Question about Motorola Mobility ROKR E8 Cellular Phone
Ringer delay i m experiencing ringer delay with my motorola rokr e8. normally it takes 5-6 ringer delay time means i can hear a ring after the caller hear it for 5-6 times and same with the caller id appearance. 90 percent of my call are missed calls. can u help?
Try copying your ringtones onto your phone instead of having them linked as ringtones from your memory card.
Posted on Feb 21, 2009
How do I turn the ringer on, on the handset?
Press program/mute button to confirm and you may program the following items: Set Language, Handset Name, Ringer Tone, Ringer Volume, Message Alert, Ring To Answer, Security Code, VIP Melody, Key Tone, Audio Predial, Vibrate Ringer, Area Code, Tone/Pulse, Registration, Deregistration and Default Setting.
Ringer Volume
From the Handset Setup Menu:1. Press the caller ID-volume ( 6 or 5) button to scroll to the RINGER VOLUME sub-menu.
2. Press program/mute button to enter the menu. SET RINGER 1HI 2LOW 3OFF shows in the display.
3. Use the touch tone pad on the handset to select 1, 2or 3, or use the caller ID-volume ( 6 or 5) button to scroll to your selection. HI is the default setting.
4. Press the program/mute button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
NOTE: If you turn the ringer OFF, the ringer off icon shows in the display.
May 27, 2016 | Uniden Cordless Phone
Phone will only vibrate and not ring
a. Make sure your ringer is not in vibrate mode.
1. Press Menu > Settings/Tools > Settings > Sounds > Ringer Type > Voice Calls. 2. Select Caller IDor No Caller ID. (A list of ring type categories will be displayed.) 3. Select a category, and then use your navigation key to scroll through the available ringers. A sample ringer will sound as you highlight each option. 4. Press OK to assign a ringer.
b. Make sure your speaker works. Turn On your speaker phone while talking to someone and see whether you can hear or not.
c.Make sure the increase the volume using keys on side of your phone.
Mar 14, 2011 | LG RUMOR Cellular Phone
My phone rings to quiet to hear
Hi, what makes the ringing of the phone to be quite to hear is because the ringer that makes you hear when the phone rings is getting weak and it needs to be replaced.
When you replace the ringer the phone will ring better again.
Take care.
Oct 06, 2010 | Motorola Mobility RAZR V3
NOK 5130 MUSIC EXPRESS, I M NOT RESET WITH DEFOULT RING TONE AND THEME.
I have a Nokia XpressMusic 5130c2 phone. When someone calls me there is music that they are hearing instead of a ringer tone. How can I remove this & just for my incoming callers to get a normal ringer tone? Thanks
Sep 17, 2010 | Nokia 5130 Cellular Phone
Set call rings
From the manual:
1. Press the CALLER ID-VOLUME ( 6 or 5) button to scroll to the RINGER VOLUME sub-menu.
2. Press mute/menu OK button to enter the menu. SET RINGER LEVEL 5 shows in the display.
3. Use the CALLER ID-VOLUME ( 6 or 5) button to scroll to your selection. LEVEL 5 is the default setting.
4. Press the mute/menu OK button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
Apr 26, 2009 | General Electric 28811FE2 Twin Cordless...
INCOMING CALL IS DELAYED
you can try reseting your phone,but this phone is naturally slow...
Apr 09, 2009 | Motorola Mobility ROKR E8 Cellular Phone
On and off switch on my Motorola Rokr E8 cell phone
The power switch for the Motorola Rockr E8 is on the little silver switch on the right side of the phone. If you push the switch up it locks the phone. Pushing it down unlocks the phone. But if you push it down and hold it there for a little while the phone will turn off. Just hold it down again to turn it back on.
Mar 17, 2009 | Motorola Mobility ROKR E8 Cellular Phone
I don't have any ringtones on my phone or I am looking in the wrong place.
1. Go to 'setup'. SELECT IT.
2. It has the first option as 'Ringer Alert Style'. SELECT THAT.
3. You will find type of alert styles like: Ring Loud / Ring Soft / Vibe and Rig Loud etc.
4. Select the ringer type you use (You will not get any ringtones on silent or vibrate mode).
5. Select Edit. You will now find options of ringtones.
Hope this solves your problem.
Mar 10, 2009 | Motorola Mobility ROKR E6 Smartphone
The ringer won't stop ringer
remove the battery leave it out for about 5 mins and put it back in
Jan 17, 2009 | Motorola Mobility ROKR E8 Cellular Phone
Motorola Mobility ROKR E8 Cellular Phone Logo
191 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
