Question about LG LB1200ER Air Conditioner
My Lg split system air con spits water
It spits water when it is first turned on and when it kicks in. I have had a look at the drain pipe and it is not clogged. It seems like there is a problem can you please help me as it is driving me crazy.
    President:
  • 2,976 Answers
Make sure the unit is tilted downward at the back. About 1" lower than the front is good. Even with a drain, the water will pool inside if it doesn't have a slope for drainage.
Posted on Feb 19, 2009
Water is spitting out of vents where is the drain pump on ac ?
David, there is no drain pump on your AC. There is a drain hole in the drip pan near the rear of the unit.
It is probably clogged. Another reason for your trouble is that the rear of the unit may not have the proper downward tilt. The rule of thumb is 1/4" to 1/2" downward tilt. This allows the water to flow freely to the rear drip pan drain hole.
Find the drain hole can be a challenge, as the clog can blend in with the hole. Once you find it, a pipe cleaner works well to clear the clog.
Hope this helped you & thanks for choosing FixYa.
Sep 16, 2011 | Frigidaire Fra064vu1 Air Conditioner
NOT POMPIN WATER OUT.I CAN HEAR POMP GOING BUT NOTHING HAPPENS
Hi
Dishwasher not draining issue occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. To access the drain pump, please follow the procedure---
1. Drain pumps are mounted to sumps in the front of dishwashers --they're easily accessible from the front of dishwashers by removing toe kicks.
2. Tools needed: small flat blade screwdriver (for unlocking terminals).
3. Remove toe kick/base cover, pull up terminal cover and disconnect wires (using screwdriver to unlock locking terminals).
4. To remove pump, pull latch (on circular collar) & rotate pump clockwise (cw).
5. To install new pump, insert @ 2:00 position & rotate counterclockwise (ccw).
6. Clean water & debris from base, then check float operation.
7. Connect wires, then install base cover & toe kick.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jan 29, 2011 | GE Nautilus 24" Built-in Dishwasher
Water in bottom of bosch dishwasher will not drain. How do I get this water to drain
Hi
Daniel
Jan 26, 2011 | Bosch SHU9915UC Dishwasher
My ac is spitting watter by the vent, and making noise i think it happends when the fan inside hits the water that acumulates inside is there something i can do to fix this and make the water go out
The AC fan is blowing the water that has condensed on the cooling pipes.It is possible that there is clogging of dirt in the fins of the cooling pipe'
this results in water logging.The filters must be clogged and dirt has accumalated.Use a good air spray or a water jet to clean.The condensed water must flow to the rear of the unit to drain out .{A/C must be fitted slightly tilted.}.Hope this helps.
Aug 29, 2010 | Goldstar LG L1004R Window Air Conditioner
Drum wont turn water wont drain checked pump suspect frost indrain hose inside washer drain pipe seems crunchy
Your probably on the right track,if you can expose the drain pipe to heat to melt frozen portion would be an idea or you could pour hot water back the drain hose(at its outlet) to melt the water in front of it-thats the most obvious thing first anyway,small socks are a nuisance also getting clogged in drain at exit from drum to drain pump
Jan 08, 2010 | Indesit W 123 Front Load Washer
During the spin cycle, my washer seems to spit water out through the draining hose faster than the hose can take take. Water comes out where the draing hose is. How can I stop this?
You have no control ove rthe speed the water comes out of the drain hose, only the ability of the drain to cope with it. You may have a build up of detergent in the drain upstand which has narrowed the paerture of the pipe. Try putting some drain unblocker down the wate pipe into which the hose is, I assume, popped into.
Dec 11, 2009 | Washing Machines
Water keeps coming back out of washer drain
DRAIN HAS A SLIGHT CLOG AND BEING SINCE YOUR NEW WASHER IS MORE POWERFUL AND EFFICANT YOU MIGHT EVEN HAVE TO RESIZE THE PIPE FROM THE TRAP TO THE DRAIN THIS IS CALLED A STAND PIPE SHOULD BE 34INCHES TALL FROM TRAP IS WHAT IS REQUIRED UNDER CODE TO KEEP THIS FROM HAPPEING
May 29, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
A/C Clogged drain pipe
Can you get to the hose in the house unit? If so canned air
May 26, 2009 | Carrier Heating & Cooling
My drain pipe for my washer doesn't drain the water fast enough.
No, but you can try snaking the drain or use something stonger like muratic or sulfuric acid. You may also want to check the venting on this drain.
Mar 15, 2009 | Washing Machines
LG LB1200ER Air Conditioner Logo
543 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
