Viking 24 in. Professional Series VUD141  Built-in Dishwasher
Problem for Viking 24 in. Professional Series VUD141 (Ultra-Premium)...
I have 2 Viking VD141 Both DW are not getting
By ilive4dogz on Feb 19, 2009
I have 2 Viking VD141 Both DW are not getting enough water. They run and the soad dispenser opens but Their is very little water if any....I have taken the hose off and it is clear (no clogs)
I have viking DW and Duel fuel Range. All of these appliances have been terrible. I have had service at least 2 times a year on both the DW. I use my oven in the basement as the range. takes FOREVER to pre heat and over cooks every thing. Don't buy viking they s$%#&
Solution #1
posted on Mar 04, 2009
Not Rated)
Kgt1962
Rank: Guru
Rating: 88%, 28 votes
You don't say what happens after the dispenser opens.
These units use very little water and thus need very little soap, you can only use powder no cubes or liquid. It uses less than a tablespoon of soap. Also use jetdry it makes a huge difference to the glasses and plastic.
If you run the unit without adding soap and the water is still soapy you are using too much soap.
The Duel fuel oven uses the broiler in preheat and if you do not finish the preheat cycle then it will burn the food .
Was this helpful?
Yes
No
Solution #2
posted on Feb 19, 2009
Not Rated)
dragonsthatk
Rank: Wiz
Rating: 81%, 308 votes
it could just be your supply lines are not big enought
Was this helpful?
Yes
No
Popular Solutions for Viking 24 in. Professional
Questions and Unsolved Problems for Viking 24 in. Professional
Do you recommend Viking 24 in. Professional Series VUD141 (Ultra-Premium) Built-in Dishwasher?
Answer
Answer
Viking double oven The delay setting will not turn off or clear - when timer setting and off is... (More)
Answer
Hi - I used the self-clean feature on my Viking oven 2 days ago and now it won't unlock and I can't... (More)
Answer
water was shut off during dishwasher cycle not dish water will not work no water even though water... (More)
Answer
Viking dw 20.3 does not complete cycle or open soap door. It does drain and fill ok . When it stops... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwashers Experts
Top Dishwasher Repairmen
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
