 months. You can try cleaning the contacts with an alcohol pad before forking out the $50 odd dollars it costs for a new head. If you have some time on your hands you could also try reinstalling the drivers - http://consumer.usa.canon.com/ir/controller?act=SupportDetailAct&fcategoryid=232&modelid=8740 Good luck
May 03, 2006 | Canon i 450 InkJet Printer
k24674
