Question about Gateway 830GM PC Desktop
Usb ports not recongized
Ok my next problem with this computer is my usb ports dont seem to work...what do i need to do to get them to work...doesnt show up on panel (meaning going to my computer) like it isnt there and i did plug in the cord for it but there are two places to plug it into dont know if it really matters which one it really needs to be plugged into though
  • 2 more comments
  • jlfw65
    jlfw65 Feb 19, 2009
    well all four of the usb ports on back work great it is just the on the front that i am trying to get working and it is plugged into the mobo but also like i had said there are two places it can be plugged into and i dont know which one is the correct one...i really perfer to having the ones on the front work because it is easier to access and i dont have an extention for the usb on the back and a lso tried to redown load the drivers but said that they already i guess i might be good there...well i hope i am..
  • jlfw65
    jlfw65 Feb 20, 2009
    i really wished that would have helped me, so how do i tell which is
    the correct one for me to use since i only have two to choose from the
    mobo is ag915g 3.0
  • jlfw65
    jlfw65 Feb 23, 2009
    as i have said before i have seen this pic and it did not help me my
    board is different and i have tried both connections and neither of
    them worked...but thanks for trying it is appreciated
  • jlfw65
    jlfw65 Feb 23, 2009
    i will recheck the circuit but i didnt see anything the first time round, but thank you for trying. I was hoping it was just the drivers for it, but that is not it either and if don't get them to working I will just have to get an extension for the back panel, and once again thank you
  • 1,226 Answers
Do use in the front ports, sometime this port is unplug to the motherboard so it need to connect before you can use that port. In the back port you can always use that ports in there it is safe to connect any plug and play device such as flash disk or usb port printer. if this both not recognize your any device you inserted then probably your device is dead. try insert your device to other pc to see if still working if not then maybe the driver of your pc are not installed. try reinstall all the driver of your system.
may this help.
Posted on Feb 19, 2009
  • 2 more comments
  • Emelio Navaja
    Emelio Navaja Feb 20, 2009
    It is great, then your problem is in the front ports, I recommend that maybe extension work great, however if you insist to connect the front panel then you can refer to this picture for right connection.(careful wrong connection it damage your device that is why i suggest usb extension from back ports)
  • Emelio Navaja
    Emelio Navaja Feb 23, 2009
    Hello Again,
    That is why i giving you this link for the proper cable coding in connecting your front panel usb ports. Just open your casing and then trace the wire connecting to front P usb ports and then refer to the picture (the given link) to connect to the mainboard.
    thank you for using fixya.
  • Emelio Navaja
    USB cable connection code are the same in all motherboards what ever brand is it. so if you tried that then probably the front panel uSB ports got grounded. If you have a slight knowledge in electronic then repairing the circuit in it will resolve your problem.
    Sorry for not resolving the issue but in every issue there is a very useful option. so why don't utilize the very good option.
    "Don't let your ideas block by this problem. This will make you create complex ideas. but if you consider the issue and utilize it you end up in open minded and it will resolve the issue.
  • Emelio Navaja
    Emelio Navaja Feb 24, 2009
    Hello Again,
    It sounds good! Thank you for using fixya. hope to see you next time around.
Usb ports dont seem to work
In order for the usb ports to work you must have 1 usb from the computer connected to the monitor. The monitor may have a specific input port from the pc in order to activate the other ports on the monitor
Mar 22, 2014 | Dell 1704FPTt 17" TFT LCD Flat Panel...
My lg external hdd hxd2 works with other computers but not on mine i have reformatted my windows 7 and it does not work ?
I usually face scenarios like yours and this is what i normaly do. Firstly Change the USB ports(in other words try all the usb ports you have on the computer. If it doesnt work try to use a diffrent USB cable. If it doesnt, then open up the hard drive and remove the usb connector and connect it directly to your computer's motherboard as a slave. Here, no doubt you will access it. Even though you have re-installed Windows 7, maybe your computer needs High speed USB Drivers
Dec 19, 2011 | Computers & Internet
Turned on computer .mouse doesnt work .seems
>>if its usb plug your mouse into diffrant port >>or just unplug give a small blow from you mouth to remove any dust from port and reconnect it
please rate my solution.....
Apr 11, 2010 | Toshiba Satellite A100-S8111TD Notebook
Vu point digital film/slide converter wont work when i plug the usb plug from the scanner into the computer a brief image appears across the screen aprox 3 secs (pic of scanner itself) then goes blank. I...
if this unit came from HSN (most did) then their specs show that it needs xp .. but their video claims it works for vista as well .. actually it depends on which model you have .. the FS-C1-VP . runs only on XP and below .. model FS-C1-Vp-BX2 .. has software to run on Vista and below .. Model FC-C520-VP-Bx2..runs on anything including vista and doesnt require software .. it just looks like a Mass Stroage Device when you plug it in .. these all look like a nice little machines for slides and negitives .. you might try unplugging the device .. reload the software (if you have any) ... then reattach the unit (to a different port) .. still problems then the USB port may be going into current limit .. you can try a different USB port (maybe one at the back of the computer) or better yet use a port expander with its own power supply .. make sure you dont have other USB devices that might be drawing current from the same USB source device (ok with the expander) .. if that doesnt get it going then if it came from HSN you can call their customer service number .. 800 933 2887 ... your item number would be 320-712 ... if the port expander or other suggestions fix it then let us know ..
it sounds like the unit is just drawing more current than your USB port can supply .. that happens a lot with large USB memory sticks (8gb or more) .. they are getting very close to or even exceeding the spec on the port .. some USB ports can do it others just shut down .. the external port expander with a power supply will almost always fix that problem and they dont cost much .. they are kind of nice also because you can put the expander ports within easy reach.
Dec 22, 2009 | VuPoint Cameras
When I plug my sandisk into the computer, I can't find it-but if I plug memory stick into same plug I can find it. How come my computer is not recongizing the sandisk
i was having the same issue, the usb port i was using was in the front of my pc, it wasn't recognizing it.. i plugged it into one of the usb ports in the back of the pc and now it seems to be working fine... hope this helps
Jul 25, 2009 | SanDisk Sansa e260 MP3 Player
Sony cbyershot
This means Cybershot is OK. Some thing to be checked in computer.
Try it in another USB port of computer. Check USB drivers of PC and better to update it by going to support page of your computer brand.
Oct 08, 2008 | Sony Handycam DCR-HC20 Mini DV Digital...
Usb device not recongized showing this error in my pendrive
wat is the error msg tht u get?? Did tht pen drive came with a cd......try connecting the pendrive to all usb ports on the system....if tht doesnt wrk, go to device manager & then uninstall all usb root hub under usb option.....restart system thn chk
Jul 22, 2008 | Toshiba Satellite A135-S2276 Notebook
Aspire 3610 USB ports
I think you might have a loose cononection for the data ports. Try putting a little bit of force on the usb device. Up, down left right. NOT ALOT. If it starts working when force is used, i tihnk you should try to take it apart and resolder the connections. If it dosen't work, uninstalling the driver and installing.
Jun 01, 2008 | Acer Aspire 3680 Laptop
Unable to access elements hard drive
Hiya dtwhite... I would suggest that the hard drive has died.. "Elements" are notorious for giving up the ghost, and normally around the 13months mark! I had a 320gb hard drive with exactly the same symptoms. Lost a helluva lot of music and photos!
One sure fire way of eliminating, whether it is just the leads at fault, or connections.. on the unit .. which very rarely it can be.. is to take out the hard drive and connect direct to your pc.. as a slave.. ( Do you know how?)... you may get lucky and find it still works... I would suggest though that if you are.. move evrything off ASAP on to something a little more reliable like a Western Digital... Never had a prob with this brand.. or indeed Toshiba! who are relatively new to the hard drive world. Use your Elements purely as an absolute emergency backup drive.
Remember to earth yourself and comp before removing or replacing anything.. or it will turn out to be an expensive exercise.
You require any help with jumper settings let me know
regards Faggly
Mar 22, 2008 | Western Digital 250GB ELEMENTS EXTERNAL...
Computer doesnot recongize my sansa
well from what im learning cause mine is doing the same thing, you'll have to format your sansa or update your usb port
Jan 06, 2008 | SanDisk Sansa e250 MP3 Player
Gateway 830GM PC Desktop Logo
85 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
