Question about Whirlpool LHW0050PQ Front Load Washer
Whirlpool Front Loader machine will not drain
I have a whirlpool LHW0050PQ. The washer will go through its wash cycle fine, but when it is time to drain, it stops and the blinking light "Done" comes on. I have opened up the washer, checked all hoses, pumps and everything is clean: no clogs. When I put it on the spin cycle, it spins with water but will not drain at all. When it is time to pump the water out, I do not hear a pumping noise or anything.
I am not sure if the pump needs to be replaced as I checked it, and it looked super clean and fine to me.
Any ideas?
  • Paulo May 11, 2010
    When it's time to drain, can you hear a hum from the drain pump? (If so the pump is getting power but might be jammed. If not check the electrical connection to the pump)
    Removing the drain boot from the pump, are you able to manually rotate the drain pump impeller? (reach inside and turn it with your finger - unplug the machine first!)
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 5 Answers
On our LHW0050PQ the "Done" light stays on solid-- it does not blink, so on yours it may be indicating a malfunction, either in the electronic control or a problem with the pump. As VersaStyle suggested, you can check the connection to the pump, check for power to that connection and also look for evidence the impeller might have a pin or something stuck in it. If it used to work and it made a lot of noise before failing, I would suspect an object lodged in the impeller or a seized bearing.
(I find that when I use non-HE detergent, the pump gets really noisy, making sounds like the bearing is going out. I have a solution for that, but your situation sounds like a complete failure somewhere.)
Posted on Mar 05, 2009
LHW0050PQ4 whilpool washing machine goes through wash cycle but wont rinse,spin or drain
According to the service manual, if the washer won't drain or spin the drain may be clogged.
http://www.searspartsdirect.com/partsdirect/user-manuals/27552/lhw0050pq4-whirlpool-parts-residential+washer-manual
Apr 04, 2014 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool Front Load Washer (LHW0050PQ) not spinning
Use a quarter inch nut driver to remove the bottom panel. A tech sheet should be under there that will give diagnostics. Open the pump filter and check for objects.616c06e.jpgea4423e.jpgfb90284.jpg
Jul 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Spare part for chinese made whirlpool washing machine
what cycle are you using?there are a couple of things that cause the timer to stop,eg- water not heating - not draining etc. can you try a cold cycle if there is one on your machine. was the water in the machine getting hot?sorry to ask you these questions but you might not need a timer hopefully. have you tried the whirlpool website? please reply 4 more help.
May 24, 2010 | Whirlpool LHW0050PQ Front Load Washer
LHW0050P Whirlpool washer?
As I understand, when you order the door boot, an instruction paper comes with it. I have done it but each model and make is different. I would research the net also.
Feb 07, 2010 | Whirlpool LHW0050PQ Front Load Washer
Need to reset whirlpool duet front load washer
How do I reset a front loader Whirlpool washing machine. The time keeps flashing. I drained the washer and now I need to reset it.
Jun 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Basically,the machine you have is garbage! - I have one also, It is less than one year old and the repair folks have been out 5 times. It doesn't spin either!
I'd call this one a lemon!
Apr 14, 2008 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool LHW0050PQ Front Loading Washer VERY NOISY during spin cycle
remove the top access panel 3 screws in top rear.
now look around and push on the drum from top
it has suspension shocks and springs like your car they should resist any movements.
look/wiggle the concrete balance blocks , no cracks or loose.
inside the tub are the arm solid /not loose.
run it with the top open what do you see/hear and where
look under the rubber flap in front did anything get under the tub
Dec 29, 2007 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool LHW0050PQ Front Load Washer Logo
621 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
