Question about Philips Magnavox 9P6034C 60" Rear Projection Television
I NEED TO KNOW HOW TO SWITCH MY 480I TO 1080I
  • 8,596 Answers
You can't do it through the menu - you have to connect your cable or sat box to the TV using red, green, and blue component cables to the right most red/blue/green slot on the back of the TV. It will upconvert automatically.
-Tha Mp3 Doctor
Posted on Feb 21, 2009
I have a 47" Visio 1080p. Tv is always set at hdmi
AV inputs are for standard analog video which is 480i. HDMI and Component inputs are the high definition inputs that run at either 1080i or 1080p You won't ever get 1080i or p through AV inputs.
Oct 22, 2012 | Televison & Video
My TV is only 480i. When my receiver reboots, I cannot see the settings menu to configure the receiver to output to 480i. I need to know the remote keystrokes to press to configure the receiver for...
You did not give your model number of receiver. Some of the ones from 2007 or so have a switch on the back for video resolution, 480i, 480p 720p 1080i so set this switch to 480i.
Mar 08, 2011 | Samsung HDTV Digital Terrestrial Receiver
Want to change my cable box from 1080i to 480i
U can't not change mode at will,the 480i or 1080i is determin by the show what mode is play on.1080i only in HD,more HD will need to order from ur cable,dish or telicom compannies.
Dec 17, 2009 | Sony Bravia KDL-40S4100 40 in. LCD TV
Switch from 480i to 1080i
if the signal is not 1080i the tv will convert back to 480i. check your content.
Aug 20, 2009 | Mitsubishi VS-60111 60" Rear Projection...
Sharp aquos 1080i is showing up at 480i. How do I
I have the same problem I'm sending 1080i to the screen and it will only display 480i. I too would love an answer to this question.
Jul 18, 2009 | Sharp AQUOS LC-42D85U 42 in. LCD TV
Adjusting the resolution from 480i to 1080i
Typically TVs will auto adjust to the input signal it receives. If your cable box is only outputting 480i then all the tv will show is 480i. Ensure you have a good 1080i signal going in to the unit and check again
May 04, 2009 | Televison & Video
480i to 1080i?
It depends on which input you are using, but the HDMI inputs are auto detecting. Most likely whatever device you have connected is not putting out a 1080i signal, and needs to be configured to do that. Once you do, you should see the input icons on the top right briefly come up, and below the input number, you should see "1080i"
Feb 01, 2009 | Sharp Aquos LC-52SE94U 52 in. LCD HDTV
High Def.
If you are using the component inputs it will select 1080i automatically IF that is what it is being sent. Make sure your device (cable/satellite receiver) is set to 1080i. The TV recognizes 480i, 480p(progressive scan DVD player) and 1080i. It DOES NOT recognize 720p. Since it has no HDMI or DVI input it can't do HD DVD or "upconvert" DVD but it does very nicely with 480p/progressive scan.
Dec 24, 2007 | Mitsubishi WS-65311 65" Rear Projection...
Greater than 480i over component?
try switching the resolution settings on the DVD player and/or the TV. I have had a similar problem and there was a manual switch i missed.
Sep 16, 2007 | Philips DVDR75 DVD Recorder
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
46 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
