Question about Canon PowerShot S2 IS Digital Camera
Same, but... After doing your trick it worked for a while. Then I put the camera off and on again. Same black screen appeared. How can I keep that "iris" open?
  • Marko Toivanen
    Marko Toivanen May 23, 2009
    I mean:
    After doing that turn it on TV mode and 15'' it works.
    for a while. Same problem appears after 1 or 2 pics.
How do I stabilize canon powershot S2ls after zooming in on a subject?
Posted on Feb 27, 2009
When turn on, two black do appears on the monitor
Moisture got into your camera. Dry it may work or replace lcd screen if available from ebay parts camera.
Jul 15, 2012 | Olympus Stylus 7030 Digital Camera
My htc smart black keeps saying 'oops a system error has occurred, restarting and then it goes to the o2 page to show it is starting up. then it goes blank and does it again
hi guys do not worry.i vll tell u da simple trick.wich gonna really works.juz go, in supports choose your fon modle as htc smart.and download the rom upgrade file.juz switch off ur fon remove the battery and wait for a minute,and again switch it on. when the screen appears juz hold the camera button on the right edge untill u see the rom version which comes in colour.juz pluge the usb cable to it .and start the downloaded rom file,juz fallow the simple procedure.and the rom vll upgrade ur fon software,and ur fon is done. i hate dis htc service guys .when i vent to them vit dis problem,dey r asking the bill vich i hav i did it myself, and i tot to sahre vit everyone hu r facing dis problem.if u ahv any query reguarding dis juz email me,,,hope u likd it ...............
Sep 21, 2010 | HTC P3450 Touch Black Unlocked...
Hi, when my camera switches on the lights flashes a few times quickly. The intro screen comes on then the screen goes black. It totally freezes and the only way i can put it off is by removing the battery!...
Hi, I solved the problem, it appears the memory card was corrupt. When I removed it and switched on the camera it worked perfectly. Not sure why this happened!! I'm just glad my camera is working again!!
Dec 04, 2009 | Samsung Digimax i6 PMP Digital Camera
Shutter stuck, screen is black. I changed batteries, no help. tried manual shutter, pulling the batteries, and it worked until I shut it off, then next time, black screen again.
Pamela, try the battery trick again (here it is, along with other's similar experience and tips). But after you get it working, take lots of pictures before putting it away again (take a couple hundred of nothing in particular. Just erase them later. After all it's a digital). You want to really work the shutter mechanism to get out any grit or material that might be in there causing it to stick.
Jul 17, 2009 | Canon PowerShot S2 IS Digital Camera
My olympus fe-170 lcd screen won't show ANY pictures.
it would appear that the lcd screen has malfunctioned and would need repair.... you can try power cycle by taking batteries out and press and hold power button down for 10 secs, draining all power out of camera, then put the batteries back in and try again
Dec 16, 2008 | Olympus FE-170 Digital Camera
Canon Powershot SI screen goes black after taking a photo
That sounds like a sticky lens shutter. They usually have to be replaced, as they usually will need parts. When the camera is working look inside the lens and take a picture(with flash turned off). You should see a black shutter door clicking shut in the lens. When the camera acts up, look inside the lens again. If the door is staying shut full time, that is your problem.
Nov 17, 2008 | Canon PowerShot S1 IS Digital Camera
Overexposure problem after the black screen
Given that the 15' batteries out trick is just a way of forcing the iris to get un stick i think your iris is probably still getting stuck (but this time open a bit).
you could try doing the 15' trick a few more times in the hope of loosening it a bit.
ultimately once you have had this issue i think you are living on borrowed time before it happens again unless you get it fixed by canon.
Aug 25, 2008 | Canon PowerShot S2 IS Digital Camera
Canon s50 display problem
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
Jun 28, 2008 | Canon PowerShot S50 Digital Camera
Error message
my camera did the same thing, lens retracts 3 or 4 times, and then proceeded with an error message "turn off and on again". I pressed the power button probably about 10 times, didn't work, so then i gave it a good smack on the top of the frame a few times while repeatedly pressing the power button and it did the trick. Hasn't gave me problems since...hope it helps
Mar 29, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
167 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
