I installed Google Chrome on my computer and our Secretary's computer and now both computers are randomly restarting. We uninstalled Google Chrome and the computers are working fine now. We would like to use Google Chrome in the school environment if we can get this issue fixed..
A few things I found with a Google search:
1. Right click Chrome icon.
2. Select Properties.
3. Click the Shortcut tab.
4. At the end of the Target textbox, type the following command:
" -no sandbox"
(without quotes; of course)
5. Click OK.
SOURCE: Dell Optiplex 160L Motherboard
Hi there is one more thing you should check before buying another mobo. Trace the wires from your on/off switch on the case, unplug it and then bridge the 2 pins out with a screw driver, this will start the computer. runit as normal, then shut down and see if you get a restart. If the computer does not restart on its own you have a faulty switch. Clean it or replace it. Regards mistyman
SOURCE: computer keeps restarting
im assuming your computer running windows, does it go inside windows b4 it will restart? common causes regarding this problem are corrupted operating system or over heat on your processor and incompatble softwares such as firewalls and antivirus.
SOURCE: Dell Inspiron 530 randomly shuts down and restarts
Sounds like it could be a virus. Or, a heat buildup problem - are all fans inside machine working? Is the fan inside the power supply operating? Was there any work done inside the computer recently?
If the hdw is all ok, go out and buy yourself a copy of Norton Internet Security 2009 - 1 user lic - $49.99 @ Staples. Do *not* buy any earlier vers. of this software! Install, update it, run computer computer scan - probably will find/remove some/many viruses.
If this helps, please take the time to rate my response to you.
Thanks and good luck.
gurutim
SOURCE: I have a dell optiplex 270 and my computer does
Third party burners (Nero, Roxio) will give you wrong drivers if you try to add a new drive. Uninstall them and remove previous drive info. Also make sure cd record trab shows in device manager and is active on the IMAMPI.
SOURCE: does a firmware update for dell optiplex 755 optical drive fix
dell 755 drivers page
your looking at the wrong firmware
optiplex 755 current bios version: A10 date 6/20/2008
for the CD Drive need to open device manager and check
what brand and model you have for dell used 2 DVD drives
sony and teac
use the correct firmware on drive, if not the drive will be killed.
if unsure open case and look for name/model on sticker of drive
