Question about Quantum Fireball Plus AS (QMP30000AS-A) 30 GB Hard Drive
Electronic schematic of Quantum QMP30000AS-A
I need electronic schematic of hard disk QMP30000AS-A. Do you know where a I can look for it? Or do you can sent me it? Grazie. Scusate eventuali errori di grammatica inglese.
3 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: Hard Disk Quantum QML20000LD-A
Hi, may I offer an alternative solution? You may want to try and replace the entire PCB assembly rather than repair. I would assume that the Quantum QML20000LD-A is a few years old and so many of the same brand/model would be lying around computer repair shops. Even if defective, these drives can be: 1) direct parts source; and 2) remove/use the entire board. You can even find this kind of HD from old CPUs (166-550 MHZ.) I believe you can get them relatively cheap and faster. Hope this somewhat helps. Cheers.
Posted on Apr 17, 2007
SOURCE: ''pulizia impossibile vedere il capitolo errori del manuale dell'u
http://www.retrevo.com/search?q=Brother+DCP-120C&rt=pd
download the manual frm the above link.Thank you.Please do rate if this could solve your problem.
Posted on Dec 07, 2008
Replacing points distributor with electronic distributor,need wiring diagram
If using an electronic distributor from an 80's or 90's vintage vehicle then there are 2 different schematics. http://www.allpar.com/fix/electronic-ignition.html This web site from ALLPAR has a perfect description with great looking, color coded wiring schematics.
Hope this helps
Jun 15, 2012 | Dodge Vehicle Parts & Accessories
I want to install quantum 20 GB lct as my second drive and as a slave. I have a six pin connector at the back. How do i set the jumper so as to make it a slave drive thakx jason
Take a VERY close look for some "engraving" near the pins.
Look for 'MA(ster)' and 'SL(ave)' and 'C(able)S(elect)' lettering.
Or, some disk-drives have a diagram on the label on the top of the disk-drive, instead of the engraving. Follow the jumpering-instructions on that label.
Nov 05, 2010 | Quantum Fireball Plus AS (QMP30000AS-A) 30...
I NEED TAN ELECTRONIC SCHEMATIC
Here is a link to the manual:ftp://ftp.digitech.com/pub/PDFs/Manuals/RP1000/RP1000%20manual%2018-0597-A.pdf It is highly unlikely that you will find a schematic unless you know a service tech for a music store that deals Digitech. Also you will need some specialized tools. Here is their contact info:http://www.digitech.com/dealers/service_lookup.php If you are a tech you can always contact them.
Apr 07, 2010 | Music
Drivers download
Hard drives do not have an installation CD unless you are referring to Windows installation CD and installing Windows on the hard drive/
Dec 07, 2008 | Quantum Fireball Plus AS (QMP30000AS-A) 30...
Primary Drive 0 is not found when I boot my computer
First things first use teh arrow keys for left and right to select auto for the primary drive. If when you reboot and the drive is not seen then double check if the hard drive is set to master you can see the jumper settings and how they should be set on the top of the drive itself. Then check the power if the drive feels like its vibrating then its ok. After that turn on the computer. If after that the drive is still not detected then you might have to consider that the drive is defective and i would suggest you try another drive and see if it is detected.
Kindly reply back for additional questions.
Nov 19, 2008 | Quantum Fireball Plus AS (QMP30000AS-A) 30...
REMOVE PCB TO OTHER HD
the drives have to be of the same rev number. must be in an anti static environment, and you should have done this before.
Oct 01, 2007 | Quantum (SE21S011) 2.1 GB Hard Drive
Apr 16, 2007 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Quantum Fireball Plus AS (QMP30000AS-A) 30 GB Hard Drive Logo
140 people viewed this question
Top Quantum Computers & Internet Experts
Tape-Techie
SirEbrum
terminalcon
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
