Question about Brother MFC 7420 All-In-One Laser Printer
Self diagnostic will complete automatically in 10 minutes
It comes up with the self diagnostic msg. then restarts automatically. once reset - it says to check troubleshooting guide (which i dont have).
  • Anonymous Nov 18, 2007
    Brother MFC 7820N. Self-diagnostic. will restart automatically within 10 minutes
    New Friend:
Problem for Brother MFC-7420 All-In-One Laser Printer Self diagnostic will complete automatically in 10 minutes
Posted on Jun 12, 2010
  • 98 Answers
You can see and download thr User's Guide that includes a Troubleshooting section here: http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000387/ALLFB_UsaEngUsr_B.pdf
Posted on Aug 01, 2007
    New Friend:
Will automatically restart within 10 minutes
Posted on Feb 02, 2013
SOURCE:
Where is the reset button on a hottpoint side by side refrigerator.
Self Diagnostics
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display can be illuminated by pressing an adjacent temperature adjustment button. When both displays are illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all 4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
To perform a self diagnostic test, locate the test in Table 2, Diagnostic Tests.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button will increment the numbers up and the WARMER temperature adjustment button will increment the numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test. Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will increment the numbers down and the WARMER temperature adjustment button will increment the numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test code. Press any button other than a temperature adjust button to begin the test.
When testing has been completed, do one of the following things:
• Enter code 1 5 to completely reset the system.
• Enter code 1 6 to exit diagnostic mode. The temperature control panel is reset automatically.
• Unplug the refrigerator for at least 10 seconds. Test mode will terminate when the refrigerator is plugged back in.
Test mode will terminate automatically after 15 minutes of inactivity.
Read more: http://appliancejunk.com/forums/index.php?topic=10408.0#ixzz3VIqUINVz
Feb 27, 2015 | Hotpoint HSS25GFT 25.0 Cu. Ft....
HOW DO I FORCE A HOTPOINT SIDE BY SIDE REFRIGERATOR (HSS25GFTA) WITH AN ADAPTIVE DEFROST TIMER INTO DEFROST MODE?
Start a diagnotsics mode and enter test code 1 - 4 of the diagnostics to start the defrost mode
Self Diagnostics
(or in your case.... after the deforst cycle completes and possibly + 15 minutes)
Thanks for choosing FixYa,
Kelly
Aug 23, 2011 | Refrigerators
2001 F-150 cruise control stopped working. Already checked the fuse and it's good. What's next
really tough to do on the net but first we need to know about any codes...
Hold speed control OFF button, and turn ignition switch to RUN position. CRUISE indicator should flash once to indicate successful entry into self-diagnostic mode. If CRUISE indicator does not flash, start procedure over. If CRUISE indicator still does not flash, repair system by symptom there might be some switch concern
If CRUISE CONTROL indicator flashes once followed by 5 additional flashes, replace speed control servo/actuator.
Release speed control OFF button. Within 5 seconds in entering self-diagnostics, press speed control ON button. Press remaining speed control buttons in the following sequence; ON, RES, COAST and SET/ACCEL.
As each button is pressed, CRUISE indicator will flash.
Wait until indicator light goes out, then press next button. After sequence has been completed, indicator light will flash to indicate test passed or failed. With the codes we can then better diagnose your concern
Immediately after static test has passed, actuator performs a dynamic test by automatically operating throttle .04-.40" (1-10 mm). Observe throttle movement to witness any sticking in cable or linkage. Ensure throttle returns properly. Turn ignition switch to LOCK position. If self-diagnostics do not pinpoint fault there is more we can do but tough over the net
Mar 26, 2010 | 2001 Ford F150 Styleside SuperCrew
Heater displays everything but you cannot turn anything on ac will not turn on neither will the heat the buttons will not even light up please help
From the equipment description, I take this to be a EATC ( Electronic Automatic Temperature Control ) system.
You can try to run the EATC diagnostic test & recalibrate ( once you have confirmed it is not a fuse )
Electronic Automatic Temperature Control Module On-Demand Self-Test The EATC module on-demand self-test will retrieve on-demand (hard fault) DTCs only, it will not retrieve continuous DTCs. Continuous DTCs can be cleared when exiting the EATC module on-demand self-test. Make sure to retrieve continuous DTCs by carrying out the Electronic Automatic Temperature Control Module - Retrieve Continuous DTCs procedure before clearing any continuous DTCs.
•The EATC module on-demand self-test will not detect concerns associated with data link messages like engine coolant temperature or vehicle speed signals. A diagnostic tool must be used to retrieve these concerns.
•The EATC module on-demand self-test will detect concerns in the system control functions and will display on-demand (hard fault) DTCs for concerns that are present during the self-test. The vehicle interior temperature should be between 4°-38°C (40°-100°F) when performing the self-test. If the temperatures are not within the specified ranges, false DTCs may be displayed.
•The self-test can be initiated after cycling the ignition switch from OFF to ON. Normal operation of the climate control system stops when the self-test is activated.
•To enter the self-test, press the OFF and DEFROST buttons simultaneously and release, then press the AUTO button within 2 seconds . The display will show a flashing blower icon for 20 seconds , after which all vacuum fluorescent segments will be displayed if there are no on-demand DTCs present. If DTCs are present the EATC module will display "00 00" and then on-demand DTCs. Record all DTCs displayed.
•If any DTCs appear during the self-test, carry out the diagnostic procedure. Refer to the Electronic Automatic Temperature Control Module Diagnostic Trouble Code Index and follow the ACTION for each DTC given. See: Diagnostic Trouble Code Descriptions
•If a condition exists but no DTCs appear during the self-test, GO to Symptom Chart Condition: The EATC System Is Inoperative, Intermittent or Incorrect Operation. See: Symptom Related Diagnostic Procedures
•To exit the self-test and retain all DTCs, press any button except DEFROST. The EATC module will exit the self-test and retain all DTCs.
•To exit the self-test and clear all DTCs, press the DEFROST button. The EATC module will exit the self-test and all DTCs will be cleared.
•Always exit the self-test before powering the system down (system turned OFF). Once the self-test is exited, the ignition switch must remain ON for at least 30 seconds to allow the door actuators to automatically recalibrate.
•Continuous DTCs will be deleted after 80 ignition switch ON cycles after the intermittent fault occurs.
The EATC module will retrieve only continuous (intermittent and hard) DTCs when carrying out this procedure.
•Retrieval of continuous DTCs can be initiated after cycling the ignition switch from OFF to ON. Normal operation of the climate control system stops when retrieving continuous DTCs.
•To retrieve continuous DTCs, press the OFF and DEFROST buttons simultaneously and release, then press the RECIRC button within 2 seconds . All vacuum fluorescent segments will be displayed if there are no continuous DTCs present. Continuous DTCs are indicated by the presence of the degrees Celsius symbol (°C) on the EATC module display. Record all DTCs displayed.
•If any DTCs appear, carry out the diagnostic procedure. Refer to the Electronic Automatic Temperature Control Module Diagnostic Trouble Code Index and follow the ACTION for each DTC given. See: Diagnostic Trouble Code Descriptions
•If a condition exists but no DTCs appear, GO to Symptom Chart Condition: The EATC System Is Inoperative, Intermittent or Incorrect Operation. See: Symptom Related Diagnostic Procedures
•To exit and retain all continuous DTCs, press any button except DEFROST. The EATC module will exit the retrieved continuous DTCs mode and retain all continuous DTCs.
•To exit and clear all continuous DTCs, press the DEFROST button. The EATC module will exit the retrieve continuous DTCs mode and all continuous DTCs will be cleared.
•Always exit the procedure before powering the system down (system turned OFF). Once the procedure is exited, the ignition switch must remain ON for at least 30 seconds to allow the door actuators to automatically recalibrate.
Electronic Automatic Temperature Control (EATC) Module and Electronic Manual Temperature Control (EMTC) Module Cold Boot Process The purpose of the cold boot process is to allow the EATC or EMTC module to re-initialize and calibrate the door actuators. To carry out the cold boot process, follow the steps below.
1.Turn the ignition switch to the OFF position.
2.Disconnect the EATC or EMTC module electrical connectors.
3.Wait one minute .
4.Connect the EATC or EMTC module electrical connectors.
5.Turn the ignition switch to the ON position.
6.Select any position except OFF on the EATC or EMTC module. The EATC or EMTC module will now initialize and calibrate the mode doors. Calibration of the mode doors will take approximately 30 seconds .
Nov 27, 2009 | 2005 Ford F-150
Error code 0f00::065d msg:IDE failed self test failed read portion . Msg: Ide device failed blank media or no media present in optical drive error code ofoo:137B This is a Dell laptop inspiron 1300
its simple:
1. Get Windows XP Booteble CD from a friend or simple download it
for example "WINDOWS XP PRO sp3 x86 32 BIT"
2. Burn it on CD
3. Switch on your Laptop/PC
4. Press F12
5. Put your Windows XP to your CD/DVD drive
6. Choose from a manu DVD/CD
7. Press any key to start instalation
8. wait a couple minutes and pres R for Repair
9. wait until you will se C:\
10. and finally type "chkdsk c:"
11. after all restart laptop/pc
12. Enjoy
Sep 06, 2008 | Computers & Internet
Whirlpool Flat top Accubake self clean 24 inch
Of course - Empty the oven and clear off around it.
The AUTO-CLEAN cycle time is adjustable, from 2 hours
30 minutes and 4 hours 30 minutes in 15-minute increments.
Suggested clean times are 2 hours 30 minutes for light soil and
4 hours 30 minutes for heavy soil. The last 30 minutes of the
cycle is for cool down.
To Self-Clean Using AUTO-CLEAN
1. Press AUTO-CLEAN.
2. Press the TEMP/HOUR “up” or “down” arrow pad to set the
desired self-clean cycle time.
3. Press START.
The oven door will automatically lock. The “DOOR LOCKED”
and “CLEAN” indicator lights will be displayed. The time
remaining will also be displayed.
4. When the self-clean cycle is complete and the oven cools,
the “DOOR LOCKED” and “CLEAN” indicator lights will turn
off.
5. Once the oven is completely cooled, remove ash with a damp
cloth.
To Delay Start Self-Clean Using AUTO-CLEAN
2. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired self-clean cycle time.
3. Press START TIME.
4. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired start time.
5. Press START.
The oven door will automatically lock. “DOOR LOCKED” and
6. When the self-clean cycle is complete and the oven cools,
off.
7. Once the oven is completely cooled, remove ash with a damp
cloth.
Owner, Warranty, Installation and Parts manuals are here:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=sf362lxst&siteCd=WHRCOM
Sometimes search links don't work when copied.
Here is the direct link to the Use and Care Guide:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10110369.pdf
Page 16 has the above instructions.
God Bless!
-Ptochos
Jun 19, 2008 | Whirlpool GR399LXHS Electric Kitchen Range
Brother MFC 7420 All-In-One Laser Printer Logo
9,049 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
